#15 |
Drives: TRD Ultramarine '13
They're not your grandma's tits. They'll be fine.
| The Following 2 Users Say Thank You to kALMIGHTY For This Useful Post: | 4Running Daily (06-24-2013), Calum (06-24-2013) |
#16 |
Drives: FR-S 2013
Camber bolts too?
Ok,
Springs it is. Should I go ahead and order camber bolts to put on When I do the springs? I got a set of Tiens on the way, 1.4 inch drop. Will I need the crash bolts to get the alignment right? I plan on taking it to a good shop in town for the alignment. Stock wheels and tires for now BTW. |
#17 | |
#RememberTheBuster
Drives: Firestorm FRS MT
If you want to look cool and say you bought something for your car, then the sub 1k coilovers are a good way to go. I don't see a reason for buying 2k+ coilovers for a 25k car that'll never see a track day in it's life. Different folks different strokes |
#18 | |
#19 |
AIM4APX
Drives: 2013 WRB BRZ Limited
Modern, high quality, coil springs don't sag. What "sags" over time are the OEM bushings and OEM bump stops which end up tearing and degrading usually because they are either under stronger loads, or at non OEM angles.
The way to combat this would be to buy a spring that comes with a bump stop with a higher durometer and then replace your bushings with poly inserts, or a hard rubber (more ideal for a daily, but harder to find). Alternatively you can just buy another set of OEM bump stops and re-cut them (assuming you did this the first time as most spring mfgs. suggest) and another set of bushings and re-install them to get the same feel as the day you put your springs on. Also, as noted above, if you use a very aggressive drop with OEM struts they will wear out faster and this can lead to a harsher ride due to your struts no longer dampening the way they should. Theom, if you are going with a 1.4" drop I would suggest an alignment bolt as well, and get an alignment done right away.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
| The Following User Says Thank You to Superhatch For This Useful Post: | theom (06-25-2013) |
| SPRING CLEANING! | Haulin | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 04-25-2016 10:44 AM |
| Spring install | DaBrz | Northwest | 8 | 05-14-2013 10:47 AM |
| Spring Mountain Run 4/28 | SubieGuts | New England | 0 | 04-20-2013 11:10 PM |
| Fact: Girls find it hot when a guy knows how to drive stick? | shishand | Off-Topic Lounge [WARNING: NO POLITICS] | 86 | 10-20-2012 03:51 PM |
| fact or fiction on this performance and tuning guide? | davey90 | AUSTRALIA | 10 | 07-19-2012 07:45 PM |
