#743 |
this seems like an excellent opportunity for an open source project. i'll donate time to the microcontroller programming and solid modeling/fea/machine work. i already have a turbo, but it'd be good for the community to get together and build something awesome. i'll even stand up the website/repo/forum to collaborate on. who's in?
#744 | |
Drives: 2001 Sunfire GT + 2007 Mazdaspeed3
| The Following User Says Thank You to Wild Weasel For This Useful Post: | ATL BRZ (07-09-2013) |
#745 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
@Robftss , can you address these questions please? ![]() |
#746 |
Drives: FR-S 10 #103 AT
Some of us have been asking for an update that will allow safely running it without a tune, as that would be a true bolt on, removable without a trace for the dealership, installation.
I think (okay, hope) he is looking into the best way to do that. Plus there are the hordes of power mongers clamoring for more boost on the upper end. There is a little more work for this to be ready for prime time. www.phantomsuperchargers.com if you want to see some of his other kits and get a feel for pricing.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#747 |
Rob has told me that this is going out to i think 4 forum members that have contacted him through the website. phantomsuperchargers.com
Interested applicants can contact him though there but if you want the product now you have to understand the limitations ie. the system is not going to make 5psi at redline. Ive only had this on my car for about 2 weeks so he is looking for more data before he gets this going full speed. Thanks, |
| The Following User Says Thank You to fenton For This Useful Post: | SloS14 (07-09-2013) |
#748 |
Drives: VW
Very good results on Fenton's FR-S, arms length feedback on his and others who have tried it determines the final product.
Variable control devices have been modelled to simulate conventional induction, conventional induction is variable by its nature because its relationship to its power source, attempts are being made to stay 'off boost' as long as possible and only use it to raise the base engine's ability when needed. This provides better economy and longevity, in other words trying to simulate a WOT condition. ![]() Presently, the partial activation provides better than stock intake (~6-8 "WC) and adds a little power and excellent tip in responds where needed. The onset of boost is deployed not to overwhelm the base engine and is applied smoothly, it is simple and very effective. As far as stock tune, Fenton drove around for a week being mindfull below 3K. Since this is activated with a simple throttle switch any number of 'window switches' can be used, even ones that activate a rev limiter tach light, cheap and effective. Providing a calibrated or user adjustable manifold referenced/ tach signal compressor rpm ramp up for the 1500 to 3000 range is better spent on the edits to the ECU that we'll have. I am thinking of a selector switch where one can chose ~40 ftlb/20hp or 50ftlb/35hp(with tune). That's easy. More to come. I'm thinking of getting one of these cars, the FA20 is a work of art! Rob |
#749 | |
That Guy
Drives: 2013 asphalt FRS MT
Rob, thanks for posting. I didn't realize you were reping the company, glad to have you in the community. How many deep cycles are the batteries capable? Is the controller capable to recharging more then two batteries? (I know the alternator also needs to be able to supply the current, I'm just asking about the controller. Any thoughts on the flow rate that could be achieved with a 36 volt system? |
#750 |
Some of us have the right background to be interested in experimenting with making our own controllers. Can you tell us what motor is used on these so we can do some research?
#751 |
Drives: Mazda 3
This is the ideal system for me as I drive 100% on the street and will have plenty of time to recharge the batteries between WOT runs due to speed limits on the streets. I'm very interested to see how partial throttle control develops and how many "steps" are provided between 0% throttle and WOT.
| The Following User Says Thank You to autobrz For This Useful Post: | NoFear99 (07-09-2013) |
#752 |
It doesn't look like there will be "steps". There are three states: off, full out, and running just fast enough to keep from becoming a restriction in the intake path. Fortunately the third state appears to have the added bonus of providing a slight amount of pressure pretty much at all times, which provides a noticeable improvement in throttle response.
| The Following User Says Thank You to mid_life_crisis For This Useful Post: | autobrz (07-09-2013) |
#753 | |
I want to reiterate that you don't step on the throttle and jet engine starts behind you at full thrust causing a "rough" ride. Its a FRS and when you go WOT it turns into a big V6 instead of a small 4 cylinder. It is very very smooth, nobody would think anything different driving with you in the car, once you go WOT it is a nice surge of torque
#754 |
Drives: it has 4 wheels and a motor
fenton what's next with this kit?
#755 | |
Drives: '13 GBS Subaru BRZ
My only concern would be people without the proper expertise trying to build one and causing harm to their car or worse themselves.
| The Following User Says Thank You to neutron256 For This Useful Post: | ML (07-09-2013) |
#756 | |
Drives: 2013 Scion FR-S, Nissan Pathfinder
Don't need to wait til high rpms for acceleration either, it just goes and it's not a sudden surge. Sent from my SGH-I727R using Tapatalk 2 |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
