Old 06-27-2013, 09:13 PM   #57
Raceseng
Raceseng's Avatar
Originally Posted by wparsons View Post
I didn't see this question asked yet, do these require any trimming of the strut towers to work? I know some plates on some cars require trimming the tower to get any adjustment range.
No trimming, completely direct bolt in.
Raceseng is offline   Reply With Quote
The Following User Says Thank You to Raceseng For This Useful Post:
wparsons (07-05-2013)
Old 07-03-2013, 11:16 PM   #58
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
Any guesstamate on when these plates might be available?
Overland'n'5thGEN is offline   Reply With Quote
Old 07-05-2013, 09:37 PM   #59
Raceseng
Raceseng's Avatar
It is going to be 4-6 weeks till we are ready to manufacture them. I have a little bit more development work to do yet but everything is looking good.
The Following 2 Users Say Thank You to Raceseng For This Useful Post:
Overland'n'5thGEN (07-06-2013), whataboutbob (11-01-2013)
Old 07-05-2013, 11:53 PM   #60
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
beautiful!
Old 07-06-2013, 11:42 AM   #61
Raceseng
Raceseng's Avatar
Originally Posted by solidONE View Post
beautiful!
Thank you!
Old 08-10-2013, 07:26 AM   #62
Pvt AJ
Pvt AJ's Avatar
Drives: Toyota 86 GTS
Im really liking the effort and quality put into these top mounts. it makes me confident to buy from you when these will be released. Ill be keeping a close eye on this so i purchase them in the near future when i get my coilovers. keep up the good work jarrett.
Pvt AJ is offline   Reply With Quote
The Following User Says Thank You to Pvt AJ For This Useful Post:
Raceseng (08-14-2013)
Old 08-11-2013, 09:33 AM   #63
kahox
Drives: 2013 FRS, 2010 Evo X GSR
Sub'd
You can't rush perfection. I'll patiently wait for these for my kw v3 if the price is right
kahox is offline   Reply With Quote
The Following User Says Thank You to kahox For This Useful Post:
Old 08-12-2013, 12:49 PM   #64
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I spent a few minutes oogling over the prototypes on Simmons' car at the Toledo Pro. Very solid design, functionally beautiful piece.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
The Following 2 Users Say Thank You to Sccabrz192 For This Useful Post:
Raceseng (08-14-2013), whataboutbob (11-01-2013)
Old 08-13-2013, 11:16 AM   #65
SACHMO
Drives: black
WOW!
Been looking at all of the options. These are beautiful.
What is the max camber expected?
SACHMO is offline   Reply With Quote
The Following User Says Thank You to SACHMO For This Useful Post:
Old 08-13-2013, 01:41 PM   #66
Raceseng
Raceseng's Avatar
More then you could ever need! Just kidding, in all seriousness I'm making some changes to try and get a degree or 2 more out of the bearing housing in plate. When production is done I plan on going to the alignment rack to get true on car max caster/camber ranges!
I plan on finalizing the CC plate design in solidworks tomorrow, then its time to order material for production!
Old 08-13-2013, 02:30 PM   #67
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
make them compatible with stock struts please
mechaghost is offline   Reply With Quote
Old 08-13-2013, 02:39 PM   #68
Raceseng
Raceseng's Avatar
That is the plan! As of right now, our priority is to make them available for aftermarket coil over systems.
Old 08-15-2013, 01:31 AM   #69
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I seriously may wait for coils, just so I can get these front and rear plates and do it all at once and do it right, man these look great!!!
Old 08-15-2013, 09:02 AM   #70
Raceseng
Raceseng's Avatar
Means a lot! Thank you!
billet, billet aluminum, caster adjustment, caster camber plate, raceseng
Tein Flex Z Coilovers Evasive Motorsports Brakes, Suspension, Chassis 54 07-16-2017 01:21 AM
Raceseng | Billet Aluminum Engine Pulleys Raceseng Engine, Exhaust, Transmission 174 07-24-2014 12:24 AM
Raceseng | Lightweight Billet Aluminum Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 13 08-27-2013 01:48 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
SRP Billet Aluminum Door Sills pedalpusher Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2012 06:44 PM
