| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
Drives: WR Blue BRZ, 240Z
The reason I want to stick with 17's is that I'm trying to preserve as much sidewall as possible to retain a comfortable ride. I'm a lot older then many of my fellow -86 enthusiasts and my old bones need to be driven is some semblance of comfort.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#16 | |
If you avoid potholes, chances are, you'll never bend your RPF1 to the point where they can't be repaired. |
#17 | |
Drives: 2005 Toyota Camry
Sorry to correct, it's unsprung weight. [ame="http://en.wikipedia.org/wiki/Unsprung_mass"]Unsprung mass - Wikipedia, the free encyclopedia[/ame] Kind of a big deal for me... my last license plate in CA was "UNSPRNG" -aex |
#18 | |
Drives: Some rust bucket
You can almost treat wheels as a consumable when you track your car, right? |
#19 | |
I can't speak for any other forged wheels (looking at basically any two/three piece forged wheels from HRE, CCW, etc.; these are machined out of forged ingots, and are not of the same quality as BBS/Rays) Just remember who provides wheels to pro level racing: OZ, Enkei, Rays, and BBS. Coincidence? Probably not. |
#20 | |
You can..... if you also treat your car as a consumable at the track. The chances of a true forged wheel to have a catastrophic failure versus a semi-forged/cast wheel having the same failure, is a lot less. More engineering/testing and refined manufacturing processes don't translate to faster lap times. They translate to more safety when something happens beyond design limits. -alex |
#21 | |
#22 | |
Want to shave lap times? Invest the money spent on a nice set of forged wheels, and take some true driving lessons at the track with a professional racing school. Most people mod and race in canyons or on public roads... not knowing how to control their cars. -alex |
#23 | |
18" wheels on the 86 will not improve performance in any way over a comparable 17" wheel. In fact, they typically make the car slower. Larger wheels are typically heavier, and anything that adds rotational weight will slow acceleration to some degree. This has been proven with a stock car, where wider 17's hurt lap times (due to extra wheel/tire weight) and 18's also hurt lap times, a bit worse I believe. The only thing that actually improved lap times were either much grippier tires, or much lighter 17's with grippier tires. A wider 17" wheel that is the same weight as the stock wheel will ultimately weigh more in the end, simply buy virtue that is uses a wider tire. Also, a wider wheel may have similar weight to another narrower wheel, but the wheel's design is a very critical element. If it has a wider rim, then it may still require more energy to accelerate because more mass is located farther from center. This isn't always the case, but something to consider beyone simple weight comparisons. |
#24 |
Dave,
You bring up very valid points. The choice of wheel and tire is a trade-off and potential compromise on many fronts. Not mentioned in your reply are the effects of a wider tire on turn-in (front) and rotation (rear) which can adversely effect the fine handling qualities of the -86 platform. At this point I'm still trying to figure out the (or rather, my) "Goldilocks" configuration. I want to stay with 17" rims for the reasons you mentioned above. I want to go with an 8" wide rim to accommodate 225 section width tires (perhaps even a 245/40 when I install a SC). And I'd like to go with a +35 off-set for looks...I know that's the wrong reason but I do like the look of a flush fit. I believe I can accomplish all of the above and still loose 2 to 3 pounds per wheel/tire and maintain the fine balance of the -86.
#25 |
For stock power, I think 17x8 is a good balance between grip and weight. A lot of track guys run that configuration right now.
#26 |
18" allow for bigger brakes which you would need to consider once you have the s/c system. Because ultimatley, even though you dont want to unbalance existing set up, adding power brings a whole additional list of variables that will require bigger brakes hence bigger wheels and tires along with other components to strengthen the chassis to cope with added power. Besides, when the power comes in, the unsprung weight difference will be less noticeable vs to a factory stock set up. The key is to remember what the end game would be on the car. Weve seen many consumers buy 2 sets of wheels because they have issues putting on bigger brakes on stock wheels... Its great for the wheel business but not necessarily good for the consumer... As indicated before, its all about trade offs and compromises. A good article from car and driver on bigger wheels and tires http://www.caranddriver.com/features...d-tires-tested It shows what you give up on acceleration and fuel economy you gain in grip along with shorter stopping distance. Now imagine adding power to the mix and the deficits of the slower acceleration are erased. Of course, wider 17" might be a solution but wider will still give the same effect as 18" because instead of adding weight in diameter, you are adding weight in width...
#27 |
Drives: 2013 FRS Asphalt
If you are not doing 17s because of brake upgrades just look through the build threads. While there are some doing them. The majority has not. And if you give us the right offset like the 17x9 +35 rpf1 we won't have issues.
2013 Scion FR-S AT Picked up 5/30/2012
#28 |
wheel size also would be dependent on how big diameter of brakes and caliper set up that would be put on the vehicle. That would determine if a 17 diameter wheel will still fit or not.
| Spacer question for OEM wheels | Mrqb22 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-26-2016 05:25 PM |
| WHEELS. Light and big, oh my! | Nezz | AUSTRALIA | 12 | 11-01-2012 05:12 PM |
| Wheels, Wheels, Wheels | Island Import Performance | IslandImportPerformance | Wheels and Tires | 4 | 07-31-2012 10:08 PM |
| Wheels Question | Tsinoy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 01-19-2012 01:45 AM |
| Why are most stock wheels weak stance? | #87 | Other Vehicles & General Automotive Discussions | 16 | 12-17-2011 05:15 AM |
