Old 07-09-2013, 12:59 PM   #57
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by cb7tuner View Post
No problem, not trying to start drama with Vortech, but i think the community should be well informed of all potential problems. Maybe these are all signs we need to put on smaller pulleys and up the boost!
The smaller pulley wouldn't give more clearance... but yes, we do need smaller blower pulleys for more boost
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 07-09-2013, 01:29 PM   #58
cb7tuner
Drives: 2013 whiteout FR-S
Just got a PM from Brian@vortech, he's being very helpful and trying to correct the situation for me.
cb7tuner is offline   Reply With Quote
Old 07-09-2013, 01:40 PM   #59
Dezoris
Dezoris's Avatar
I agree, at the end of the day as you said its better to publish the issues so we all know and prevent more problems going forward.
Old 07-09-2013, 02:36 PM   #60
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
I will check my pulley at lunch time and report back. I think I might be rubbing because I have close to the same sound that was in that video. Only around 3000 RPM's. I hope there is no hole in my pipe.
Deepseadiver is offline   Reply With Quote
Old 07-09-2013, 04:27 PM   #61
charged86
charged86's Avatar
so my question is should I go buy a belt and pulley for just in case? arghghhd
under closer inspection my pipe touches the hood slightly. I just played around with the fitment of my pipe I think I have it slightly better I think this pipe needs more R & D on their side. I also hope that there is only a small batch of these pulleys going bad.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-09-2013, 04:52 PM   #62
Foobar
SLO NO MO
Foobar's Avatar
Just checked mine - there's a very slight rub mark on the bottom of the pipe going into the throttlebody but I've got at least half an inch of clearance between the pulley and the pipe on both pulleys that get close to it. Not sure if the mark was a remnant of the first install I did before I readjusted things to make sure there was no rubbing. I'll put some tape on the pipe and keep an eye on it to see if any new marks show up.
Old 07-09-2013, 05:00 PM   #63
charged86
charged86's Avatar
I like your idea. what was the order date and delivery date for yours?
I paid in feb. and received it in march was one of the new batch kits. it went to evasive then me
Old 07-09-2013, 05:28 PM   #64
Pete
Pete's Avatar
Drives: 22 BRZ
I carry a spare belt in my car just in case. I know that is the most common point of failure for any belt driven supercharger.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 07-09-2013, 05:32 PM   #65
Dezoris
Dezoris's Avatar
I have a replacement belt sitting in the trunk as well and one of the racing belt variants to test on order. I will probably throw that on if I get the pulley replacement in this week. My guess is that will add 300HP maybe 500HP because the belt is blue.
Thinking about getting a new tensioner too to be safe.
Old 07-09-2013, 06:13 PM   #66
charged86
charged86's Avatar
Geez will we be redesigning this entire kit by next year?
Old 07-09-2013, 06:21 PM   #67
Pete
Pete's Avatar
Drives: 22 BRZ
I may pick up the blue belt just for peace of mind if it isn't expensive. Also because Racecar.
Old 07-09-2013, 09:12 PM   #68
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Here is the extra belt I keep in the boot for the vortech kit. These pics may be a bit overkill
20130709-VortechReplacementBelt-002 by VictorN07, on Flickr
20130709-VortechReplacementBelt-007 by VictorN07, on Flickr
20130709-VortechReplacementBelt-012 by VictorN07, on Flickr
What is the part number for the blue belt?
F1point4 is offline   Reply With Quote
Old 07-09-2013, 09:42 PM   #69
cb7tuner
Just a pic of my bad idler removed, bearing barely moves and you can see the melted center section and lip where the belt rode on it.
Brian is sending me a new pulley and belt as an extra backup, and I'm sending them this to investigate it
Old 07-09-2013, 09:44 PM   #70
charged86
charged86's Avatar
that got pretty warm.
Kartboy Crank Pulleys 95.00 tom@kartboy Engine, Exhaust, Bolt-Ons 16 06-11-2013 01:06 PM
Crank,Alternator,Waterpump Pulleys etc..? fareastbrz Engine, Exhaust, Transmission 6 05-28-2013 08:46 PM
Titan Performance second batch of pulleys Amalgamo User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-30-2012 09:57 PM
