Old 07-05-2013, 06:21 PM   #561
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by Dezoris View Post
Nice work, what are your boost readings usually under WOT at higher RPM is it typically close to 9?
I have to install it first but via data logs yeah just about man! I'll get the low down once I install the stuff
ft86me is offline   Reply With Quote
Old 07-05-2013, 10:31 PM   #562
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
Originally Posted by nelsmar View Post
You could just remove the brake
Booster tap that is included and get one with two barbs. As there is already a line going to the bypass valve. That or Y it out.
However you don't really need one to detect over boost as it is a belt driven compressor. Personally I have a p3cars vent guage (fa20club sells them) that replaces the oem driver vent with a half vent / half multi use display. It uses the obd port and just reads the OEM map sensor. No hoses required! I however don't use it for boost reading. Just oil temp but it serves for multiple functions and can be used for diagnostic purposes.
I have the p3cars vent guage as well. Just put it on today, took me about three minutes.
Now that I am reading boost, what is everyone seeing for maximum boost? I think I saw mine get to 6.5 psi.
On a site note, I just got my smaller pulley today, I wonder how much of a pain that will be to install.
Deepseadiver is offline   Reply With Quote
Old 07-06-2013, 12:38 AM   #563
Dezoris
Dezoris's Avatar
Do any of you guys know what the root cause of this one was?
[ame="http://www.youtube.com/watch?v=li3ZdciP-7o"]scion frs vortech noises - YouTube[/ame]
Old 07-06-2013, 01:11 AM   #564
DJCarbine
Thupercharged
DJCarbine's Avatar
At redline I see ~9-9.5psi
At 2-3k the gauge says I manage about 1-2psi
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 07-06-2013, 01:56 AM   #565
nelsmar
Woah! does this mean you found it or you are asking? I hear this sound @ ~ 3-4k rpm under lower throttle and sometimes light engine breaking. I think my car might have been making it NA as well though (I remember on the highway i would sometimes hear a chirp while cruising at normal highway speeds).
That almost sounds like a high pitched fluctuating bypass valve?
My flickr - Canibeat
Local magazine scout
Old 07-06-2013, 02:02 AM   #566
Dezoris
Dezoris's Avatar
I was trying to research the squeak I was having, and found that video.
Dont know if it was someone on here or not. When it stops sounds like high pressure fuel pump.
Old 07-06-2013, 04:03 PM   #567
charged86
charged86's Avatar
I think it was bad blower. It got taken care of at no charge to customer. And my autometer is dang close to reading 10psi. With stock 3.48 pulley. Hopefully will be my 3.125 pulley next week
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-06-2013, 10:02 PM   #568
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
So I finished up the install and for my first impressions:
Documentation sucked, but I used the rallysportdirect guide to help me along
10 hours start to finish install time (with breaks over 2 days)
Tuning is an interesting aspect. I was tired of getting mini answers / no communication with Visconti so I ended up buying a tune from FA20club as well.
Stock basemap vs stock basemap the fa20club tune pulls way harder than John's. Its a significantly noticable change, even my gf said it feels faster than yesterday.
I'm sending both data logs for updates today/tonight, will post back how it feels, and compare how long each takes to respond with a retune (pretty sure this right here will show who cares about the customers and who is done as soon as they have the money)
pheoxs is offline   Reply With Quote
The Following 4 Users Say Thank You to pheoxs For This Useful Post:
DJCarbine (07-06-2013), draggin_az (07-07-2013), Lonewolf (07-07-2013), nelsmar (07-07-2013)
Old 07-06-2013, 10:54 PM   #569
DJCarbine
Thupercharged
DJCarbine's Avatar
Very interested in the results
2013 FRS
Vortech V3 11psi
Old 07-07-2013, 01:56 AM   #570
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by Brian@Vortech View Post
We aren't underdriving the supercharger, we are leaving room for people to go more aggressive if they wish. If we maxed the compressor out right out out of the box, there would be no room for people to increase boost without changing the compressor. Whether doing so by raising rev limits, changing pulleys, etc., people will want to increase the boost. If we made a system with absolutely no boost upgrade, no one would buy it. Even if people have no intention of raising the boost, they still subconsciously need to know they can before they buy.
We made that mistake in the past on our Lexus IS300 system...as soon as people found out there was no pulley swap option for boost upgrade, it killed the sales of that system. Even though the system made great power out of the box, and there were other compressors they could have upgraded to, it didn't matter. That system was instantly D.O.A. We have the extra impeller speed buffer for that reason - so people can go a little more aggressive if they want without having to swap compressors. For those enthusiasts that want even more...we have that covered too, but will require a compressor upgrade (and we have lots of options there).
did you say...compressor..upgrade...? do tell about this compressor upgrade. id be very interested in knowing what you guys offer to step up the gains to the next level. thanks in advance!
Old 07-07-2013, 02:41 AM   #571
Dezoris
Dezoris's Avatar
Glad to see you finally got it done!!
Also if you dont mind can you email me your some of your logs you sent? I want to take a look compare to those I have.
You have any pictures? Initial impressions?
External oil system?
Old 07-07-2013, 02:45 AM   #572
ft86me
ft86me's Avatar
Drives: 2013 FRS
That's be fine by me haha
Old 07-07-2013, 02:48 AM   #573
Dezoris
Dezoris's Avatar
I think if you are boosting more than 12PSI it would be a cooling issue not to have am oil fed blower?
Don't think too many Vortech owners would go this high though.
Old 07-07-2013, 02:49 AM   #574
ft86me
ft86me's Avatar
Drives: 2013 FRS
True Hmmm daily and some spirited driving may be overkill
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
