#57 | |
Thupercharged
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#58 |
Drives: 2013 whiteout FR-S
Just got a PM from Brian@vortech, he's being very helpful and trying to correct the situation for me.
#59 |
I agree, at the end of the day as you said its better to publish the issues so we all know and prevent more problems going forward.
#60 |
Drives: 2013 BRZ DMG manual Limited
I will check my pulley at lunch time and report back. I think I might be rubbing because I have close to the same sound that was in that video. Only around 3000 RPM's. I hope there is no hole in my pipe.
#61 |
so my question is should I go buy a belt and pulley for just in case? arghghhd
under closer inspection my pipe touches the hood slightly. I just played around with the fitment of my pipe I think I have it slightly better I think this pipe needs more R & D on their side. I also hope that there is only a small batch of these pulleys going bad.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#62 |
SLO NO MO
Just checked mine - there's a very slight rub mark on the bottom of the pipe going into the throttlebody but I've got at least half an inch of clearance between the pulley and the pipe on both pulleys that get close to it. Not sure if the mark was a remnant of the first install I did before I readjusted things to make sure there was no rubbing. I'll put some tape on the pipe and keep an eye on it to see if any new marks show up.
#63 | |
I like your idea. what was the order date and delivery date for yours? I paid in feb. and received it in march was one of the new batch kits. it went to evasive then me
#64 | |
Drives: 22 BRZ
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
#65 | |
Thinking about getting a new tensioner too to be safe.
#66 | |
#67 | |
Drives: 22 BRZ
#68 | |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
Here is the extra belt I keep in the boot for the vortech kit. These pics may be a bit overkill
![]() 20130709-VortechReplacementBelt-002 by VictorN07, on Flickr ![]() 20130709-VortechReplacementBelt-007 by VictorN07, on Flickr ![]() 20130709-VortechReplacementBelt-012 by VictorN07, on Flickr Quote:
#69 |
Just a pic of my bad idler removed, bearing barely moves and you can see the melted center section and lip where the belt rode on it.
![]() Brian is sending me a new pulley and belt as an extra backup, and I'm sending them this to investigate it |
#70 | |
| Kartboy Crank Pulleys 95.00 | tom@kartboy | Engine, Exhaust, Bolt-Ons | 16 | 06-11-2013 01:06 PM |
| Crank,Alternator,Waterpump Pulleys etc..? | fareastbrz | Engine, Exhaust, Transmission | 6 | 05-28-2013 08:46 PM |
| Titan Performance second batch of pulleys | Amalgamo | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 07-30-2012 09:57 PM |
