Old 06-30-2013, 07:09 PM   #1
encity5
encity5's Avatar
front pipe?
Sounds like this is a really noob question so my apologies ahead of replies. (i dont have any experience with car mechanics and tuning and such, still learning)
What exactly does the front pipe do? I understand that the exhaust gasses go through this pipe, but what are the differences between catted / catless / resonator?
I'm looking to install an aftermarket exhaust (invidia n1 or q300) and just want to make sure i do it properly. A lot of videos and examples i see always mention a catless front pipe.
So if im getting an aftermarket catback exhaust, do i need a new front pipe? what kind? any major benefits / pitfulls to having one?
Everything else mechanically is stock.
Thanks! any resources to understand these items would also be great! trying my best to learn.
encity5 is offline   Reply With Quote
Old 06-30-2013, 07:21 PM   #2
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
your car has two "cats" in the exhaust system. these are for emissions which i would assume are strict in new york.
the benefits to replacing the exhaust is to free up flow ( the header is more complicated than just bigger piping)
Getting just a catback will have little to no affect on power or mileage, it will make it sound different (usually louder and deeper tone)
Resonated will cancel out certain frequencies generally to avoid drone when switching to an aftermarket header.
GR86 MT premium
StormTrooper is offline   Reply With Quote
The Following User Says Thank You to StormTrooper For This Useful Post:
encity5 (06-30-2013)
Old 06-30-2013, 07:23 PM   #3
StormTrooper
You should be able to search....try reading through the nameless/ jdl/ P&L header threads and the Perrin exhaust thread.
should have everything explained within those.
GR86 MT premium
Old 06-30-2013, 07:33 PM   #4
mxsled
mxsled's Avatar
Drives: Audi A3 2012
This:
Axleback=Muffler
Catback = midpipe+muffler
Headerback= overpipe/frontpipe+midpipe+muffler
Moto east Ecutek /JDL UEL Header/Nameless Performance axleback exhaust-Motiv overpipe/Full Perrin CAI/BC Racing Coilover/Traklite angle 18x9/Federal 595 RS-R (245-35-18)/Blackhousing,hid 4300k headlights/Crystal eyes taillight/Anarchy Motive Heavy ShiftKnob/Cusco Sport pedals/Jpm Coachworks alcantara dash panel,cluster,shift boot,
mxsled is offline   Reply With Quote
The Following 3 Users Say Thank You to mxsled For This Useful Post:
ericmpena (06-18-2014), ProjectD (07-01-2013), Yamaha_R6 (01-29-2014)
Old 06-30-2013, 08:02 PM   #5
encity5
encity5's Avatar
Originally Posted by mxsled View Post
This:
Axleback=Muffler
yea i came across that diagram in my search, i know where the pipe goes.
Looking for more specifics about the roles it plays and the differences.
Old 06-30-2013, 08:50 PM   #6
jonbonazza
It's function is really no difference than the rest of the exaust system -- to deliver exahust gases from the engine to the rear of the car where they can be safely vented to the atmosphere.
A resonated front pipe has a resonator which, like mentioned above, ultimately reduces drone and usually reduces sound level.
A catted front pipe will have a catalytic converter instead of a resonator for emissions purposes (This is what is installed from the factory).
A catless front pipe (A.K.A. a test pipe) has neither and is just a pipe.
jonbonazza is offline   Reply With Quote
The Following User Says Thank You to jonbonazza For This Useful Post:
Old 06-30-2013, 10:17 PM   #7
Cal3000
Drives: Panda FR-S
The overpipe is basically there to couple the header to the front pipe. Overpipe geometry is important for performance of the engine and can be a vacuum to the exhaust gases that leave the header reducing back pressure.
The OEM front pipe holds the secondary cat for emission purposes. The secondary cat causes back pressure to the engine which restricts the breathing which restricts power. Your engine vacuums air through the intake and spits out exhaust. Exhaust pressure in the headers and overpipe will be higher with the cat than with no cat. You engine will be working against this pressure.
So when you remove the secondary cat, you engine can breath better and has less pressure to work against, so it increases the engine hp.
Midpipe and muffler allows the exhaust gases to travel from the car safely as jonbonazza said. Changing just these components will have minimal effects for performance increase.
Piping curving and dimensioning is also very important for performance through the exhaust system.
Cal3000 is offline   Reply With Quote
The Following 2 Users Say Thank You to Cal3000 For This Useful Post:
encity5 (07-01-2013), spgrizz22 (06-30-2013)
Old 07-01-2013, 12:10 AM   #8
j2digit
j2digit's Avatar
Drives: 2000 Integra LS, 2013 FRS Firestorm
My apologies as well for asking here , but is picking a catless pipe ,will it dramatically affect your emmision in the future? i know we won't need smog test for at least the next three years (here in cali) but just don't want to be on the illegal side of it.
thanks in advance
well, that was fast. I found this on the MXP website:
http://www.mxp-performance.com/?page_id=539
"the highway in the state of California or elsewhere that requires emission controlled to be retained"
so i guess catless pipe is a no no here in cali.
"Power is nothing without Control"
j2digit is offline   Reply With Quote
Old 07-01-2013, 01:35 AM   #9
Cal3000
Drives: Panda FR-S
thanks in advance
With new cars, I think you don't have to get it smoged till after 6 years. I could be wrong.
You can delete your cats and just replace them when smog check comes around. Or just get a high flow cat if you are conscious about the environment.
I have a catless front pipe and will be getting a vortech SC. Will strip back to stock for smog check.
The Following User Says Thank You to Cal3000 For This Useful Post:
j2digit (07-02-2013)
Old 07-01-2013, 08:57 AM   #10
swift996
swift996's Avatar
I just got a non-catted but resonated front pipe, it pulls smoother up top now. Probably good for about 3-4hp but who knows w/o a dyno. I'm running a header so I think the OEM front pipe was restricting the flow.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-01-2013, 09:31 AM   #11
infinite012
Drives: 13 DGM BRZ Ltd
thanks in advance
Removing your catalytic converter(s) completely is a federal offense. It is illegal to remove your catalytic converter(s) in all 50 states.
42 USC § 7522(a)(3)(A):
(a) Enumerated prohibitions
The following acts and the causing thereof are prohibited—
(3)
(A) for any person to remove or render inoperative any device or element of design installed on or in a motor vehicle or motor vehicle engine in compliance with regulations under this subchapter prior to its sale and delivery to the ultimate purchaser, or for any person knowingly to remove or render inoperative any such device or element of design after such sale and delivery to the ultimate purchaser;
infinite012 is offline   Reply With Quote
The Following User Says Thank You to infinite012 For This Useful Post:
Old 07-01-2013, 09:54 AM   #12
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
yea i dont think anyone cares about that law lol. I hear people going full catless headerback, but dont mention a tune, how are the afr's when not tuned?
bkblitzed is offline   Reply With Quote
Old 07-01-2013, 02:17 PM   #13
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
TL;DR in our car it does not nothing but changes the sound. / May be illegal to remove cats in certain states.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
The Following User Says Thank You to l0aded For This Useful Post:
chas3wba0 (08-05-2015)
Agency Power Front/Over pipe (Combo pipe) - Cheap! seven Engine, Exhaust, Bolt-Ons 12 03-09-2013 01:40 AM
FA20CLUB Over Pipe Front Pipe & Cold Air Intake Now Ready FA20Club.com Engine, Exhaust, Transmission 171 02-27-2013 09:44 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
Agency Power over-pipe/front pipe combo question... seven Engine, Exhaust, Transmission 11 01-13-2013 12:14 PM
