Old 03-11-2013, 05:30 PM   #57
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by swift996 View Post
Looks super clean! Are you running OEM brakes in the rear? The reason I ask is I just picked up a set of Wilwoods for the front and not sure what I'll do in the rear yet. Maybe just pads?
OEM calipers in the rear w/ Hawk HP+ pads and SS lines. Will be switching those pads out for something more aggressive soon, I believe.
Thanks!
Originally Posted by mact View Post
Where in IA are the AutoX events? I want to go to some this summer.
Jeremy and I are the local directors for our SCCA autocross events. Our first scheduled event is March 24th at Adventureland Amusement Park in Altoona, IA.
Other venues we have are:
1. Iowa Events Center, Des Moines, IA
2. Oskaloosa Municipal Airport, Oskaloosa, IA
3. Iowa Speedway, Newton, IA
Hope to see you at some! We will have both cars out at all events since we are the event directors.
Cheers!
-Yo
FT-86 SpeedFactory is offline
Old 05-04-2013, 05:42 PM   #58
FT-86 SpeedFactory
Greetings from One Lap
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
jonnyozero3 (05-08-2013)
Old 06-28-2013, 10:21 PM   #59
FT-86 SpeedFactory
Update Time!
Details:
Enkei RPF1
Offset: +38mm
Hub Bore: 73mm
Bolt Pattern: 5x100
Weight: 17.6lbs <- SUPER LIGHT!!!
Color: Black
We mounted up 265/35/18 Hankook RS3 tires in the love of keeping grip on the road.
WHY?
Lets not forget our V2 Single Exit is now on the car.
Super lightweight. Muffler section weights in at 10 lbs exactly. Add in our mid pipe at 16lbs, entire system is 26lbs.
V2 SPECS:
2.5" T304 Stainless Catback to Muffler
Minimal bends, Single Piece Mid-Pipe No pie cuts and welds here.
4" Stainless Angle Cut or Rolled tips
Made in the U.S.A (Iowa to be exact.)
V-Band Clamp for rear section
Un resonated or resonated options are available on this system
Extremely light weight
Fits both manual and automatic FRS / BRZ cars
Backwards compatible with the V1 system.
Picture time.
Resonated:
Non Resonated:
Standard Pics:
On Car:
Videos contain the following exhaust mods:
Borla UEL
Motiv Over Pipe
Invidia Resonated Front Pipe
FT-86 SpeedFactory V2 Exhaust ( Single Exit )
Rev Video - Resonated Version:
[ame="http://www.youtube.com/watch?v=3x6-lBPjSjY"]FT-86 SpeedFactory V2 Exhaust - Single Exit - Scion FR-S and Subaru BRZ - YouTube[/ame]
Drive By - Resonated Version:
[ame="http://www.youtube.com/watch?v=3D9KmIF8boQ"]FT-86 SpeedFactory V2 Drive By Videos - YouTube[/ame]
More videos and dyno's after we get back from 86Expo in Las Vegas.
Drive By on the Salt Flats - Resonated Version:
[ame="http://www.youtube.com/watch?v=4BI7F4VA7n8"]FT-86 SpeedFactory V2 Exhaust Fly By - Salt Flats - YouTube[/ame]
Old 06-28-2013, 11:07 PM   #60
Dipstik-sportech
Dipstik-sportech's Avatar
You guys should bring the car down to BIR in September for Proving Grounds. There were some guy down there from Des Moines at the last one.
Dipstik-sportech is offline
Old 06-29-2013, 06:10 AM   #61
Hiros86
Hiros86's Avatar
Drives: whiteout FR-S
are these the 17 or the special edition 18s?
Hiros86 is offline
Old 06-29-2013, 10:45 AM   #62
FT-86 SpeedFactory
That photo is the 17's. Those are special order also. Pretty much any RPF1 in our fitment is special order which is why they are hard to get a hold of.
The 18's are limited edition due to the color of sticker Enkei is putting in the boxes.
Old 06-29-2013, 10:48 AM   #63
FT-86 SpeedFactory
We're thinking about attending the September event. The June event was to close to 86Expo for us to make it.
Old 06-29-2013, 12:32 PM   #64
Dipstik-sportech
You guys should really come down. There were quite a few of the twins down there. I plan to do the road course and drags.
Old 06-29-2013, 11:45 PM   #65
FT-86 SpeedFactory
Well the road course is calling our name so may just have to make it happen.
Old 07-25-2013, 02:55 PM   #66
FT-86 SpeedFactory
bump
Old 07-25-2013, 04:56 PM   #67
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
To
So you've gone to 18" Enkeis now how much heavier was overall setup compared to what you found on 17s tires and all?
Assume as well you pretty much need to be on coil overs with 18x9.5" as well to avoid any rubbing etc correct?
OICU812 is offline
Old 07-25-2013, 05:21 PM   #68
FT-86 SpeedFactory
It has been quite some time since we have been able to update any of our build threads, but we have some changes being made to the car before we head out to 86 Fest in Fontana, CA.
This update will showcase a major change
We are still wrapping things up on the install, but we shall be boosting soon
The Following 2 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
humanshield (07-25-2013), R2RO (07-28-2013)
Old 07-25-2013, 05:21 PM   #69
FT-86 SpeedFactory
Originally Posted by OICU812 View Post
To
I'll have to go weigh a set here in a minute, but It's probably 4-5lbs more per corner.
Old 07-25-2013, 08:30 PM   #70
humanshield
Drives: bucket
i took the weekend off and my girl and i will be driving to fontana. we will see you there!
nice upgrade BTW
humanshield is offline
Drop In Filter Dyno Results - FT-86 SpeedFactory FT-86 SpeedFactory Engine, Exhaust, Transmission 241 08-20-2018 11:22 AM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
FT-86 SpeedFactory - Exclusive Source for FR-S / BRZ / GT-86 Parts! FT-86 SpeedFactory Announcements, Contests, Giveaways 10 08-02-2012 12:50 PM
>>>KW V3 Suspension<<<< IN STOCK - FT-86 SpeedFactory FT-86 SpeedFactory Brakes, Suspension, Chassis 8 07-31-2012 11:50 PM
