Old 06-25-2013, 01:48 PM   #99
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by StormTrooper View Post
Still not seeing how you would add in an up pipe and downpipe into the stock design and have it work well...
I agree that a turbo is the easiest way to make power... I highly doubt it's smooth or as easy to handle on the track as a s/c or na car though.
Its as smooth as you want it to be with a very linear power curve thanks to the GTX28 turbo. Trust me everything works very well mostly do to who tuned this car.
cf6mech is offline   Reply With Quote
Old 06-25-2013, 04:25 PM   #100
sw20kosh
Drives: 2013 Black FR-S
You don't add an up-pipe or downpipe. The turbo mounts behind the engine where the stock 2nd cat sits. The stock header/primary cat is retained.
Old 06-25-2013, 04:36 PM   #101
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
Originally Posted by FR-S Matt View Post
Catless headers don't stink if you have a cat in the front pipe. If I could clarify, go catless on the header but KEEP a cat in the front pipe.
(Ran catless longtube headers for years on my LS1 with cats in the front pipes and I don't get any nasty smell)
would you throw a cel with not cat in the header?
DAN_BRZ is offline   Reply With Quote
Old 06-25-2013, 07:25 PM   #102
FR-S Matt
You will if you don't run a spacer or tune the CEL out. The stock sensor picks up more flow from the header and throws a code reading it running rich I believe. It really kills your AFR balance at that point to continue to drive with the CEL on. Highly advise getting a tune with a catless header over the spacer. Not only will you increase performance, you get increased MPG's too when you aren't stomping on the gas.
I had two stock o2 sensors burn out on my Camaro SS with longtube headers because of the increased flow on them. Swapped to some aftermarket Bosch replacements and they work like a charm. It will be interesting to see how the stock o2's handle the flow over the years.
The Following User Says Thank You to FR-S Matt For This Useful Post:
DAN_BRZ (06-26-2013)
Old 06-26-2013, 02:04 AM   #103
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Why would someone pay the price for forged internals and then go redneck on the turbo setup???
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 06-26-2013, 03:37 AM   #104
sw20kosh
A. that config was the first turbo kit released to the public so if he bought it way back when the car was first released, he literally had no choice
B. he wanted to retain factory cat and header for a reason like emissions or stock header design
C. he wanted to have the added weight be towards the center of the car and not the front for weight balance purposes
D. he didn't want a hot turbo sitting in the engine bay emitting heat on everything in there
Until his incident with the cat falling apart we had not seen any incidence of a cat failing on this platform. Now we know.
The Following User Says Thank You to sw20kosh For This Useful Post:
cf6mech (06-26-2013)
Old 06-26-2013, 09:07 PM   #105
brzadmir
Drives: 13' BRZ, 05' 325xi, 02' RAV4
I hear a lot of people bashing the Borla UEL headers, for the new and improved batches is the welding better, quality wise and what not improved? Would anyone recommend such a purchase?
brzadmir is offline   Reply With Quote
Old 06-26-2013, 11:52 PM   #106
spgrizz22
Drives: Scion FR-S
I wouldn't get the Borla Headers. I would look at the JDL headers or MXP headers
spgrizz22 is offline   Reply With Quote
Old 06-27-2013, 01:10 AM   #107
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
The new Lachutes look interesting and well made.
The Following User Says Thank You to OICU812 For This Useful Post:
Hawk77FT (09-08-2013)
Old 06-27-2013, 03:38 AM   #108
Fast_Freddy
Drives: Passat
O2 spacers and mini-cats are just as effective as a tune and they cost hundreds less. The primary purpose of the secondary O2 sensor (narrow-band) is to monitor catalyst efficiency. When the cat is removed the sensor sees more oxygen than it would with a cat so all you need to do is reduce the volume of exhaust gas it sees. Angled spacers with restricted orifices work very well as do "mini-cats".
Closed loop AFR is controlled primarily by the primary O2 sensor (wide-band) and is unaffected by the secondary O2 sensor. Even with a P0420 CEL your AFR will remain unchanged from the target lambda 1.0 (stoich, 14.7:1). Fuel economy is unlikely to ever improve from an aftermarket tune although performance will.
I suspect it more likely that those O2 sensor failed due to increased temp rather than increased gas flow. Bosch makes great O2 sensors but our Denso's are excellent as well. I did have to replace a Denso wide-band on my 08 XB after I turbocharged it but it was fouled during tuning. The replacement Denso lasted over 50k miles and was still 100% when I traded the car in on my FRS.
http://www.bigdaddiesgarage.com/
Fast_Freddy is offline   Reply With Quote
The Following User Says Thank You to Fast_Freddy For This Useful Post:
FR-S Matt (06-27-2013)
Old 07-27-2013, 06:04 AM   #109
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
our SARD header has arrived! now waiting for the SARD catpipe to arrive!
https://www.facebook.com/media/set/?...8047905&type=3
ST-A is offline   Reply With Quote
Old 08-03-2013, 07:09 PM   #110
yamsta
daGangsta
yamsta's Avatar
Drives: 2013 FR-S 6MT
If anyone needs an equal length catted header right away I'm selling mine: http://www.ft86club.com/forums/showthread.php?p=1116300
yamsta is offline   Reply With Quote
SARD Japan Header & Mid-Pipe & Header & ECU nigel-jdmparts Engine, Exhaust, Transmission 63 01-21-2014 12:20 PM
Opinions please on header ft86me Engine, Exhaust, Transmission 40 06-09-2013 11:45 PM
Is there another header out there with a cat besides hks? Frsexxxy Engine, Exhaust, Transmission 10 05-23-2013 08:12 PM
What is the best header for my set up? CSI:86 Engine, Exhaust, Transmission 25 05-11-2013 02:36 PM
FS JDL EL Header JDLAutoDesign Engine, Exhaust, Bolt-Ons 8 02-16-2013 03:42 PM
