Drives: GBS BRZ Limited
Stainless Steel Brake Lines on a Daily Driver?
I'm about to take my brake calipers off to paint them with a G2 kit. While I have them off I was considering swapping out to stainless steel lines, probably the StopTech lines. Do you think it's worth it on a non-tracked car or should I save the coin?
#2 |
Drives: '13 DGM BRZ Limited
Go for it since you'll have to remove the line anyways. You'll get better brake pedal feel even on the street.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 4 Beta |
#3 |
Drives: dark grey metallic Toyota 86 MT
Better to change to ss lines. When I had my stock lines replaced with Goodridge lines the improvement was significant. I noticed that the ss lines have a smaller internal diameter. I guess this helps increase pressure and this is complemented by the ss reinforcement because the braided stainless steel prevents expansion.
#4 |
AIM4APX
Drives: 2013 WRB BRZ Limited
I've heard that SS lines do almost nothing on a car that already has such a good brake feel. I've read posts on here saying they are good, and some saying that their brake feel got worse when they put them on.
Rubber lines aren't just rubber, they have tensile material laid below the rubber to prevent expansion. On a 20 year old car, sure they will make a difference, but I would wager that going to a higher temp fluid, buying a MC brace, or buying better brake pads are all better investments than SS lines for a car built in the last year.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#5 |
Honestly, I haven't noticed anything wrong with the braking system. I figured since I was already taking the calipers out it would save time to just swap out. But for me, this probably would end up being only a cosmetic change.
#6 |
Boosted Member
Drives: 2013 SWP BRZ Limited
I am debating this as well. With Oregon summer weather (85 - 95F), will a SS line be necessary for occasional track events? Or just swapping the high temp brake fluids enough for it to not boil/melt the brake lines?
Also, if I get high performance pads, will the stock brake line hold up fine?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#7 |
SS lines aren't required. Rather, they're there to prevent long term degredation that the stock lines will eventually suffer.
We only stock Speigler lines for the FR-S/BRZ; they come with a lifetime manufacturer's warranty. [ame="http://www.youtube.com/watch?v=_lKokKLxt1M"]Spiegler Performance Parts Whip Test - YouTube[/ame] |
#8 | |
When In Doubt...
Drives: Slowww
Spiegler is well established in making brake lines for our two wheeled brethren. Apparently they're pretty strong too....
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#9 | |
![]() I personally change my brake lines every 100 on-track sessions or so on my S2000, but that car is underbraked, and brake line failures (at the crimp) from extreme heat cycling has been observed on the platform. We've been keeping an eye on our lines on the CSG BRZ, and they aren't seeing anywhere near the heat my S2000 does, so I'm going to say (for now) that they shouldn't ever need to be changed on a street car unless there is visible damage. Tracked cars should have the lines inspected regularly, but I don't forsee them needing regular replacement. |
#10 | |
Member of the year - 2016
Drives: Scion FRS
Listen, just do a better tire setting and pads, you'll be fine for a street set up.
#11 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
I'm installing SS lines on my car..
I recently did a track day at Mid-Ohio with Carbotech XP10 pads. One thing the XP10s do, according to Carbotech, is level off a bit when they get up to temp. This is to allow for greater modulation. When I hit that temperature point, I could really feel the "slack" in the braking system. So I want to eliminate as much of that as possible. I have installed a MC brace, but I'm not sure I can say it was a noticeable improvement. So SS lines are waiting to go on, and at the same time I'm going to upgrade to ATE Blue. We'll see how the pedal feel is on my next track day. |
#12 |
is better than you
Drives: 2013 raven FRS
ss lines are cheap like 100$ for both front and rear so might as well. But for a brand new car, i dont feel like you would need it.
#13 |
PROUD OF BOXER
Drives: Raven FR-S
chase bays are cheap - $80 and have the "L" fittings unlike other lines.
#14 | |
Driving Enthusiast
Drives: 2013 BRZ Limited
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.My BRZ |
| WTB: stainless steel brake lines for SCION FRS (front & back) | dcfr | Canada Classifieds | 2 | 04-03-2013 07:49 AM |
| Dynosty Stainless Steel Brake Lines $99 Shipped | Dustin@Dynosty | Brakes, Suspension, Chassis | 9 | 12-29-2012 09:56 AM |
| Goodridge Stainless Steel Brake Lines | LavosTRD | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-29-2012 06:37 PM |
| Stoptech Front Stainless Steel Brake Lines | Pekingduck | Brakes, Suspension, Chassis | 1 | 10-21-2012 10:29 PM |
| Stainless steel brake lines | taosracer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 09-20-2012 04:09 AM |
