View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 07-10-2013, 11:54 AM   #2227
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by Tromatic View Post
Do some of you not understand that the pump itself is either poorly designed of has some defect that causes the chirp? Until the re-design or permanent fix, odds are your pump will chirp, no matter how many you try.
I think the more likely issue is that Toyota didn't do their due diligence with testing and never imported any American gasoline blends to test the car with.
Old 07-10-2013, 12:08 PM   #2228
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Toyota and Subaru rigorously test all their cars in America like just about every other manufacturer who sells a high volume here, primarily testing high heat scenarios in the Southern California desert (doesn't get much hotter than Death Valley).
Why would they spend thousands of dollars importing fuel blends from around the world when they can just ship a couple test cars to certain locations? I also remember some statements that the suspension was actually tuned by region, so our FR-S probably has a different setup than the GT-86, not a huge difference but there's different parts in there.
Five bucks says the engineers shrug it off, it's only a noise after all, the PR team probably forced a fix to retain "legendary reliability".
ineedyourdiddly
Old 07-10-2013, 12:23 PM   #2229
HunterGreene
Hail Magnet
You may be right, or they didn't test the cars for more than 2-300 miles. Some people weren't getting the chirp until they got closer to 1000 miles.
The Following User Says Thank You to HunterGreene For This Useful Post:
icecreammmm (07-12-2013)
Old 07-10-2013, 12:29 PM   #2230
strat61caster
You realize the miles driven has more to do with fill ups cycling fuel through the pump than actual miles traveled right? Some appear on the first tank of different gas, some on the second, third, or twentieth.
It might have more to do with using a consistent blend than anything else for all we know, for instance the one time I tried Shell V-Power every third post talks about was my loudest tank, switched back to the cheapest station around (Arco) and it got quieter.
Anyway, they typically run cars in high heat actual scenarios to test for failures, that means at least 10,000 miles and on cars designed for reliability likely 100,000 miles (time permitting), I would bet another five bucks that there's a Toyobaru test mule in America right now with well over 60,000 miles on it.
ineedyourdiddly
HunterGreene (07-10-2013)
Old 07-10-2013, 10:46 PM   #2231
NIKOLA
NIKOLA's Avatar
Drives: 2013 Scion FR-S in Ultramarine
Well, I brought in my car today to get a new High Pressure Fuel Pump installed and so far no crickets. However, only time and mileage will show whether or not my crickets are gone for good. From what I've read "here" it just doesn't seem like the problem will go away until a truly re-designed fuel pump is finally made available to us.
Let's see what happens.....
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
NIKOLA is offline   Reply With Quote
Old 07-10-2013, 11:20 PM   #2232
Carwhisperer
Drives: A lot of supercars.
You're all wasting your time getting new HPFP's.
Carwhisperer is offline   Reply With Quote
Old 07-10-2013, 11:25 PM   #2233
BRZnut
Drives: BRZ DGM Limited
Want to give an update....use at your own risk but I have been doing the 2 cycle oil additive to the fuel, just as I did with my I30, and have not had the crickets. Also, my BRZ engine is much quieter, especially at idle.
http://forums.maxima.org/fluids-lubr...ml#post8784502
anyone else doing this??
The Following User Says Thank You to BRZnut For This Useful Post:
sierra (07-11-2013)
Old 07-10-2013, 11:31 PM   #2234
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
So 83% of our sample space have had issues and Toyota/Subaru have just p**sied out and called it normal, really? that's not right, I hope there will be aftermarket HPFP when I get an FRS because no one wants a modern sports car to sound like a 60s-80s muscle car belt squeak tisk tisk toyobaru
Old 07-10-2013, 11:34 PM   #2235
NIKOLA
NIKOLA's Avatar
I wouldn't say that you are wrong. However, we who try may get lucky and get a pump that "is" actually re-designed and solves the problem. Even if the part number is the same there would be revisions to said part number.
Old 07-10-2013, 11:58 PM   #2236
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Reality of the situation is if everyone keeps having their HPFP replaced under warranty, ToyBaru's accountants and executives will spend money to develop a redesign. Right now they're banking on most people being ok with the loud chirping.
mwjcyber is offline   Reply With Quote
Old 07-11-2013, 01:31 AM   #2237
zoomzoomers
zoomzoomers's Avatar
So after about 3.5k miles of silence, the chirps have come back!
I really think it's the gas. When I was exclusively using Shell 91, the chirps went quiet. I got a little too confident since it was quiet for so long. Recently I've been using all sorts of different gas, the BAM!!! The chirps came back today. My last fill up came from Chevron. Haven't used Shell for the past 2 fill ups.
Old 07-11-2013, 07:41 AM   #2238
BRZnut
Be brave and try the oil...at your own risk of course...and see how it works!
Old 07-11-2013, 08:42 AM   #2239
sierra
Drives: Skoda Yeti DSG diesel 4x4
Good to see it mentioned again.
Here's a post on this same thread from almost a year ago suggesting the same solution but it got a lot of flack and ridicule. Some tried it and were pleased when the noise shut up.
http://www.ft86club.com/forums/showp...&postcount=159
I'm amazed that 83% have the crickets in the US when it seems unheard of in Oz where ethanol is rare and then it's only used in the lower grade that we can't use. Mine has 10,000km on the clock and idles quietly as do all the other here apparently because i've never seen any mention of it on the forums here.
sierra is offline   Reply With Quote
The Following User Says Thank You to sierra For This Useful Post:
Marrk (07-11-2013)
Old 07-11-2013, 12:37 PM   #2240
EL_to_TBD
EL_to_FR-S!
EL_to_TBD's Avatar
Drives: Scion FR-S
What are the octane options in Australia?
What about Japan? I bet this was talked about already, but has anyone there had the crickets (sounds like an STD)?
EL_to_TBD is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
