Old 07-07-2013, 02:46 PM   #351
EN2_Squirrel
EN2_Squirrel's Avatar
@Areddi what size is your front sway bar?
STREET MOD. My wallet now hates me....
EN2_Squirrel is offline   Reply With Quote
Old 07-07-2013, 02:48 PM   #352
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
He said he's running the Strano bar, which is 22mm hollow. This is the softest aftermarket FSB on the market (85% stiffer than stock)
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 07-07-2013, 03:02 PM   #353
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Anyone have a good idea on how much time difference there is between our stock nearly all season tires and a good set of max or extreme summer tires?
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 07-07-2013, 03:06 PM   #354
Areddi
Areddi's Avatar
Drives: Firestorm FR-S
The Strano bar is 22mm hollow.
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
Areddi is offline   Reply With Quote
Old 07-07-2013, 03:19 PM   #355
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
2-3 seconds
Scooby South is offline   Reply With Quote
Old 07-07-2013, 03:55 PM   #356
StormTrooper
I noticed load ranges on racing or extreme performance tires tend to be lower than standard....is this a problem? what kind of minimum range could we run on an otherwise stock car?
GR86 MT premium
Old 07-07-2013, 04:23 PM   #357
Areddi
Areddi's Avatar
Originally Posted by Areddi View Post
So here is a setup question:
Couple of bolt on's, stock suspension other than the Strano 22mm front bar, running on 225 ZII's on stock rims, in STX and am modding up slowly.
After installing the Strano bar I have loved it, really did a great job of combating the oversteer. I have found now that on some of the tighter courses I am running into too much understeer on the sweepers where I can carry some speed. I have played with tire pressures a bit, and still cant quite find something that I love, though something around 36 square has been good so far.
I thought about picking up the Perrin 16mm rear bar and running it on the softest setting (a 30% stiffness difference from stock) to try to dial back a bit of the understeer. What do you guys think? Good idea? Bad idea?
So thoughts anyone?
Old 07-07-2013, 04:28 PM   #358
Scooby South
Conedancer
So thoughts anyone?
You failed to mention what other mods you have. Yes a rear sway will help balance the car out a bit. Is it completely stock other than the front Bar. what is your alignment settings?? Camber???? There are lots of other variables other than just throwing bars on... .. but all the other stuff plays just as important roles to the balance of the car...and there is other ways, in combination, to achieve the overall goals.. Hope that makes sense to you. My first thoughts are, to throw a set of Koni's on it.. Then play with the rear bar.
Bill
Old 07-07-2013, 05:49 PM   #359
Areddi
Areddi's Avatar
Sure I thought I was clear in what I outlined, sorry if I caused confusion. Stock suspension is fully stock, including camber, etc. That is on the list of things to do as well. At this point, Koni's are also on the list, but that is a price challenge that may have to wait until next season. I guess my question is more in the sense of will changing to that slightly stiffer rear bar dial some of that understeer back out? Sound like it will and I have been thinking that it would. I need some guidance on tire pressure as well. As mentioned I have been playing with it, and just cant find something I am fully happy with. I am thinking going with the rear bar and sticking with my square setup might be the way to go, but I am open to suggestions!
Old 07-07-2013, 06:14 PM   #360
StormTrooper
I was told square or slightly lower in the rear starting at approx 38psi hot and going down from there....i'm sure it's dependent on the tires your using though.
GR86 MT premium
Old 07-07-2013, 07:28 PM   #361
apexaddict
Spend the money you would spend on the bar on camber bolts and alignment. Max camber up front (-1.2 or so), 0 toe front, and 1/8" total toe-in out back. Then run a few more events and see if your problem is fixed.
If the car is understeering, you want to make the front end of the car work better - putting a rear bar on is a band-aid at best, and in most situations, is not advisable, regardless of prep level.
Andrew P.
#14 STX Scion FR-S - powered by Stranoparts and Moto-East
apexaddict is offline   Reply With Quote
Old 07-07-2013, 09:40 PM   #362
knipple
Drives: 2013 Ultramarine Scion FR-S
For those asking about SP class, per the 2013 rulebook, under CSP is the following statement:
Sports cars under 2.0L not otherwise classified.
Per the owners manual, our engine is 1,998 cm3 < 2.0 L
Therefore, the FR-S/BR-Z is in CSP.
knipple is offline   Reply With Quote
Old 07-08-2013, 07:32 PM   #363
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I want to ask the lamest question in the thread...
I really wanna put a lip spoiler on the trunk, we all know this does nothing for aero performance but is someone going to protest this? I got thinking this because I saw an STR Miata this weekend with one.
Old 07-08-2013, 07:46 PM   #364
whataboutbob
AutoX-10/10ths every run
They could if you win, or just beat them.
Build thread:Here
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
