Old 07-09-2013, 03:01 AM   #15
ft86me
ft86me's Avatar
Drives: 2013 FRS
@Brian@Vortech perhaps you might want to chime in on this
ft86me is offline   Reply With Quote
Old 07-09-2013, 03:26 AM   #16
Dezoris
Dezoris's Avatar
This was the noise I started hearing which maybe bearing noise from that pulley at this point.
[ame="https://www.youtube.com/watch?v=FgyYmguXMZQ"]FR-S Vortech Pulley Noise - YouTube[/ame]
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
Deepseadiver (07-09-2013), michaelosx (07-09-2013)
Old 07-09-2013, 03:31 AM   #17
Sniper2606
Sniper2606's Avatar
Same here.
So many headaches with this kit already
Whats the return policy on this anyways, cannot find it on the vortech page
Sniper2606 is offline   Reply With Quote
Old 07-09-2013, 06:13 AM   #18
cb7tuner
Drives: 2013 whiteout FR-S
I've PM'd him and I think he's aware of the situation, he's mostly involved in their social media and marketing so there's not much he can do himself. But I was asked to talk to a tech and that's where it went south for me. I explained what I found and what had happened, and the techs replys were very defensive and seemed to act as if it was my fault. I was asked to send my parts back to Vortech to be looked at to determine what would be done after that. But come to find out another member here that had the same failure as me contacted Vortech and with no questions asked already has another belt and pulley on the way to him. I feel like I've been given the run around and it could have been handled better for me.
cb7tuner is offline   Reply With Quote
Old 07-09-2013, 07:46 AM   #19
charged86
charged86's Avatar
My pulley is in perfect condition. It has barely brushed my intake pipe. I did feel nervous about that plastic pulley before install because it did wiggle.
I will say this some of these ground down pulleys "could" be installation error. I still have room to position the pipe higher on the the supplied bracket.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-09-2013, 07:48 AM   #20
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by Dezoris View Post
Thanks I really appreciate that! After staying away from modding for a long time, this car has certainly been a mix of both good and bad.
One thing is for sure if I can get through the bugs of I may start enjoying driving it more.
If you are driving the car during the winter do you have a battle plan for a blower heater for cold starts?
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 07-09-2013, 08:13 AM   #21
cb7tuner
I will say this some of these ground down pulleys "cold" be installation error. I still have room to position the pipe higher on the the supplied bracket.
My pulley has not touched anything, i don't even think the pipe could touch the idler pulley if I wanted it to. It's ground down because the belt has jumped from the idler wiggling (because bearings failed) and caused the belt to ride on the lip of the idler. Then causing the idler to act like a saw hacking up the belt and taking chunks of the lip with it. My pulley hasn't touched anything. Oh and mine was in perfect shape a few days ago as well.....then it happened. No way it could be installation error. The pulley is pre installed on the blower assembly (but every bolt was checked to be tight before installation like the instructions say to do so) and nothing was loose when I removed the bad parts. I'm an A&P licensed aircraft mechanic. I'm very methodical in my installations. Like I've already stated, its really not that big a deal to me because it was a cheap easy fix. I just don't like how the situation was treated in my personal case by vortech and I would like to warn others of potential future problems and where to get replacement parts with part #s
Old 07-09-2013, 08:34 AM   #22
DJCarbine
Thupercharged
DJCarbine's Avatar
Just checked my pulley/pipe clearance. No issues.
When I installed, I lifted the pipe before tightening the couplers/bracket for this exact reason
It looks like less from the picture, but there is a good 8-9mm of clearance between pulley/pipe
No rubbing
Also, all owners should check their pipe for rubbing... it took less than 2 minutes with a flat blade screwdriver and a 10mm wrench to pull the pipe and check.
The pipe DOES contact the hood insulation, but it doesn't really put pressure on the hood/pipe and only touches when fully closed.
I am changing the pulley for a dayco/Duralast pulley. I wonder what the mfr. of the pulley that comes with our system is....
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
charged86 (07-09-2013)
Old 07-09-2013, 08:48 AM   #23
cb7tuner
Dayco 89003 is the factory vortech part, its molded onto the pulley near the bearing when you remove it you can see it. I haven't been able to find another compatible brand of pulley yet
Old 07-09-2013, 08:55 AM   #24
DJCarbine
Thupercharged
DJCarbine's Avatar
How about the gates 38006? Its slightly wider, but its steel and the diameter and all other measurements seem to be the same minus the width.
Dayco 89003 Pulley
76mm x 17mm Flat w/Flange, 26mm wide
Gates 38006
Steel Smooth/Backside 76mm x 17mm x 30.5mm
Its listed as a cross-reference for the 89003, and looks like it will actually give more room than the dayco pulley because it does not have the "guide" ridges on the ends of the pulley
2013 FRS
Vortech V3 11psi
Old 07-09-2013, 09:11 AM   #25
DJCarbine
Thupercharged
DJCarbine's Avatar
Also are you guys removing the blower to change the belt?
It looks like with enough cursing, you don't need to.....
2013 FRS
Vortech V3 11psi
Old 07-09-2013, 09:15 AM   #26
nelsmar
Hmm I will check when i get back in town next weekend for other places i may be rubbing. I am at 1,500-2,000 miles and just checked my idler pulley. Looks perfect. I have a decent clearance and everything is completely centered between pulleys, brackets, etc. I just made sure to line that up when installing. However when i reinstalled the MAF up pipe i forgot to check for clearance. I will verify if maybe instead of rubbing against the pulley if i am rubbing against the chasis on the passenger side.
Although the thought of a potential belt issue is un-easy considering when i get back i have a ~1,500+ mile road trip in the car coming up.
My flickr - Canibeat
Local magazine scout
Old 07-09-2013, 09:20 AM   #27
cb7tuner
Dayco 89003 Pulley
Gates 38006
It may work but I'm unsure. Im hesitant on it without the ridges/lips though, I figure they are there for a reason. I also think the kit needs a slightly smaller belt to. After the upgraded compressors were released with the 9psi pulleys the belts were still never changed. So with a slightly smaller pulley I figure the tensioner isn't as tight. I think the gates belt is 98.110" long , maybe a 97.5" or 98" would be better
The Following User Says Thank You to cb7tuner For This Useful Post:
Old 07-09-2013, 09:21 AM   #28
skatery1989
Drives: BRZ Limited
I checked mine this morning. There's a little wear spot on the pipe but I notices if you make sure to push it in till it hits the throttle biddy it self there's alot more room. I do have to say I am disappointed in Vortech service latley I have been trying to contact the guy that sold me my kit for about two months now.
skatery1989 is offline   Reply With Quote
Kartboy Crank Pulleys 95.00 tom@kartboy Engine, Exhaust, Bolt-Ons 16 06-11-2013 01:06 PM
Crank,Alternator,Waterpump Pulleys etc..? fareastbrz Engine, Exhaust, Transmission 6 05-28-2013 08:46 PM
Titan Performance second batch of pulleys Amalgamo User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-30-2012 09:57 PM
