Old 03-16-2012, 08:49 PM   #1
Audi
on the German Autobahn
Drives: Sweet A3
Question speakers
i got a good deal on a like-new pair (6.5-inch coaxial speaker kit with built-in crossover) this offer will end soon and this thing are REALLY Good
i am planning to remove the stock speakers (cheap). should i buy it for my future BRZ/FR-S.
does it fit? is 6.5 inch the exact size? please answer ASAP .. thanks in advance
Audi is offline   Reply With Quote
Old 03-16-2012, 09:08 PM   #2
Audi
Drives: Sweet A3
How about 5.25" Speakers on the doors?
Old 03-17-2012, 12:10 AM   #3
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
6.5s would fit but why in the heck would you want coaxials in the door? The mids and tweeters are in the dash and likely to provide much better imaging stock than just aftermarket coaxials in the door.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-17-2012, 02:48 AM   #4
Audi
Drives: Sweet A3
Thanks Dave
Excuse my stupidity but im learning from ya.
So do you think the stock is better than FOCAL Speakers or other after market brands?
i will not change the headunite and i will run the speakers without amp. that what i did 10 years ago in my audi a3 .. FOCAL were the best speakers I've ever heard.
So what exactly the size of the mids (in the door) I have looked at the BRZ manual and still can not figure out something?
Old 03-17-2012, 03:21 AM   #5
st162celica
Drives: 86 GTS Manual - Tornado Grey
Leave the stock stereo and speakers. Just get an amp. Will be more than enough. All stereo units don't power the speakers much, you need an amp. Changing speakers won't make it any louder or clearer.
st162celica is offline   Reply With Quote
Old 03-17-2012, 05:51 AM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Audi View Post
Thanks Dave
Door speakers are 6.5", or maybe 6.75" which is just an oversized 6.5. However they just handle mid bass duties. The mid range and tweeter are in the dash. I'd replace all three if you are building a new system.
Focals, even in the A stuff really want an amp though. I'd venture a guess that the stock hu puts out very little power.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-04-2012, 03:07 PM   #7
cruzinbill
Drives: Argento 6spd FR-S
This is no where remotely close to true..... changing speakers to something of quality will indeed increase the clarity, loudness will come down to the difference in efficiency between what was in there and what you're putting in. While an amp will give sufficient power, it does not help the fact that the stock speakers are garbage.
cruzinbill is offline   Reply With Quote
Old 07-04-2012, 04:04 PM   #8
Dkittrell
Drives: 2013 FR-S hot lava
Stock speakers are powered by an amp FYI . The stock speakers are a low quality speaker , the cone is better quality then a lot of stock units tho .
couldn't say it better .
I just got back from a shop as I'm going to do JL audio ,3 way C5 and in the rear im cutting the stock speaker out and puttin in 6.5". Also doing a custom built box and doing a single 10 and dyno-matting the car . Power by 5 channel 700 watt amp . And topping it off with a kenwood dnx9990 head unit .Won't be the hardest system but it will be one of the cleanest
Dkittrell is offline   Reply With Quote
Old 07-04-2012, 05:28 PM   #9
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Underpowering quality speakers = blown speaker.
Focal is a high end brand... they want an amp. Don't use them with the stock headunit powering them.
Chewie4299 is offline   Reply With Quote
Old 07-04-2012, 09:01 PM   #10
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
So wrong I don't know where to start. Most factory head units, even without an amp, have enough juice to comfortably run most aftermarket speakers. Just don't try to make yourself deaf and a simple speaker change will make a huge difference. So far, my factory speakers suck, can't find anything wrong with the hu or amp though.
michaelahess is offline   Reply With Quote
Old 07-04-2012, 09:04 PM   #11
michaelahess
Within reason, not entertaining all of main street with the windows down, Focals will be fine on the amp. If you get louder or deeper, lower than 120k or so, bigger amp will be needed. Never, ever trust the freq resp published on a speaker, even focal. 6 inch woofers are not going to comfortably go lower than 100 to 120. Louder you play them the higher the sustainable freq.
Old 07-04-2012, 09:21 PM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Low power does *NOT* kill a speaker. Distortion does when a user pushes their low power amplifiers to the point of clipping.
I agree on not using the HU, but mostly for SQ reasons and efficiency once you throw a power robbing passive crossover network in the mix. And certainly at a given volume level a good amp will push less distortion to the drivers than a HU will.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-04-2012, 09:31 PM   #13
Chewie4299
Spaceman
Chewie4299's Avatar
Well yes, if you want to connect all the dots. Ultimately, playing power hungry speakers loud without a powerful enough amp typically = dead speaker.
Old 07-04-2012, 09:35 PM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It's just one of those misconceptions that has always bugged me
Distortion can be introduced in many areas, having plenty of power (or not enough) by itself doesn't mean anything. Too much power can kill a driver too, but too little never will. Distortion will kill a driver regardless of power.
Oh and running full signal to a tweeter because you forgot to set the crossover on the source (or amp) will smoke a tweeter too
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Speakers Audi Scion FR-S / Toyota 86 GT86 General Forum 1 01-21-2012 05:09 PM
