Old 05-25-2013, 03:48 PM   #57
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
how much does a UOA typically cost?
chenshuo is offline   Reply With Quote
Old 05-25-2013, 03:59 PM   #58
bluesubie
Drives: 2004 Subaru Forester 2.5XT
IMO, the best bang for the buck is Oil Analyzer's Inc for $22.45 which includes TBN, nitration, and oxidation.
http://oaitesting.com/prices_automotive_fleet.htm
-Dennis
bluesubie is offline   Reply With Quote
Old 07-10-2013, 01:12 PM   #59
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Bump for any further updates? I'm tempted to swap due to burning a lot of mobile 1 my last two oil changes. Either this or Amsoil
Old 07-10-2013, 01:35 PM   #60
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Originally Posted by Coheed View Post
I'm using the GC 0w30 as well and don't have any idle dip issues, even with AC going. Engine runs smooth. I'm not really sure how much of this is attributed to the weight of the oil. But I am a bit harder on my car than most, and I do see track days without swapping oil out.
Since its been hot and I've been using the A/C, my idle dip came back even after I had Toyota reflash the newest calibration. Do you really think changing to 0W-30 is the reason it's smoother to you?
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 07-10-2013, 01:35 PM   #61
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Honestly, I would try the GC 0w-30. It's a slightly heavier version of a 30 weight so it may help your consumption. Also, my engine seems WAY smoother and more willing to climb from lower than normal revs. Ex. 3rd gear at 1000 rpm no problem. My 2 cents
Gords_zenith is offline   Reply With Quote
Old 07-10-2013, 10:07 PM   #62
roddy
roddy's Avatar
Drives: '13 Ultramarine
I like GC. I used it last summer when it was really hot, and the engine was more quiet on that than anything else I've tried. There is a slight valvetrain noise that I can hear with the TGMO 0W20 (current fill) and Amsoil SS 0W20 that I don't notice with the CG. I also use it in my wife's RDX (turbo), and my Mustang (supercharged).
The RDX Used Mobil 1 5W30 before, and would go through about 1/2 a quart between oil changes (5000 miles). Not bad considering it's got over 100K miles on it. Since changing to GC, the oil level hasn't moved, and she's about 4K miles in.
The Mustang didn't get switched over for any particular reason, other than having some GC on hand. I previously used RP 5W30, M1 5W30, and Amsoil SS 5W30/10W30.
Old 07-15-2013, 10:55 PM   #63
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
at 1,000 miles I did an oil change with GC 0w30 and a OEM subaru filter, and did a 2 day track weekend at Sebring (8 total 30 min sessions), where I hit close to 300* oil temps based on the OEM sensor, so I will report back with my UOA when I send it off shortly.
smbstyle is offline   Reply With Quote
Old 07-16-2013, 12:25 AM   #64
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Originally Posted by Hanakuso View Post
FYI Autozone is having a $29 sale on 5 bottles + Fram filter. There's an option to go with Mobil 1 filter for $4, which I did for my GF's Jetta since I prefer the OEM filters
Not sure if this is a nationwide sale but all 3 local stores had this deal here in SoCal
Yep, I bought a few complete oil changes of GC with this deal. They gave me Bosch filters. Using the OEM though.
mines13 is offline   Reply With Quote
Old 09-14-2013, 05:32 AM   #65
finch1750
finch1750's Avatar
any update on this?
Old 09-14-2013, 09:55 AM   #66
smbstyle
smbstyle's Avatar
any update on this?
Ah yes, sorry for the delay. I have attached the UOA.
Here is my email conversation with Blackstone as well as their comments regarding track use:
ME:
I use the car a lot for track days. This was after two days on track, with approximately 250 track miles. Do you see any issue with running longer on the same oil? The oil temps were in the 290*s, so that is why I was worried about running more than two days on this oil. I just recently completed a single day event on Toyota 0w20, which I will be sending in a sample of as well after the next track day.
BLACKSTONE:
Scott,
Running longer on the oil shouldn't be a problem. The oil itself was fine in your sample, and the wear levels weren't unexpected for a new engine, so we don't see why not. When running more track days on the oil, you might see some of the wear metals reading higher than average, but that's normal with engines used for racing. You could try increasing your oil runs slowly (say, adding one more track day or 300-500 miles to the previous run), and seeing how your engine and oil are handling that kind of use.
The Following User Says Thank You to smbstyle For This Useful Post:
finch1750 (09-14-2013)
Old 09-28-2013, 12:45 PM   #67
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
What about Mobil1 0W-30?
garfull is offline   Reply With Quote
