Old 07-07-2013, 02:35 AM   #15
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Got any side shots you can post of your car?
eSOLOR is offline   Reply With Quote
Old 07-08-2013, 02:03 AM   #16
Shinryu
Shinryu's Avatar
Drives: 2013 BRZ Limited
Are these modified at all? This is the first time I've seen them with illuminated side markers; those not lighting up was the main thing making me hesitant to buy them...
Shinryu is offline   Reply With Quote
Old 07-08-2013, 03:06 AM   #17
Panman
Panman's Avatar
Drives: 86 GTS
Hmm, my JDM market ones don't light up (not required here in Australia).
Panman is offline   Reply With Quote
Old 07-08-2013, 03:45 PM   #18
hamlet
Drives: blue brz, silver R8 5.2, orange s2K
Ordered mine.. now need to find a way to make the fronts come on w the DRL's
hamlet is offline   Reply With Quote
Old 07-08-2013, 09:25 PM   #19
DSOmegaX
DSOmegaX's Avatar
Mine are USDM ones and include the illuminated side markers. They're not as bright as the picture makes them out to be, but they are present.
@dsomegax.cars
Old 07-08-2013, 10:20 PM   #20
makalaka
makalaka's Avatar
Drives: 2013 Sonic, 2013 BRZ ltd
Did any of you remove the factory flasher? If so, how? I tried removing mine but couldn't get it to budge I ended up just leaving the new one hanging from the wire harness.
makalaka is offline   Reply With Quote
Old 07-08-2013, 10:23 PM   #21
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We have the USDM ones in stock as well. No re-pin is needed.
FT-86 SpeedFactory is offline   Reply With Quote
Old 07-16-2013, 08:54 PM   #22
kevin621
Drives: Subie
I checked Maxzone's fan page. They are giving away a free set of TOM's lamp by join their facebook event. Go check it out if any one interested.
https://www.facebook.com/DepoMaxzone...4973742&rest=1
kevin621 is offline   Reply With Quote
Old 07-17-2013, 08:38 AM   #23
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Link? I only see the JDM model listed.
edit: nevermind, I see in the details they are actually USDM tails. They're just listed as JDM in the title?
It's a bit confusing since the details list the following:
These are the USDM SPEC units. No re-pin is needed, simply install and rock!
TOM'S Tail Light Specs:
Bolts up to OEM locations
JDM Spec - No side deflector
Plug and Play
I guess that means the layout of the light is JDM, but the wiring is USDM? Not having that side reflector still keeps them DOT legal?
And plug-n-play, but we still need an LED relay so they don't blink hyperfast, right?
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 07-17-2013, 09:42 AM   #24
Foobar
SLO NO MO
Foobar's Avatar
Not sure if you figured this out eventually, but I had to shove a precision flathead screwdriver into the OEM relay's fastener claps, then pry it up so that it allows the clip on the harness to slide off.
LED Tail Lights Ryan86 AFRICA 13 11-20-2017 06:43 AM
TYC tail lights doggy Cosmetic Modification (Interior/Exterior/Lighting) 90 02-13-2014 03:03 AM
RED'ed out tail lights ! AJ PwR Cosmetic Modification (Interior/Exterior/Lighting) 17 07-02-2013 01:19 AM
Red tail lights are on!! eddieEndo Scion FR-S / Toyota 86 GT86 General Forum 24 06-23-2013 03:20 AM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 09:38 PM
