#197 |
Drives: 2023 WRB BRZ (MT)
#198 |
Drives: '13 FRS
I've got a scanmaster on my VR4 (OBDI) that's basically identical in function, but it's in an ugly box. This is an amazing product for the FR-S Since a boost gauge will be required for a turbo kit, this seems like the ideal solution for a stage 1-2 (avo) turbo kit car. Bummer that it doesn't show knock, though ![]() I see that you can rotate the gauge in the dash. Can you flip it 180, and flip the text? That would put the gauge closer to the road which is pretty much always better :happy0180:
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135 |
#199 |
Drives: '13 FRS
I guess I got one of the last 2 at the GB price
![]() I couldn't resist buying 1 of the 150 psi sensors. It will be nice to know the exact oil pressure of our engine before we've even finished breaking it in...
#200 |
Drives: Scion FR-s
just ordered
did you guys figure out all of the wires??
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake |
#201 |
Drives: 2013 White Out FR-S
thanks for the order. fyi our gauge has the overboost warning built in preset at 6.5 psi it will begin to flash.
| The Following User Says Thank You to FA20Club.com For This Useful Post: | lbroskee (06-28-2013) |
#203 |
Drives: 2013 SWP BRZ
Tony - was your stock depleted? If not i'll send over a payment now.
#204 |
we have more of them coming in no worries
| The Following User Says Thank You to FA20Club.com For This Useful Post: | xxscaxx (06-28-2013) |
#205 |
#206 |
they are almost ready to release the pdf install guide but you only programmable features are for external sensors and adjusting the boost warning limit. everything else is preset and as far as programming you can use the guides they have listed on their site for the other gauges the controller is the same for all gauges just install differs based on vehicle
#207 |
Drives: 2013 BRZ Limited
I just got mine in today. Super easy to put in and works great. (I am glad I ordered an oil cooler now that I can see how hot my oil gets with just a single hard run!)
Anyway... I have a ProSport oil pressure sensor and wiring harness that I'd like to hook up to this if possible. Obviously, the gauge side of the harness doesn't match... a 4-pin connector with three wires in it (red, white & black). Anyone tell me what I have to connect where?? Thanks! |
#208 |
Grip>Slip
any in stock still? @FA20Club.com
#209 |
SLO NO MO
Got my kit today and installed it - works great. Thanks Tony!
Where is everyone tapping the green dimmer wire on to? I just left mine disconnected for now. |
#210 |
I wonder if you can tap it into the headlight leveling switch like you can in an STi. I just installed gauges in my bro's 08 sti and I tapped a wire right on that and it worked perfect.
| Tags |
| gauge, p3cars |
| LHD 3-meter gauge-pod? | TuxedoCartman | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 02-11-2015 06:19 PM |
| Dash Cam + HU + Reverse Integration | JDMSushi | Electronics | Audio | NAV | Infotainment | 0 | 12-04-2012 06:47 PM |
| iPod®/USB Integration in the glove box? | 8987846 | Electronics | Audio | NAV | Infotainment | 26 | 12-04-2012 12:45 AM |
| Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) — General Topics | 40 | 08-19-2012 04:29 PM |
| Gauge Sweep? | himbo | BRZ First-Gen (2012+) — General Topics | 17 | 12-12-2011 11:39 AM |
