Old 06-30-2013, 10:49 PM   #29
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
Originally Posted by DarkestBuddha View Post
Kelvin you ever get the VG yet?
Him and I are still waiting for them if he got them from the same place I did, which I am 98% sure.
Old 07-02-2013, 07:51 PM   #30
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Originally Posted by BRZJonny View Post
Mine was also produced after the problem was supposedly fixed. When I took it in for a service, I told the tech about my intermittent problems with reception etc. when they checked it, they discovered that the upgrade had NOT been performed on my car even though the vin# was after the problem range. Subaru authorized the fix and since then everything works perfect.
What I was saying is that I have no GPS antenna issues. Are you referring to the SiriusXM antenna, which is separate form the GPS antenna?
DoomsdayJesus is offline   Reply With Quote
Old 07-02-2013, 10:17 PM   #31
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
sooo educate me a bit.. With the Beat Sonic..Do we loose any capability??? XM/HD/NAV ????
An option I am checking on right now is a new Legacy Sharkfin..in Factory Colors.. I just have to see if it is compatible with our connections... I sure hope so as that would be a great mod... as long as it would work. Will keep you advised
Bill
Scooby South is offline   Reply With Quote
Old 07-04-2013, 06:09 AM   #32
37
degrees
37's Avatar
Drives: 6MT BRZ
It bolts up but is non-functional. If function is a priority then you'll want a cover or short mast instead.
http://www.ft86club.com/forums/showthread.php?t=32737
http://www.ft86club.com/forums/showp...0&postcount=22
A modified Nissan antenna apparently works but XM is gone and radio reception is likely an issue.
http://www.ft86club.com/forums/showthread.php?t=12105
37 is offline   Reply With Quote
The Following User Says Thank You to 37 For This Useful Post:
Scooby South (07-04-2013)
Old 07-04-2013, 08:40 AM   #33
Scooby South
Conedancer
Thanks so much..saved a bunch of time and money...wonder why that didn't come up when I searched. .appreciate the assist.
Bill
Old 07-04-2013, 08:40 AM   #34
Scooby South
Conedancer
Bill
Old 08-06-2013, 12:56 PM   #35
DarkestBuddha
Drives: BRZ limited GBS
so did any of you guys install your VG yet? pics!
DarkestBuddha is offline   Reply With Quote
Old 08-06-2013, 01:06 PM   #36
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
I'm sure I can find a picture somewhere, but I've had the VG antenna since August of last year and it's definitely still holding up. Paint match is perfect versus the Beat-Sonic and I've noticed no loss in reception versus the stock antenna listening to XM radio daily. GPS is still terrible but no antenna change will fix that.
mikeTee is offline   Reply With Quote
Torn on Antenna Options. 2pt5RS Cosmetic Modification (Interior/Exterior/Lighting) 17 02-18-2014 07:16 PM
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 02:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
WTT: Beat-Sonic Antenna for Modelista Antenna joergasm Canada Classifieds 4 12-10-2012 10:13 AM
Antenna Options Re~Mix Electronics | Audio | NAV | Infotainment 10 07-20-2012 01:02 PM
