Old 07-05-2013, 12:55 PM   #617
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by mid_life_crisis View Post
Like making ice in the basement of a skyscraper at night when the electricity is cheaper instead of running the AC all day.
why do you post?
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 07-05-2013, 01:18 PM   #618
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by carbonBLUE View Post
why do you post?
What's your problem? You described storing electricity when it's cheaper and the demand is reduced and I gave a simple example to indicate I got the point.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 07-05-2013, 01:34 PM   #619
mid_life_crisis
Originally Posted by CBR600RR View Post
ya I think I read something about that - the computer reads that there is over 5psi or something and throws a CEL?
I think this is the post you were looking for.
It appears i may have reached the limits of a NA tune, going WOT at VERY low RPM's causes (P0108 - MAP Pressure Circuit High Input).
It seems the map i am running may know that 4.6psi is not what it is suppose to see.
Last edited by mid_life_crisis; 07-07-2013 at 06:24 PM. Reason: Corrected incorrect answer
Old 07-05-2013, 01:52 PM   #620
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm sure I saw a post from one of you northerners griping about the gas. Does the availability of high octane vary from province to province?
Does it vary from state to state?
Do you realize that me and Fenton have never met and that we live ~5000 kms (3000 miles) from each other? And that neither of us are at a far east or west end of our country?
Old 07-05-2013, 02:19 PM   #621
Wild Weasel
Wild Weasel's Avatar
Drives: 2001 Sunfire GT + 2007 Mazdaspeed3
FWIW, everyone else in the country considers you to be at the far east.
Wild Weasel is offline   Reply With Quote
Old 07-05-2013, 02:59 PM   #622
mid_life_crisis
Yes, but that doesn't mean you guys have the same problem.
Didn't notice either point, and don't understand what they have to do with my not knowing what gas is available in Calgary.
Old 07-05-2013, 04:13 PM   #623
Robftss
Drives: VW
Originally Posted by Dodzilla View Post
Looking great! Did you log IAT at all? I wonder how hot it gets at these boost levels.
Today:
Base intake temp: fairly stable 81F.
Several low rpm 3.5- 3.8 psi pulls, peak 132 F
Several high rpm pulls 1.25 - 2 psi, peak 104 F
Ambient 65F.
Vehicle: 2012 4.3L V6
Device: small LCD temp display (~0.5 second rate).
Fenton's will be the same.
Robftss is offline   Reply With Quote
Old 07-05-2013, 04:43 PM   #624
rx3
Good point. You could actually also produce ice (at low power demand) for an intake-air-cooler which you would then only use at full throttle (denser air and more aggressive timing).
These guys were able to almost double the torque with a cold intercooler:
http://www.are.com.au/Big%20HP/Dry%2...%20cooling.htm (dry ice though).
rx3 is offline   Reply With Quote
Old 07-05-2013, 05:52 PM   #625
the_butcher
Drives: 2013 Scion FRS
I'm not much at reading dyno graphs yet.. noobish I know. Did this match/beat/compare to the vortech kit?
the_butcher is offline   Reply With Quote
Old 07-05-2013, 07:10 PM   #626
Dodzilla
Drives: 2013 Subaru BRZ
Thanks for the info.
I wonder at what point some water injection or intercooling becomes necessary... it's more like 110F ambient here
Ambient 65F.
Dodzilla is offline   Reply With Quote
Old 07-05-2013, 07:13 PM   #627
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Interesting build, kinda neat.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 07-05-2013, 07:14 PM   #628
unijabnx2000
unijabnx2000's Avatar
Drives: Nissan
I might have to throw one of these on my Cobalt and Versa also
unijabnx2000 is offline   Reply With Quote
Old 07-05-2013, 07:32 PM   #629
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
If these take off like I hope they do, I might have to throw one on everything with an engine and alternator. I'd be pumped to see 5psi till redline. Wish I had a MAP, ESC, and motor laying around. Might get bored and tinker till the FRS specific kits are production ready.
Edit: I'm bored. Went ahead and ordered parts.
Old 07-05-2013, 07:33 PM   #630
Robftss
Drives: VW
Fenton 168HP 205.7HP 37.7HP
Fenton 131 ft-lbs 185 ft-lbs 54 ft-lbs
Note: This is just comparing output, stands to reason with the base being similar...so are the gains.
Of course, again, this system behaves more like nitrous with a refill function. But it is overall far simpler.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
