Old 05-27-2013, 12:52 AM   #15
Gen
Drives: Scion FR-S
Eh...
Gen is offline   Reply With Quote
The Following 2 Users Say Thank You to Gen For This Useful Post:
nix (07-19-2013), SkullWorks (07-16-2013)
Old 05-27-2013, 05:31 PM   #16
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Originally Posted by Gen View Post
Eh...
That's coming from the connection of the compressor inlet to your tester, right?
Bubbles rolling around the compressor housing walking toward the turbine side.
Actually leaking from the tester connection.
If so... no worries, just a funny picture to post.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 05-27-2013, 05:40 PM   #17
Gen
Drives: Scion FR-S
It's the compressor housing itself unfortunately. Bubbles are actually walking toward the tester away from the turbine. I can't hear / feel any air, but it sure can double as a bubble machine.
At redline I'm seeing a drop to about 7.1 psi from a max of 8. Might explain the drop off in power I see on the dyno.
If I remember correctly, the GT28s have no O ring; bolts are definitely snug. High temp RTV seems to come highly recommended.
Old 05-28-2013, 12:12 AM   #18
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That is interesting looking. I know I didn't put anything on any of my bolts when I assembled and clocked my GT28.
Old 05-28-2013, 12:35 AM   #19
dabocx
dabocx's Avatar
Drives: Scion FRS
Use this as a cheap excuse to get a gtx30
dabocx is offline   Reply With Quote
Old 07-01-2013, 02:14 PM   #20
Gen
Drives: Scion FR-S
Mustang dyno after addressing some issues with the original fuel pump install and sealing the turbo. I don't advise following the instructions that are sent with the kit for the pump.
Old 07-01-2013, 02:28 PM   #21
jamesm
That's still very, very low. Something is wrong there.
Old 07-01-2013, 02:49 PM   #22
Opposed
Drives: 2013 Asphalt FR-S
On a Mustang dyno though? Those read super low as it is. Isn't the base FBM kit only do between 260-280whp on a Dynojet?
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 07-01-2013, 02:55 PM   #23
jamesm
i would still consider that to be very low. I've never seen an FBM kit make less than 270whp even on a completely stock car on 91. That's what, 225whp? I could be wrong.
Old 07-01-2013, 02:57 PM   #24
Gen
Drives: Scion FR-S
217
For what it's worth, it read 155 at the wheels before addressing the fuel pump. The original installer followed the instructions on the install to a T, complete with zip ties. (not being sarcastic) It's now much more secure.
Old 07-01-2013, 03:06 PM   #25
jamesm
correction to a dynojet reading would be 12% according to the sticky (not an exact science, i know). that put's at at 243 dynojet whp. i'd get the thing looked at.
Old 07-01-2013, 03:22 PM   #26
Gen
Drives: Scion FR-S
Quite honestly, I think the numbers people think it makes aren't realistic.
Here's King Tut's Dyno on 93
Considering it's on a dynojet with better fuel, that's damn near identical.
This was his 14psi run.
Old 07-01-2013, 03:33 PM   #27
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We just did a complete turbo install on a customer car that made 304hp @10 psi on 93 pump.
On 16 psi and e85 we made 400hp. I will post up the whole build shortly.
FullBlown is offline   Reply With Quote
Old 07-01-2013, 05:17 PM   #28
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I would not quote my numbers. As time has gone on, I have grown less confident in either of those dyno plots being correct due to RPM pickup issues. The RPM scale is not correct for either pull that was collected. I will have new dyno plots after July 12th.
The Following 4 Users Say Thank You to King Tut For This Useful Post:
akuhei (07-01-2013), Floggin Tires (07-01-2013), lexusb3 (07-01-2013), Sportsguy83 (07-02-2013)
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Compilation of Dyno results somewhere??? Scooby South Engine, Exhaust, Transmission 3 01-08-2013 06:51 PM
Pocket Dyno App Results CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 14 09-12-2012 10:45 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 10:15 PM
