Old 06-23-2013, 10:44 PM   #1
theom
Drives: FR-S 2013
Spring Sag? Fact or Fiction.
So I want to lower my car an inch or an inch and a half.
My buds tell me to save $2000 for coil overs.
I don't drift or track, but I may AutoX a couple times a year.
Yes, spirited driving.
So, the guys tell me if I do buy springs they will only be good for year or so then they will start to sag.
Is this BS? or is it real?
To me the bang for buck with $250 on springs seems like a good choice.
theom is offline   Reply With Quote
Old 06-23-2013, 10:47 PM   #2
cnk
Drives: '13 DGM BRZ Limited
If you're just looking to lower about an inch, just go with RCE Yellows and be done with it. Every spring will settle after installation, but quality springs should be fine after that.
cnk is offline   Reply With Quote
Old 06-23-2013, 11:06 PM   #3
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
They are correct, springs would only last you about a year give or take. Putting aftermarket springs on the stock shocks/struts will only make them wear out faster. As for coilovers, they could last 50k+ miles. If you do labor yourself, you could start off with the springs and when your stock shocks blow, just upgrade to coil overs. If you're paying somebody to do it, it'll end up being more expensive in labor to change the springs on the shocks vs. changing the whole coilover itself.
Enraged21 is offline   Reply With Quote
Old 06-23-2013, 11:29 PM   #4
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Some of my friends have had good quality springs for over a few years. They haven't noticed sagging, excluding the initial settling after install. With a spring, you'll probably wear out your struts faster. If you go with a coilover, go with a good quality coilover; you get what you pay for when it comes to suspension. Just realized that you'll eventually need to rebuild them. Everything eventually breaks.
G_Ride is offline   Reply With Quote
Old 06-23-2013, 11:48 PM   #5
theom
Drives: FR-S 2013
Thanks,
So, it's not that the springs will sag so much as the extra stress on the dampers will wear them faster.
Now I think I get it.
So I'm going to do Tien springs for now, Installed with a buddy. Meanwhile save for a good coilover set.
Old 06-24-2013, 03:18 AM   #6
suaveflooder
I don't buy the whole "spring sag" idea at all. I've run two cobras, a Mustang GT and an M3 on lowering springs alone and NEVER had an issue with any of them sagging. All have been for multiple years.
Once again, I went with springs on this car. Like you, I wanted a mild drop and the car DOES have coil overs on it already, they just aren't adjustable. I put on some eibach pro's and couldn't be happier. I would have absolutely gone with the yellows, just got a kick ass deal on the eibachs from a local guy and I couldn't pass up the deal.
Save your money and go springs. I already have the money set aside for when the shocks blow to get some Koni's. You will spend 1/2 the money (with the koni yellows), and with your mild drop and limited track interaction, you really won't need the adjust-ability of coilovers IMHO.
And yes, the car will be autox'd as often as I can get the day off work.
suaveflooder is offline   Reply With Quote
Old 06-24-2013, 08:42 AM   #7
Drftfan
Drives: Argento FR-S
Spring sag. Lol. Okkkkkk. I had eibachs on my 240sx for years and had no issue.
And if springs sag so bad then your stock ones would eventually do the same thing.
Springs do settle. But sag? Highly doubtful.
This is your first performance car?
Drftfan is offline   Reply With Quote
Old 06-24-2013, 09:26 AM   #8
Racecomp Engineering
Coilovers and a spring/shock are essentially the same thing, it's just that the coilover is height adjustable. Saying one sags and not the other is wrong.
A crappy spring can sag whether it's on a coilover or if it's a conventional spring. A quality spring will not sag.
- Andy
Old 06-24-2013, 10:28 AM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
- Andy
Saying coilovers are height adjustable is a pet peeve of mine. The way the term is used by most enthusiasts that's true, although of course it's not a requirement of a coilover (which is obvious).
Agreed on the spring quality
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-24-2013, 10:40 AM   #10
It's true that any spring over shock arrangement (height adjustable or not) is a coilover, but in today's wordage it's just the way it goes that coilover = height adjustable. For better or worse.
For anyone that cares, the stock car technically has coilovers. :headasplode:
- Andy
Old 06-24-2013, 03:41 PM   #11
Vegas Racing
My advice, dont take advice from that guy anymore.
A quality set of springs will last just as long as the OE springs were can. Check out a set of Eibach springs.
Vegas Racing is offline   Reply With Quote
Old 06-24-2013, 03:43 PM   #12
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
RCE or Swift. I went with Swift for extra 0.20 inches drop.
hanabie is offline   Reply With Quote
Old 06-24-2013, 03:50 PM   #13
qoncept
qoncept's Avatar
This is terrible advice. A little drop and minor bump in springrate aren't going to kill your stock struts. And most coilovers that don't cost a fortune are absolute garbage with poor performance and probably won't last nearly as long as stock struts. Even if they did, you could buy OE struts 4 times for what they cost.
If you want to look cool and say you bought something for your car, go for coilovers.
qoncept is offline   Reply With Quote
Old 06-24-2013, 04:48 PM   #14
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
it all depends on quality.
bkblitzed is offline   Reply With Quote
SPRING CLEANING! Haulin Scion FR-S / Toyota 86 GT86 General Forum 14 04-25-2016 10:44 AM
Spring install DaBrz Northwest 8 05-14-2013 10:47 AM
Spring Mountain Run 4/28 SubieGuts New England 0 04-20-2013 11:10 PM
Fact: Girls find it hot when a guy knows how to drive stick? shishand Off-Topic Lounge [WARNING: NO POLITICS] 86 10-20-2012 03:51 PM
fact or fiction on this performance and tuning guide? davey90 AUSTRALIA 10 07-19-2012 07:45 PM
