Old 07-09-2013, 05:50 PM   #1
jermyzy
Drives: 2013 WRB BRZ Sport-Tech 6MT
How cold is your a/c blowing?
Starting to warm up here in Vancouver, BC. Finally used A/C for the first these last couple of weeks. Even with the A/C set on "low" setting, it's only blowing cool air, barely enough to keep me cool when it's super hot. My RSX used to blow ice cold at the lowest setting. It's definitely working, because if I turn it off, it becomes warm/hot air, I just thought it should be colder than this on the lowest setting...
jermyzy is offline   Reply With Quote
Old 07-09-2013, 05:57 PM   #2
Calavera
Calavera's Avatar
Drives: Scion FR-S Whiteout
July has been hot in south TX (100 plus everyday) and mine blows ice cold on lowest setting.
If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious shit.
Calavera is offline   Reply With Quote
The Following User Says Thank You to Calavera For This Useful Post:
Guff (07-13-2013)
Old 07-09-2013, 06:09 PM   #3
radroach
Drives: car
Quit your bitching about the heat in Canada -The South
The Following 7 Users Say Thank You to radroach For This Useful Post:
6speed_Sam (07-09-2013), Calidrifter (07-09-2013), FR-S Matt (07-09-2013), ftc~brz (07-10-2013), joelg (07-15-2013), Opie (08-17-2013), rebelyell22 (08-19-2013)
Old 07-09-2013, 06:11 PM   #4
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
My A/C is blowing cold air, I can feel my fingers get frostbite if exposed for prolonged period of time..
LeeMaster is offline   Reply With Quote
Old 07-09-2013, 06:15 PM   #5
thill
When my auto A/C is on full, it is uber cold. I have to set my interior temp to about 72 or I freeze (unless it is above 95 degrees out which is rare here). And that is with me only using the drivers side vents.
I would get that checked out..
Old 07-09-2013, 06:20 PM   #6
jermyzy
Ok thanks, that's what I figured, just wanted to check with others before I brought it in.
Old 07-09-2013, 06:29 PM   #7
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
I would say there's a problem with your a/c. Here in Arizona on the hottest day yet it's not very long after I have my a/c on that I have never had to run the fan speed above #2.
whaap is offline   Reply With Quote
Old 07-09-2013, 06:46 PM   #8
Mikem53
Drives: FR-S 6MT
Agreed.. Low 90's here with high humidity.. AC works great and gets cold instantly..
Which is a good thing with raven
Mikem53 is offline   Reply With Quote
Old 07-09-2013, 06:46 PM   #9
PMPB
Drives: BRZ Sport-tech
Even with it set at 24 Celcius for both zones, it's blowing really cold. It's currently in the 30's in Ontario with ridiculous humidity. Some days it's "Feels like 40C". Even so, the air coming out is dry and very cold. I'd say you have a problem.
PMPB is offline   Reply With Quote
Old 07-09-2013, 07:38 PM   #10
Mikem53
Drives: FR-S 6MT
If its just starting to warm up outside... Then your fine..
The hotter it gets outside, the more efficient the AC becomes..
Old 07-09-2013, 08:14 PM   #11
topazsparrow
Drives: slow
Mine isn't that cold either. I can run mine on max with the recirc on for hours and the cabin never gets cold - just comfortable.
I thought it was just a weak AC system to save weight and fuel, but after reading some posts I think I might take it in and get it looked at. I'm also near Vancouver.
topazsparrow is offline   Reply With Quote
Old 07-09-2013, 08:19 PM   #12
FR-S Matt
Mine is very cold, thankfully... 98-104 degree days!
Old 07-09-2013, 08:36 PM   #13
BoxRZ_86
BoxRZ_86's Avatar
Drives: 2013 Subaru BRZ Limited SWP
here in New Jersey we have been having some humid days in the 90's, i have mine on LO at full blast and it just keeps me cool. compared to my old 2005 acura tsx this ac is decent but my tsx ac was amazing. but i am also a big guy and am always hot.
BoxRZ_86 is offline   Reply With Quote
The Following User Says Thank You to BoxRZ_86 For This Useful Post:
FnFast (07-10-2013)
Old 07-09-2013, 10:25 PM   #14
PMPB
Question
Unfortunately you don't know how heat pumps work, and this is very false.
There is no need to get into a huge discussion about the physics of it, but it's safe to say that if it's less than 35 Celcius outside, and his A/C not blowing very cold air, there is a problem.
Mind-blowing features of the next model BRZ Baldoak BRZ First-Gen (2012+) — General Topics 89 08-28-2013 07:59 PM
Passenger side HID Ballast keep blowing CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 3 04-13-2013 01:13 PM
it to cold Pekingduck Southern California 9 01-05-2013 09:08 AM
Did the issue with the air vents blowing hot ever get resolved? fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 25 09-05-2012 02:21 AM
A/C Compressor blowing hot? Is this normal? SocalBurt Engine, Exhaust, Transmission 3 08-22-2012 08:10 AM
