Old 05-30-2013, 02:49 PM   #1
mid_life_crisis
Drives: FR-S 10 #103 AT
CDT speakers
I've used them in the past with good results, but it's been a while. Are they still considered to be a good speaker? Has anyone tried them in an FR-S? I'm thinking in particular of the their 642 set that has a 6.7 inch bass driver, a 4 inch mid-bass and a tweeter.
mid_life_crisis is offline   Reply With Quote
Old 06-27-2013, 12:47 PM   #2
koteman
koteman's Avatar
Drives: Scion frs
i have them the 4s need a lot of work to fit but the 3s fit with out much
koteman is offline   Reply With Quote
Old 07-03-2013, 04:06 AM   #3
BigJyoungblood
Enthusiast
BigJyoungblood's Avatar
Drives: 2013 Scion FR-S (37J)
Which series do you have and how do you like them? Been thinking about the HD-632
BigJyoungblood is offline   Reply With Quote
Old 07-03-2013, 08:44 AM   #4
koteman
koteman's Avatar
Drives: Scion frs
I have the cl 642 set they r nice my amp right now isn't enough power to really hear what they can do. The onky think right now is the 4 inch speakers seen to be crossed to low on the passive cross over and distort at higher volume on some songs but once I get a new amp and go semi active I'll fix that plus it could be my amp also. But other than that they have killer mid bass way more than the jl 3way set I did in a friends frs. But the jl sound louder but they have a nice amp with matched power on them so hard to compare right now.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4 Beta
The Following User Says Thank You to koteman For This Useful Post:
BigJyoungblood (07-07-2013)
Old 07-03-2013, 10:59 AM   #5
mid_life_crisis
Interesting that the 4's seem to be crossed too low. Is that with the CDT crossover? CDT is known for their crossovers more than anything else so they should be pretty tight. Did you seal behind them?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
Old 07-04-2013, 03:24 PM   #6
koteman
koteman's Avatar
Drives: Scion frs
Yeah Cdt ex30 cross overs and it's not sealed behind so could be that could also be my amp. If I turn my hp to 120 it's fine but then I lose all my lows to the 6.5s and got have subs yet so it's not good enough to not have lows at least a little. I'm gonna run the 6.5s separate then cross the mids and tweeters a little hight when I get a new amp
Sent from my Galaxy S3
Old 07-05-2013, 09:36 PM   #7
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I really like the speaker mounts! Did you do them or did someone else do them?
kmbkk is offline   Reply With Quote
Old 07-05-2013, 09:37 PM   #8
koteman
koteman's Avatar
Drives: Scion frs
I did them check out my build log for more pics they took fir ever to get sizing right barely fit had to cut some dash out
kmbkk (07-10-2013)
Old 07-08-2013, 01:27 AM   #9
BigJyoungblood
Enthusiast
Adjust the midrange's eq at the crossover and mess with the tweeters also, I bet you will be able to increase the sound and reduce the distortion till you get your new amps!
Old 07-08-2013, 08:36 AM   #10
koteman
koteman's Avatar
Drives: Scion frs
I tired a few things the tweets are good at 0db if I reduce the mid it's way to quite. I even have the 6.5 playing full range and it helps a little bit but still need the mid at 0 not-3 but I just ordered my subs yesterday so ill be able to raise the cross over soon and be good :-D
BRZ door Speakers bbs15 CANADA 3 05-23-2013 05:29 PM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 06:31 PM
FS [vic] Speakers & Sub fuddbutter Australia Classifieds 2 10-13-2012 06:59 AM
speakers Audi Electronics | Audio | NAV | Infotainment 13 07-04-2012 09:35 PM
Speakers Audi Scion FR-S / Toyota 86 GT86 General Forum 1 01-21-2012 05:09 PM
