Old 06-27-2013, 05:17 PM   #99
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by SubieNate View Post
How big a tank of meth would you need to feasibly daily drive it with the meth turned on? Could you get a tank big enough to last through more than one tank of gas?
Also, it looks like you're injecting before the SC. I thought that was bad juju on a PD type supercharger?
5 gal/h nozzle takes a while (~30 mins) to deplete my tank when constantly on. During daily driving it only comes on when you really need to accelerate so the 3 gal tank I am using lasts an eternity.
On the track, I find the meth injection is on about 50-60% of the time. For a 20 min session I would probably only deplete the tank 1/3 of its volume.
As for the position of the nozzle, you have it backwards. You want to spray onto the screws or rotors to make them more efficient (cooling them down and sealing them better).
Old 06-27-2013, 05:29 PM   #100
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Gotcha. For some reason I was thinking that spraying before compressing could damage things. Incompressibility of fluids and all.
SubieNate is offline   Reply With Quote
Old 06-27-2013, 07:43 PM   #101
sw20kosh
Wont hurt anything if it is a fine mist.
After all, you are spraying incompressible fluid into a combustion chamber that see's tremendous compression to the tune of 12.5:1.
As long as you don't spray too much or have large droplets, you'll be fine.
Old 06-27-2013, 07:44 PM   #102
robispec
Drives: Black frs project
Fluids vs gasses the who idea behind the wmi is getting the h2o to vaporize and using the heat delta to absorb the compressive heat.
robispec is offline   Reply With Quote
Old 06-27-2013, 07:55 PM   #103
Calum
That Guy
Drives: 2013 asphalt FRS MT
*Insert news story about genocide, depravity, and general human ugliness here.*
This is why I love you man.
Jackass
Old 06-27-2013, 09:10 PM   #104
swift996
swift996's Avatar
Important to note that you won't likely be able to run WMI with the intercooled version if you plan on injecting pre-compression. The water will likely cause condensation at the heat exchanger (intercooler). Alternatively you could run a 4 port injector at each intake manifold runner, but you loose some of the benefits of pre-compression (cooling the charge/sealing the compression in the screws).
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 06-27-2013, 09:38 PM   #105
robispec
Jackass
Def. a glass half empty kind o guy with his post history... But the world needs all types.
Old 06-27-2013, 09:49 PM   #106
Calum
That Guy
Orbital? Nah, more like the glass is half way. Not half empty or half full, just tells it like it is. Sometimes he is an ass, but it's because he's not letting other people blow smoke up his ass. He might need to smoke a joint to calm down & let some things slide. And he seems to forget that no matter how hard he tries he'll never fix stupidity. But I'm not much different, I just read my posts before I hit submit and think if this is a hill I'm willing to die on or not. If not, I press back and let the stupid continue without me.
Old 06-27-2013, 10:48 PM   #107
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by canu_50 View Post
Lol you clearly know nothing about Innovate.... Let me just put 2 other compagny name that is all in the same groupement.
Wiseco
JE pistons
Believe me, innovate won't go down because of a 200 000$ inventory they have on those supercharger.
I think you missed the point that was already explained in another post.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 06-28-2013, 01:14 PM   #108
canu_50
canu_50's Avatar
Drives: Scion fr-s
I did actually, saw it after lol. Was too lazy to go and edit my post. And after reading my self again, i might have been also a little bit rude!
Sorry for that my friend!!
canu_50 is offline   Reply With Quote
Old 06-28-2013, 10:16 PM   #109
sw20kosh
Small update:
Starting to smell burning clutch after 3rd and 4th gear pulls (usually up-hill ones). Possible sign that the clutch is stressed?
@robispec was on the stock clutch and tracking the shit out of it for how many miles and how much more ft-lbs before it finally gave out? His car is lighter too though so less inertia for the clutch to accelerate.
Old 06-29-2013, 07:55 AM   #110
robispec
yeah going through the stock clutch...
Old 06-29-2013, 01:31 PM   #111
sw20kosh
Is the new one holding up still?
Old 06-29-2013, 03:05 PM   #112
robispec
Yes no problems
Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! Innovate Motorsports Forced Induction 577 10-15-2014 12:49 AM
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 10:25 PM
Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! Visconti Forced Induction 67 04-03-2013 03:56 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 09:14 PM
