Old 07-07-2013, 10:57 AM   #1
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
Stainless Steel Brake Lines on a Daily Driver?
I'm about to take my brake calipers off to paint them with a G2 kit. While I have them off I was considering swapping out to stainless steel lines, probably the StopTech lines. Do you think it's worth it on a non-tracked car or should I save the coin?
Skippman is offline   Reply With Quote
Old 07-07-2013, 11:24 AM   #2
cnk
Drives: '13 DGM BRZ Limited
Go for it since you'll have to remove the line anyways. You'll get better brake pedal feel even on the street.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 4 Beta
Old 07-07-2013, 11:40 AM   #3
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Better to change to ss lines. When I had my stock lines replaced with Goodridge lines the improvement was significant. I noticed that the ss lines have a smaller internal diameter. I guess this helps increase pressure and this is complemented by the ss reinforcement because the braided stainless steel prevents expansion.
andrewFT86 is offline   Reply With Quote
Old 07-07-2013, 12:49 PM   #4
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
I've heard that SS lines do almost nothing on a car that already has such a good brake feel. I've read posts on here saying they are good, and some saying that their brake feel got worse when they put them on.
Rubber lines aren't just rubber, they have tensile material laid below the rubber to prevent expansion. On a 20 year old car, sure they will make a difference, but I would wager that going to a higher temp fluid, buying a MC brace, or buying better brake pads are all better investments than SS lines for a car built in the last year.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
The Following 3 Users Say Thank You to Superhatch For This Useful Post:
ATL BRZ (07-08-2013), hmong337 (06-16-2014), strat61caster (07-25-2016)
Old 07-07-2013, 01:31 PM   #5
Skippman
Skippman's Avatar
Honestly, I haven't noticed anything wrong with the braking system. I figured since I was already taking the calipers out it would save time to just swap out. But for me, this probably would end up being only a cosmetic change.
Old 07-07-2013, 02:18 PM   #6
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
I am debating this as well. With Oregon summer weather (85 - 95F), will a SS line be necessary for occasional track events? Or just swapping the high temp brake fluids enough for it to not boil/melt the brake lines?
Also, if I get high performance pads, will the stock brake line hold up fine?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 07-07-2013, 03:06 PM   #7
CSG Mike
CSG Mike's Avatar
SS lines aren't required. Rather, they're there to prevent long term degredation that the stock lines will eventually suffer.
We only stock Speigler lines for the FR-S/BRZ; they come with a lifetime manufacturer's warranty.
[ame="http://www.youtube.com/watch?v=_lKokKLxt1M"]Spiegler Performance Parts Whip Test - YouTube[/ame]
new2subaru (07-25-2016)
Old 07-07-2013, 07:48 PM   #8
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
From personal experience, what is the longevity like on SS brake lines? I'm all about modifications that will reduce maintenance costs/time (more importantly time).
Spiegler is well established in making brake lines for our two wheeled brethren. Apparently they're pretty strong too....
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
SkAsphalt (07-08-2013)
Old 07-07-2013, 10:22 PM   #9
CSG Mike
CSG Mike's Avatar
Not too many people ride here... I think
I personally change my brake lines every 100 on-track sessions or so on my S2000, but that car is underbraked, and brake line failures (at the crimp) from extreme heat cycling has been observed on the platform.
We've been keeping an eye on our lines on the CSG BRZ, and they aren't seeing anywhere near the heat my S2000 does, so I'm going to say (for now) that they shouldn't ever need to be changed on a street car unless there is visible damage. Tracked cars should have the lines inspected regularly, but I don't forsee them needing regular replacement.
Laika (07-08-2013)
Old 07-07-2013, 10:25 PM   #10
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Eh? The only person seeing them would be you.
Listen, just do a better tire setting and pads, you'll be fine for a street set up.
Old 07-07-2013, 10:57 PM   #11
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I'm installing SS lines on my car..
I recently did a track day at Mid-Ohio with Carbotech XP10 pads. One thing the XP10s do, according to Carbotech, is level off a bit when they get up to temp. This is to allow for greater modulation. When I hit that temperature point, I could really feel the "slack" in the braking system. So I want to eliminate as much of that as possible.
I have installed a MC brace, but I'm not sure I can say it was a noticeable improvement. So SS lines are waiting to go on, and at the same time I'm going to upgrade to ATE Blue. We'll see how the pedal feel is on my next track day.
Old 07-07-2013, 11:39 PM   #12
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
ss lines are cheap like 100$ for both front and rear so might as well. But for a brand new car, i dont feel like you would need it.
bkblitzed is offline   Reply With Quote
Old 07-07-2013, 11:49 PM   #13
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
chase bays are cheap - $80 and have the "L" fittings unlike other lines.
supramkivtt2jz is offline   Reply With Quote
Old 07-08-2013, 12:39 AM   #14
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
F*** your 95F summer temps lol just giving you a hard time because im in Texas. Ive looked at SS lines but honestly probably the last thing id do for a DD unless you are looking for that little bit extra feel. bleeding the brakes and upgrading the fluid might give you all the extra feel you want or a MC brace.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
WTB: stainless steel brake lines for SCION FRS (front & back) dcfr Canada Classifieds 2 04-03-2013 08:49 AM
Dynosty Stainless Steel Brake Lines $99 Shipped Dustin@Dynosty Brakes, Suspension, Chassis 9 12-29-2012 10:56 AM
Goodridge Stainless Steel Brake Lines LavosTRD Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-29-2012 07:37 PM
Stoptech Front Stainless Steel Brake Lines Pekingduck Brakes, Suspension, Chassis 1 10-21-2012 11:29 PM
Stainless steel brake lines taosracer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 09-20-2012 05:09 AM
