Old 05-31-2013, 11:53 PM   #1
VietnamPhenom
Drives: 2013 FR-S WHITEOUT
Go Fast Bits 3pc Lightweight Crank Pulley
I just got my GFB pulleys and installed. I really like this mod. Makes the car a little bit more lively. Revs are quicker, accleration is more responsive, and overall a great mod to have. I did install this myself. Taking off the water pump pulley is really easy. While the belt is still on, use a 10mm wrench or socket/ratchet combo and loosen the bolts. The belt itself will apply tension for you loose to the bolts off the water pump. Remove and place the new pulley on. Thread all the bolts on and reattach the belt. Use the belt's tension to tighten the water pump bolt.
As for the alternator and crank pulley, I used a chain wrench to hold each pulley stationary while using a breaker bar and socket to loosen it. The alternator nut is a 24mm while the crank is a 22mm. Remember to torque down the crank pulley to 95 ft. lbs.
Sorry for the crappy cell phone pics.
VietnamPhenom is offline   Reply With Quote
The Following 3 Users Say Thank You to VietnamPhenom For This Useful Post:
Alabang 86 (06-01-2013), Calum (06-01-2013), number1Tango (07-18-2013)
Old 06-01-2013, 12:56 AM   #2
EZWood
BAMF
EZWood's Avatar
are they just lightweight, or are they under drive?
Old 06-01-2013, 01:52 AM   #3
VietnamPhenom
Just lightweight.
Old 06-01-2013, 02:15 AM   #4
Alabang 86
Alabang 86's Avatar
Drives: GT86
nice job!
...my turn...
Alabang 86 is offline   Reply With Quote
Old 06-25-2013, 02:37 AM   #5
T-SoL
T-SoL's Avatar
Drives: Ultramarine FR-S MT
Hey i see that its been about a month since upgraded to GFB. How is it so far? Can you tell us about your experience i am planning on doing the same thing and GFB is the lightest combo you can get. also @EZWood mention "are they just lightweight, or are they under drive?" what is the difference? i have no idea what u are talking about so please educate me. Thanks in advance
T-SoL is offline   Reply With Quote
Old 06-25-2013, 12:34 PM   #6
Grymm86
Grymm86's Avatar
Drives: BRZ Limited DGM
Lightweight pulleys are just that, light weight and the same diameter as stock. an underdrive pulley on an accessory will have a slightly larger diameter and will rotate the component slower than designed.
Grymm86 is offline   Reply With Quote
The Following User Says Thank You to Grymm86 For This Useful Post:
T-SoL (06-25-2013)
Old 06-25-2013, 12:52 PM   #7
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
When you say the car accelerates faster, do you mean like a hundredth of a second 0-60? I don't see lightweight pulleys doing much more than that.
Old 06-25-2013, 01:08 PM   #8
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
They don't make a crazy difference, but it should be noticeable. Roughly the same as an intake or catback exhaust. It might drop a tenth off of your 0-60, but it should also improve your fuel economy because the engine doesn't have to work as hard to move the pulleys. Again, its only a small difference(probably less then 1mpg), but its a relatively cheap and easy mod with basically no down side.
@VietnamPhenom how long did it take you to install all 3? I put just a crank pulley in my old tC and that took me maybe half an hour(didn't know exactly how to do it)
Trashed675 is offline   Reply With Quote
Old 06-25-2013, 01:20 PM   #9
VietnamPhenom
As what everyone said, they are a lightweight pulleys. They don't make a "huge" difference, but they do make a difference. Throttle repsonse is quicker, and the revs are slightly faster then stock. Somedays I don't realize that I'm already doing 50 in 3rd. (in a 40 mph zone)
As far as time, it took me around an hour to do all 3. If you have the proper tools, the install will be easy to do. The water pump pulley is the easiest to remove. The alternator will have to be kept stationary, or if you have an impact gun fast enough to take the nut off. The crank was fairly easy, put the car into 6th and use a breaker bar with a 22mm socket and just give it a yank. Make sure you torque down the crank pulley bolt, and alternator nut. The water pump bolts can be snug.
The Following User Says Thank You to VietnamPhenom For This Useful Post:
Trashed675 (06-25-2013)
Old 06-25-2013, 02:10 PM   #10
SloS14
SloS14's Avatar
What does that have to do with the pulleys?
Old 06-25-2013, 03:05 PM   #11
Trashed675
Trashed675's Avatar
Probably that he didn't realize he was going that fast because it was easier to get up to speed.
Old 06-25-2013, 04:11 PM   #12
VietnamPhenom
^ What he said. It is easier to get up to speed with the pulleys. Overall it is a good mod. I haven't had any problems with thus far. I've put roughly around 2k miles on it. NO CEL or any sort of complications.
Old 06-25-2013, 04:21 PM   #13
UncleFester
Perhaps I should have tried a chain wrench on the alternator. I ended up disassembling it to get the pulley off.
I'm happy with it, its a nice kit. I can't say I feel a difference as I installed it in part with a lot of other mods.
UncleFester is offline   Reply With Quote
Old 06-25-2013, 09:40 PM   #14
T-SoL
T-SoL's Avatar
Thanks guys! got a lot of good insight.
any info or diy on the go fast bits pulley set fluffy-reindeer-slayer Engine, Exhaust, Transmission 2 07-17-2013 10:13 AM
FS: Kartboy Lightweight Crank Pulley OrbitalEllipses Engine, Exhaust, Bolt-Ons 6 03-21-2013 09:21 AM
Go Fast Bits Lightweight Pulley Kit on sale & Free Shipping @ Circuit Motorsports Circuit Motorsports Engine, Exhaust, Bolt-Ons 58 03-20-2013 03:07 PM
My lightweight crank pulley experience WolfsFang Engine, Exhaust, Transmission 22 11-29-2012 03:15 AM
Ralco RZ Lightweight Crank Pulley HELP! JERZgrl88 Engine, Exhaust, Transmission 11 10-10-2012 01:41 PM
