#57 |
Drives: '13 GBS Subaru BRZ
So as I lay awake with a bout of insomnia last night I was working out the basic control concept I wanted for my prototype. Simple is the key at this point and should be easily done with a PICaxe microcontroller, and inputs from the Throttle Position Sensor, and a MAP sensor.
Fun with flow charts!
| The Following User Says Thank You to neutron256 For This Useful Post: | No Limit Motorsport (07-11-2013) |
#58 | |
i would suggest that we prototype the whole thing on an arduino then move to having bespoke boards printed. that will result in the lowest possible cost, can be completely open source (megasquirt is not, very important detail), and it will allow people with an arduino at home to wire their own circuit and use it as is. with an open source project it is extremely important that there are no proprietary dependencies. every link in the chain must be something like GPL or MIT licensed. |
| The Following User Says Thank You to jamesm For This Useful Post: | Frs300 (07-10-2013) |
#59 | |
Drives: FR-S 10 #103 AT
Cross reference throttle position and engine rpm to find boost target. This way you have absolute control over what rpm and/or throttle position sets what boost level. The level of control is far greater.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#60 |
Drives: 2013 FR-S whiteout
What would be wrong with having a tiny off-the-shelf arduino (or similar)?
#61 | |
#62 | |
#63 | |
I favor the PICAxe for a few reasons: 1. I'm used to working with them 2. They use BASIC so they are stupid simple to program even for non-programmers like me. 3. They are dirt cheap. I mean like $3 cheap.
#64 |
Drives: 13 White MT FR-S
What about power source? 24v like the Phantom, or more? I had some old industrial UPS wet cell batteries I was thinking would work, although they are heavy.
#65 | |
Voltage really depends on what motor you decide to use. I'm looking at around 36V but I'm still researching that side of things.
#66 | |
| The Following User Says Thank You to mid_life_crisis For This Useful Post: | jamesm (07-10-2013) |
#67 |
mainly just that it costs more than it has to. you're paying for a uart-serial chip that you won't need, and a few other things. with an atmega on a bespoke board we could get the cost down below $10 probably.
#68 | |
#69 | |
of course when the system is armed a simple scaling of throttle percentage to motor speed is less than ideal as well, as we're not concerned with motor speed, we're concerned with boost. it should read map, then compare to a boost target referenced from rpm and throttle position. this is a far more flexible design, imho. |
| The Following User Says Thank You to jamesm For This Useful Post: | mid_life_crisis (07-10-2013) |
#70 |
Drives: Raven FRS
Funny, would said thing for 2 option. A PIC uc program in Assembler, way more efficient and simple, but that because I am use to program in assembler, I think best is to go with what you know best.
| Tags |
| hairdyerperformance, only pulls hard one gear |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 06:42 PM |
| DUP THREAD MODZ PLZ DELETE KTHX | SloS14 | Forced Induction | 0 | 07-09-2013 05:41 PM |
| Electric Turbocharger | Shankenstein | Forced Induction | 91 | 06-24-2013 02:47 PM |
| Electric 86 | frosty86 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-10-2012 02:16 PM |
| WRX Electric turbo | Neilus | Engine, Exhaust, Transmission | 42 | 05-03-2012 09:20 PM |
