Old 07-01-2013, 06:52 PM   #1
Hanakuso
Oil coolers that will fit with the TRD intake?
Anyone have first hand knowledge of which oil cooler fits with the TRD intake?
I really like the Perrin setup but it doesn't look like it has enough clearance. Another option would be to ask Perrin to make the length of the hoses longer and use a banjo bolt and then an angeled fitting for at least the left side fitting.
Hanakuso is offline   Reply With Quote
Old 07-01-2013, 07:13 PM   #2
sw20kosh
Drives: 2013 Black FR-S
what portion of the intake is having clearance issues? @robispec Cooling Solution should fit with that intake.
Old 07-01-2013, 07:18 PM   #3
Hanakuso
Just looking at these pictures, it looks like it won't be able to fit.
Old 07-01-2013, 07:22 PM   #4
sw20kosh
Might be a tight squeeze. Looks like the issue is the fittings on the sandwitch plate which to my knowledge all oil coolers use.
Old 07-01-2013, 07:26 PM   #5
Hanakuso
Just from look at this picture, maybe a banjo bolt and an angled fitting will work, but it will also decrease flow.
I know the Cusco oil cooler might have a sandwich plate that works better, but I don't like the fact it's expensive and it doesn't turn on till 260F
Old 07-01-2013, 07:40 PM   #6
robispec
Drives: Black frs project
We have a new sandwich plate with the fittings center and vertical not horizontal.
robispec is offline   Reply With Quote
The Following 2 Users Say Thank You to robispec For This Useful Post:
Hanakuso (07-01-2013), JDKane527 (07-01-2013)
Old 07-02-2013, 02:39 AM   #7
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Got a pic?
I think we (TRD intake guys) can get away with using banjo fittings like in the Mishimoto oil cooler kit. I was thinking on getting it, but I'm wanting to put my funds elsewhere for now. I took another pic of the clearance, between oil filter and intake box, while I was installing my P&L header.
JimmyMac is offline   Reply With Quote
Old 07-17-2013, 05:45 PM   #8
Mishimoto
Drives: 2013 Subaru BRZ
Hey guys, thought I would chime in here to help answer any questions. Our kit does use banjo fittings like JimmyMac said, which would allow our kit to fit with this intake.
Let me know if you have any questions about this kit. You can find more info on the product page here - http://www.mishimoto.com/subaru-brz-...er-kit-13.html
Mishimoto is offline   Reply With Quote
The Following 2 Users Say Thank You to Mishimoto For This Useful Post:
stevo_12v (07-17-2013), TofuJoe (08-27-2017)
Old 07-17-2013, 06:54 PM   #9
Hanakuso
I ended up preordering a Perrin oil cooler. If it doesn't fit then I might try a banjo bolt, but most likely I would just end up selling the TRD intake. I'll update once I get it.
Old 07-17-2013, 10:24 PM   #10
brillo
Drives: 2013 Firestorm FR-S
Having just built my own cooler kit following the template outlined by Perrin I'd think your ok as far as clearance as I have the stock air box and the TRD box looks smaller. If you run into fitment issues pm me as I have some tricks that can help. Also check out F1point4's oil cooler DIY thread for additional tips.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 07-18-2013, 03:57 AM   #11
JimmyMac
JimmyMac's Avatar
TRD box is bigger.
Old 01-01-2014, 03:31 PM   #12
wootwoot
Drives: FRS
Bump.
Anyone install an oil cooler with their TRD intake?
Old 01-01-2014, 06:01 PM   #13
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by wootwoot View Post
Bump.
Mishimoto unit will fit just fine.
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Kris86 (09-22-2016)
Old 01-01-2014, 08:24 PM   #14
wootwoot
Drives: FRS
Is there any down side to those banjo bolts? Do they flow as well as the other fittings?
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 06:06 PM
New Twist On Oil Coolers @ Pure Automotive Performance Pure Automotive Engine, Exhaust, Transmission 39 04-09-2013 10:33 PM
HKS Oil Coolers in stock Sam Strano Engine, Exhaust, Bolt-Ons 3 11-13-2012 01:41 PM
