Old 07-02-2013, 02:40 PM   #1
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Which lowering springs compatible with OEM shocks?
I know Race Comp makes the yellows that are matched to the stock shocks. But are there others? Please share if you know of any.
Thanks.
hmong337 is offline   Reply With Quote
Old 07-02-2013, 02:45 PM   #2
waterbison777
Swift
waterbison777 is offline   Reply With Quote
The Following User Says Thank You to waterbison777 For This Useful Post:
hmong337 (07-03-2013)
Old 07-02-2013, 03:31 PM   #3
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Eibach make two versions most common the Pro kit which is a 7/8th - 1" drop. Swift as mentioned, Hotchkis as well, all work well and have plenty of reviews and discussions here for sure.
The Following User Says Thank You to OICU812 For This Useful Post:
Old 07-02-2013, 03:46 PM   #4
hmong337
Emperor JDM
hmong337's Avatar
Okay. Like with many aftermarket lowering springs, you usually have to pair them with aftermarket shocks. I thought the Eibachs would need harder damped shocks..? From what I have searched so far, the Race Comps seem to be the only ones that come out and tell you upfront that they were designed with the OE shocks in mind. I would hate to blow out my OE shocks from a mismatched aftermarket spring. I think Tein is the other one that makes OEM compatible springs.
Old 07-02-2013, 07:52 PM   #5
Panman
Panman's Avatar
Drives: 86 GTS
STI Pink springs - That's what I have and am very happy with them and it's OEM+
Panman is offline   Reply With Quote
Old 07-03-2013, 12:08 PM   #6
Excelerate
Excelerate's Avatar
Drives: Crystal Black BR-Z Limited
We recently just sold a set of H&R Super Sport Springs to a customer, and although H&R doesn't say that they are specifically designed for OEM springs, the customer really liked them. He noticed the ride was a little stiffer, but nothing too crazy and he said it definitely improved the handling. It's a moderate drop and really improved the overall look of the vehicle. Most of these cars don't have a lot of miles on them so you should still get a fair amount of life out of the shocks. Granted they will make them go a little quicker, but you should still see a decent life span.
Excelerate is offline   Reply With Quote
Old 07-03-2013, 12:15 PM   #7
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Same goes for the TRD ones.
Guillaume is offline   Reply With Quote
The Following User Says Thank You to Guillaume For This Useful Post:
Old 07-03-2013, 12:58 PM   #8
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Hotchkis springs work very well with the OE dampers. They also work great with Koni shocks if you decide to upgrade.
Nitro22 is offline   Reply With Quote
The Following User Says Thank You to Nitro22 For This Useful Post:
Old 07-03-2013, 01:38 PM   #9
Opposed
Drives: 2013 Asphalt FR-S
Agreed! I love my Hotchkis springs! They ride great. You actually can't really tell a difference over OEM.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
The Following 2 Users Say Thank You to Opposed For This Useful Post:
hmong337 (07-03-2013), Hotchkis (07-03-2013)
Old 07-03-2013, 06:24 PM   #10
Ryuu0u
(=^・ェ・^=)
Ryuu0u's Avatar
Drives: 2013 FRS, '08 GSXR 600
I kinda want to know who has the hotchkis kit that comes with all the sway bars and such. Is it worth it in terms of handling?
Ryuu0u is offline   Reply With Quote
Old 07-03-2013, 06:32 PM   #11
Panman
Panman's Avatar
Drives: 86 GTS
Not all TRD (JDM) springs fit with OE shocks. I went with the STI springs for that reason. The new ones which do work with OE shocks (Sportivo) weren't available when I got my springs.
Old 07-03-2013, 06:41 PM   #12
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
All these companies can say this and that but at the moment, no one really knows what really works well with the shocks. Only time will tell, but from what i keep reading, the Swift shocks are very close to stock in terms of feel and ride, which might mean nothing but sounds like a best bet. In terms of rates...
The yellows get great reviews but they seem to be quite harsher then stock set up.
Ideal set up would be Koni shocks and yellows (or other springs) if your worried about OEM shocks.
The average for your lowering your car with springs on stock shocks is about a year or so of aggressive/spirited driving intill you'll start to feel a loss in responsiveness, IMO.
Old 07-08-2013, 01:14 AM   #13
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Mach V Springs feel very good with the stock strut, i have it since 1 month now maybe more and i love it.
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 07-08-2013, 04:07 PM   #14
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I have Eibach Pro kit. certainly stiffer than ever before BUT less role and dive. I love it. Also more predictable when I break traction
Cusco products, Swift Springs and <Koni Shocks/SPC rear camber kit> b2autodesigns Brakes, Suspension, Chassis 713 09-11-2017 01:03 PM
FS: OEM springs and shocks Bcarlos Brakes, Suspension, Chassis 7 01-19-2014 03:58 PM
Oem shocks and springs Jhon19lopez Brakes, Suspension, Chassis 3 05-20-2013 05:33 PM
Springs & Shocks: Which to Buy? GhostofAkina Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 03-11-2013 02:16 PM
TRD Springs on std shocks? Panman AUSTRALIA 3 02-14-2013 03:59 PM
