Old 07-01-2013, 11:52 AM   #29
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by whitefrs View Post
So having a filter is ok?
Because you have the vacuum line connected off the back of the manifold a filter is NOT ok. You either run it as a closed system or you run it as a vented system. The best solution to run the can as intended is to T off the vacuum line on the back of the intake manifold and run it to both of the ports on the can. Just remember that once you accelerate and hit boost there is no longer any vaccum being created to pull out the oily gasses so essentially the can becomes pressureized at that point. With a vented can it never sees vacuum or boost so it performs the same all the time.
Sportsguy83 (07-01-2013)
Old 07-01-2013, 12:05 PM   #30
mad_sb
Drives: 2013 Asphalt FR-S
I know you and I are on opposite side of the fence about open vs closed systems.. but I think we both agree that the way he currently has this plumbed is creating both a vacum leak and a boost leak since he has the port on the intake manifold connected right?
Old 07-01-2013, 01:47 PM   #31
Gen
Drives: Scion FR-S
4 engines??? Holy shit
Just what the local shops are reporting, but who knows, really. A lot of stuff goes on that never makes it on this forum, but don't take it as gospel.
Gen is offline   Reply With Quote
Old 07-01-2013, 02:18 PM   #32
King Tut
NASA SpecE30 Racer
King Tut's Avatar
We are in agreement.
Old 07-01-2013, 03:38 PM   #33
FullBlown
FullBlown's Avatar
Drives: Scion FRS
we always vent to atmosphere without a problem
FullBlown is offline   Reply With Quote
The Following 3 Users Say Thank You to FullBlown For This Useful Post:
GsxrMe (10-14-2015), IBill4You (07-21-2015), whitefrs (07-02-2013)
Old 07-04-2013, 12:53 AM   #34
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
They don't have any diagrams of the inside of the can so it's difficult to tell for sure how you need to connect it with a boosted application.. but i am guessing, since any oil caught is supposed to drain out the bottom port, the can has no internal separation and as a result it's not doing anything good in the current configuration.
Fairly sure the way that is plumbed right now you are sucking unmetered air into the intake manifold when off boost and blowing metered air our the when under boost. That may be part of the reason your fuel trims are all over the place.
For the time being, you should take the can out of the equation and put the system back like it was before you installed the can.
For that can to work properly it needs to be a closed system. You will need a bung pre turbo (as others have said) to connect to the port that is open. you also want a good check valve between the can and the intake manifold port so it will not pressurize the can under boost pressure. The stock pcv valve is on the block side so as soon as you go in boost the charge is filling the can and running out the open port and back into the block on the connected intake side port.
I honestly think you would be better off with 2 separate 2 port cans and a couple of crankvents (http://www.et-performance.com/automotive.html)... the idea draining the caught nasty back into the oil system is.. well... nasty.
This is wrong I tested mine by pressuring it. the top and bottom are separate.
Gregg
jdzumwalt is offline   Reply With Quote
Old 07-04-2013, 08:53 AM   #35
mad_sb
Gregg
Top and bottom what? Ports on the can?
EDIT: Maybe the can is actually completely divided inside making 2 independent paths with no cross over (I think that is what your saying right?), in which case oil would drain back via the pcv valve and the port under the AC compressor.
Personally, i would rather pay more for 2 independent cans that do not put the captured oil back into the system, but that topic has been beat to death already.
Old 07-04-2013, 09:32 AM   #36
jdzumwalt
Motor Sports slut
Yes it is separate. This allows for both bottom ports to drain back into the block. These things work and they work well.
Old 07-21-2015, 12:33 PM   #37
IBill4You
Drives: 2015 Subaru BRZ
Until someone shows me gains when pulling vacuum on the crankcase, then I will stick with vented. I don't want that oily air going through my engine.
Hey King Tut, did you ever see those gains or still running V2A?
IBill4You is offline   Reply With Quote
Old 07-21-2015, 08:12 PM   #38
King Tut
NASA SpecE30 Racer
King Tut's Avatar
There are no gains. I sold the car with the V2A, and I have a V2A on my turbo S2000 now.
Old 07-21-2015, 08:29 PM   #39
mrk1
Drives: Sterling BRZ Ltd
I have been running vent to atmosphere on a custom separator for over a year. Yes it smells and requires the maintenance of draining the can but that's a compromise I'll make. I want to keep my pistons clean and that crud out of the motor. There are way to many big power builds with VTA cans for it be a detriment to power.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Old 10-13-2015, 12:41 PM   #40
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Boom, resurrection!
I guess I am missing something. I dont understand why the top port of the intake manifold would be used here if you are boosted. Wont you be boosting the catch can here? I dont see a check valve. Would plugging that port on the intake manifold and running the AOS line to a port pre turbo be a better solution?
xkalelx is offline   Reply With Quote
Old 10-14-2015, 06:32 PM   #41
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Always make sure you NEVER give the crankcase boost or you'll be in the market for a new motor. Doesn't matter if its a BRZ, Motorcycle or a lawn mower.
If you don't like the smell, Run hoses pointing down or something. Catch cans are great if you care about the earth.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
xkalelx (10-19-2015)
Crawford Edition FRS??? CAMBAM_6 Scion FR-S / Toyota 86 GT86 General Forum 11 06-23-2013 07:36 PM
Crawford Air / Oil Separator - 13+ BRZ/FRS/GT-86 ngabdala Engine, Exhaust, Bolt-Ons 11 06-10-2013 09:22 PM
FS: Crawford AOS xwd Engine, Exhaust, Bolt-Ons 6 04-07-2013 07:44 PM
Need help Crawford AOS install ngabdala Engine, Exhaust, Transmission 19 11-21-2012 08:04 AM
