Old 07-05-2013, 01:10 PM   #57
37
degrees
37's Avatar
Drives: 6MT BRZ
@bestwheelbase the US BRZ's head unit looks to be optional in the Impreza so there's a chance that other 2012/2013 Impreza head units will work. Scroll down a bit on this page to see the radio options: http://www.cars101.com/subaru/imprez...13photos2.html
I also asked before in this post but didn't get a reply. The quest continues.
37 is offline   Reply With Quote
Old 07-05-2013, 02:19 PM   #58
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
My 2013 has revised badging. I revised it right off the car.
Ganthrithor is offline   Reply With Quote
The Following 2 Users Say Thank You to Ganthrithor For This Useful Post:
KelvinBRZ (07-05-2013), Stierzy34 (07-05-2013)
Old 07-05-2013, 03:16 PM   #59
PMok
Codename: Stitch
PMok's Avatar
Originally Posted by modifier View Post
Agreed. It looks like a variant on the Impreza/Forester Premium trim (6 speaker) unit.
what does the PTY CAT button do?? bring out a Party Cat? A Puddy Tat?
The Following User Says Thank You to PMok For This Useful Post:
ftc~brz (07-31-2013)
Old 07-05-2013, 08:40 PM   #60
AznBRZer
Drives: 16 CBS WRX Limited
Program TYpe and Category.
AznBRZer is offline   Reply With Quote
Old 07-05-2013, 11:32 PM   #61
davidchoi
davidchoi's Avatar
Drives: BRZ - White Satin
Originally Posted by driftartist View Post
everyone keeps talking about the stupid knee pads....are you all old and have crazy joint problems? have you had knee replacement surgery? 1st world problems in my opinion. i just drive the damn thing.
amen
davidchoi is offline   Reply With Quote
Old 07-29-2013, 04:09 PM   #62
hernanBRZ
Chilean
Drives: BRZ '13 + Civic Coupé '96
Originally Posted by bestwheelbase View Post
@hernanBRZ what is the part number for that head unit? I would totally swap that with the USA version. Those buttons look very easy to read and reach.
where is the part number written?
in the back? in the front?... any example?
hernanBRZ is offline   Reply With Quote
Old 07-29-2013, 04:23 PM   #63
Ingen
Drives: Ultramarine FR-S 6MT
Originally Posted by GNS View Post
No, you misunderstand. The knee pads are FOR the driver and front passenger, not for the car.
What, for when the dealership bends them over with random fees and a lack of test drives?
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
The Following User Says Thank You to Ingen For This Useful Post:
Old 07-29-2013, 11:25 PM   #64
Cameronghanson
Drives: n/a
Soo...does that mean this is the STI
Cameronghanson is offline   Reply With Quote
Old 07-30-2013, 12:12 AM   #65
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
I must be the only one who actually likes the radio.
The stereo sounds great after installing an 8" sub and adjusting the equalizer settings according to this:
http://img.tapatalk.com/d/12/12/13/ta4y8y8e.jpg
As far as using the touch screen, I have no problem pushing the buttons while I'm driving. I rest my wrist on the stick shift and my finger reaches the screen just fine and is stable.
I know there are way better options out there, but I don't think the Fujitsu is as horrible as most make it out to be.
ericmpena is offline   Reply With Quote
The Following User Says Thank You to ericmpena For This Useful Post:
sprintertrueno86 (07-31-2013)
Old 07-31-2013, 01:00 AM   #66
Boil
Drives: CX500 Cafe Bobber
I say Subaru just needs to do two things to improve the audio/sat nav in the BRZ…
Make an OEM Audio Plus Reference 500 (designed for the BRZ) system standard, and for a head unit, an Apple iPad mini…!
The iPad mini would be (easily) removable, yet totally secure while one was experiencing a bit of 'spirited driving'…
An integrated iPad mini could also be used for digital gauges…
…and OpenTablet…!?! Could that be somehow made to function thru an iPad mini?
Boil is offline   Reply With Quote
Old 07-31-2013, 08:08 AM   #67
Be-Are-Zee
You might be the only one. The stock sound is horrible at any EQ setting.
The real reason I am responding is to let you know you shouldn't rest any weight on your stick shift. This added weight causes wear on the syncros and eventually that gear will be useless.
Be-Are-Zee is offline   Reply With Quote
Old 07-31-2013, 08:14 AM   #68
Boil
So where would that leave folks who are using weighted shift knobs…?!?
Example - Anarchy Motive Mammoth XS @ 671g (1.47lbs)
Old 07-31-2013, 08:16 AM   #69
Be-Are-Zee
I'm not sure. I'm also not sure how much weight causes the issue but I've heard of hands resting on the stick causing long term wear so a hand is heavy enough.
Old 07-31-2013, 08:21 AM   #70
SigmaHyperion
Drives: 2013 SWP BRZ Limited
The difference is in how the weight is placed on the stick.
Weight that is straight vertically down won't affect anything at all -- hence why shift knobs of whatever form are fine.
However, when you rest your hand on it, the weight is never completely vertical. You are very slightly pulling the stick one way or another (usually back and left) and potentially engaging a synchro would could over time wear it out.
SigmaHyperion is offline   Reply With Quote
Passenger side HID Ballast keep blowing CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 3 04-13-2013 12:13 PM
Did the issue with the air vents blowing hot ever get resolved? fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 25 09-05-2012 01:21 AM
A/C Compressor blowing hot? Is this normal? SocalBurt Engine, Exhaust, Transmission 3 08-22-2012 07:10 AM
Ideas of making FR-S with BRZ model features ngabdala Scion FR-S / Toyota 86 GT86 General Forum 23 04-29-2012 11:19 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 07:16 AM
