Old 07-01-2013, 05:35 PM   #29
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
@Gen Gad to see your making good progress.
Keep us on the up n up.
Originally Posted by FullBlown and adjusted by Floggin tires View Post
We just did a complete turbo install on a customer car that made
304hp @10 psi on 93 pump.
400hp @16 psi on e85 (Fckn Corn!)
I will post up the whole build shortly.
All BS aside, sounds sweet.
Looking forward to it.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 07-01-2013, 05:38 PM   #30
Floggin Tires
I have grown less confident in either of those dyno plots being correct due to RPM pickup issues.
Getting perfect RPM reading can be so picky/irritating at times.
ZC6-CBS, is home
Old 07-01-2013, 05:39 PM   #31
jamesm
Originally Posted by Gen View Post
Quite honestly, I think the numbers people think it makes aren't realistic.
Here's King Tut's Dyno on 93
Considering it's on a dynojet with better fuel, that's damn near identical.
This was his 14psi run.
That's dyno only goes up to ~6400rpm lol
Old 07-01-2013, 05:58 PM   #32
FA20Club.com
Drives: 2013 White Out FR-S
I would not quote my numbers. As time has gone on, I have grown less confident in either of those dyno plots being correct due to RPM pickup issues. The RPM scale is not correct for either pull that was collected. I will have new dyno plots after July 12th.
if thats the case you can just read the runs as mph instead of engine speed.
FA20Club.com is offline   Reply With Quote
Old 07-02-2013, 07:52 AM   #33
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
217
For what it's worth, it read 155 at the wheels before addressing the fuel pump. The original installer followed the instructions on the install to a T, complete with zip ties. (not being sarcastic) It's now much more secure.
Yes sir, the fuel pump install can be a pain in a big ass.
Here's a compilation of what I've learned in the last few months of it.
http://www.ft86club.com/forums/showthread.php?t=33993
Old 07-02-2013, 02:19 PM   #34
Gen
Drives: Scion FR-S
Yes, the original zip ties the installer used started to dissolve. Zip ties aren't really the best for orienting the pump correctly either.
Gen is offline   Reply With Quote
The Following User Says Thank You to Gen For This Useful Post:
Sportsguy83 (07-02-2013)
Old 07-02-2013, 02:48 PM   #35
mad_sb
Drives: 2013 Asphalt FR-S
Mustang dyno after addressing some issues with the original fuel pump install and sealing the turbo. I don't advise following the instructions that are sent with the kit for the pump.
Much better, you have a couple things working against you at this point...
1. 91 octane
2. Factory exhaust (lots O back-pressure)
Free up the exhaust and you will pickup spool as well as the ability to run a little more timing up top.
Corn Juice will also help if it's available
Old 07-02-2013, 03:32 PM   #36
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
We made 290 wheel hp recently on stock exhaust with a base kit and manual boost controller.
Pure Automotive is offline   Reply With Quote
Old 07-14-2013, 09:05 PM   #37
Gen
Drives: Scion FR-S
1. 91 octane
Ehh...I'm starting to think I have more working against me now. Bob put down 216 (91 octane) with his innovate kit today on the same dyno. His power train is stock other than a catback, but he also still has both cats.
whataboutbob (07-15-2013)
Old 07-15-2013, 11:28 AM   #38
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The best thing to do is get that thing on a Dynojet with at least AFR logging and hopefully boost logging and get some real SAE corrected numbers. Then we can see what the car is doing and see if your making the correct boost numbers and the AFRs are where they should be. If you want to do some datalogs, I will take a look and compare to my car.
Old 07-15-2013, 11:38 AM   #39
mad_sb
Have you checked your cat to make sure it's intact? I saw someones thread where they melted one or both of them.. don't recall who's.
Old 07-15-2013, 11:45 AM   #40
xjohnx
Grip>Slip
xjohnx's Avatar
was that @CSG Mike when he had the DI failure?
Old 07-15-2013, 11:51 AM   #41
CSG Mike
CSG Mike's Avatar
Our cats were damaged due to the engine running ultra lean... there were no modifications to the drivetrain except for an axleback (muffler replacement). IMO, completely unrelated to FI, but I'll be more than happy to answer any questions.
xjohnx (07-15-2013)
Old 07-15-2013, 12:04 PM   #42
Gen
Drives: Scion FR-S
Exhaust system is the only thing left I can really think of. Was going to check the cat out this week, but it doesn't seem to be an issue at first glance.
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Compilation of Dyno results somewhere??? Scooby South Engine, Exhaust, Transmission 3 01-08-2013 06:51 PM
Pocket Dyno App Results CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 14 09-12-2012 10:45 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 10:15 PM
