Old 07-02-2013, 01:45 PM   #15
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by loogs View Post
looked easy enough up until the pin thing. now i need to find someone to do the install cause i just dont get it
you have to depin the wires out of the clip, and re-arrange them.
These tails are super nice. If I didn't paint my stock ones i'd be all over these.
xxscaxx is offline   Reply With Quote
Old 07-02-2013, 02:15 PM   #16
loogs
Drives: on cruise control
exactly, what the hell does that mean?
loogs is offline   Reply With Quote
The Following User Says Thank You to loogs For This Useful Post:
Alltezza (04-11-2016)
Old 07-02-2013, 02:23 PM   #17
xxscaxx
exactly what it reads. You need to remove each wire out of the back of that clip shown, and move them into a different spot.
If you don't know what de-pinning is, just google it.
The Following User Says Thank You to xxscaxx For This Useful Post:
loogs (07-02-2013)
Old 07-02-2013, 04:13 PM   #18
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
That is correct. And really it is super easy. Takes just a few minutes to get the pins(wire ends) out of the harness plug, then you just slide the wires into a different spot in the harness plug and you are good to go. I am working on something that should make this a bit more clear as well
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 07-02-2013, 04:42 PM   #19
swift996
swift996's Avatar
Originally Posted by RallySport Direct View Post
Thanks!!! And I know the feeling haha.
We also just posted up a video we made
Thanks,
Rick
Looks awesome. Once I get my innovate supercharger installed/tuned and my water/meth running I'll be on these. They look so nice and would complete my car's exterior aesthetics. I just ordered $500 in brake pads this morning...I'll have to reload my car fund savings first.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-02-2013, 05:03 PM   #20
loogs
Thanks,
Rick
looking forward to this cause im clueless with this stuff
what wheels are those on the BRZ/ FR-S in your sig?
Old 07-02-2013, 05:13 PM   #21
swift996
swift996's Avatar
ESM 004s
Old 07-02-2013, 05:29 PM   #22
Bignicky1
Drives: Slowww
will these pass inspection?
Bignicky1 is offline   Reply With Quote
Old 07-02-2013, 06:53 PM   #23
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Is it possible to re-pin the tail light harnesses instead? I'd be more comfortable doing the lights so the car's harness stays the same and avoids confusion in the future (ie no need to re-pin back to USDM if switching back to old lights, etc.)
Old 07-02-2013, 08:37 PM   #24
RallySport Direct
Nice! Really a great way to set off the back of this car. The stock tails leave much to be desired
Sounds good, I will let you know as soon as we get them up
I doubt it, they do not have a DOT stamp on them and they do not have the required reflector to meet U.S. specifications. However they look OEM, so they may not even be questioned. Always play it safe though, just in case
This is a great question that I did not touch on. The Tom's harness/plug has a glue/sealant that you would have to remove first before you could re-pin the harness plug. It is possible, but would take a bit more work to get it done.
Thanks guys!
Rick
The Following User Says Thank You to RallySport Direct For This Useful Post:
BigFatFlip (07-02-2013)
Old 07-02-2013, 08:45 PM   #25
loogs
wait. pass inspection where? i thought as long as you dont trigger a check engine light, you pass inspection. im in new york so is it different somewhere else or the same
Old 07-03-2013, 11:16 AM   #26
Bignicky1
Drives: Slowww
Im in NY too, I just dont want to bring it for inspection and fail over this .... but i know people to just "pass me"...
Old 07-03-2013, 03:22 PM   #27
loogs
yeah ill probably pass on the Toms and get some other brand. too many issues
Old 07-03-2013, 04:10 PM   #28
Bignicky1
Drives: Slowww
I will prob too, with the whole repinnin of some wires. But these are THE best looking taillights
SOCAL INSTALL AND SELL-- HID KITS--LED LIGHTS--REVERSE LIGHT--PAINT TAILLIGHTS!! F-T Exterior Parts - Lighting 202 03-21-2016 03:02 PM
FS: FRS/BRZ Red OEM taillights 86design Exterior Parts (Aero, Lighting, Etc.) 4 06-26-2013 07:34 PM
New taillights youngy AUSTRALIA 7 04-14-2013 07:16 AM
Taillights idea adprokid Cosmetic Modification (Interior/Exterior/Lighting) 25 09-16-2012 01:40 AM
