#71 | |
Drives: 2013 Black FR-S
#72 |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
#73 |
FWIW if you have data logging capabilities either through EcuTek or simply the Torque pro app, you can log the boost pressure and do a pull out on the open road.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#74 | |||
Reverse Burnouts
Drives: 2013 Argento FRS
you also have to remember this kit is going in for CARB approval on that tune so the more conservative it is the better chance they will get CARB approval, CARB approval costs money and i think they would rather not try twice because they failed the first time because they sold the kit with a more aggressive tune that did not pass the CARB requirement on emmission they know tuners will get their hands on this kit and show the numbers we want to see they know it will happen so the initial numbers aren't too much to worry about...
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#75 | |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Yes the engine is physically making more power but you have less coming out the crank. All superchargers have some parasitic lag, how much though, no idea. Just saying it is possible |
#76 | |
Robi (E85, 105 effective octane?)and the auzzies (98RON, 95 "our-octane") have no problemo what so ever. ![]() I need to have my tuner tune the water meth in the low rpms. He only advanced timing for the meth post 3k rpms which is why you see a divergence of the green and red lines start right at 3k. I'll have it spray at 1 psi and have him try to advance the timing. Maybe I'll even swap out the 5 lb/hr nozzle for the 7 lb/hr nozzle... *gasp*
#77 | |
Mr. Cranky Pants
The power consumption of the unit is a known quantity. Roughly 30hp at max rpm(15k) and 1.4bar absolute output pressure(5.8psi boost). It's going to be pitifully low at 2000 rpm and 4-5 psi on this motor.
There's something else going on. Also, the math just doesn't add up with this: Quote:
#78 | |
hint:
#79 |
Mr. Cranky Pants
I can completely understand that. Is that what's actually going on?
#80 | |
I can see that loss gone with 93 octane. Hell it is gone in australia and in Robi's E85 car. I just need to get the meth injecting sooner and the tune adjusted for it. If not, then flex fuel here I come. =) That being said, it doesn't impact my spirited driving at all as I am at or above 3k rpms (and not in 5th or 6th) if I want to go anywhere in a hurry. I am above 4k all the time on the track. Cruising and city driving is part throttle and that feels no different than stock. Last edited by sw20kosh; 06-25-2013 at 12:47 PM. |
#81 | |
Drives: 2013 Asphalt FR-S
I've been laughing at all the low power numbers posts because i learned to tune on a uncorrected dynodynamics.... people with bolt on evo's would come in and baseline 230whp, I would tune them and they would make 280whp and act all butt hurt over not making over 300 like their buddy made on topspeeds dynojet... then they would drive it and could not stop going on about how amazing the car felt... then their buddy would show up the next weekend for me to tune them after they got spanked by a car "only" making 280whp..... I love the shape of the curve on your plots.. it's all very use-able power. Looks like it has the potential to carry out to 8k (with breathing mods). With the right sized header and the smaller pulley it should be awesome. I am curious if the way it sounds will get to you after a while... not sure I want to hear the whine when im in DD mode. I do have a few hardware questions:
~Namaste~ |
#82 | |
Drives: 22 BRZ
![]() Even so, your preliminary results look good, 3k to redline is a WIDE powerband. I bet you are having a blast with that.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
#83 | |
Drives: Black frs project
we will find this out wendsday (70mm pulley) not needed you tune the car on the maf iirc the tuner said the stock map sensor is the same as the one found in a STi Last edited by robispec; 06-26-2013 at 05:47 PM. |
#84 |
Drives: FRS
http://www.ft86club.com/forums/showt...t=39910&page=9
Another innovate Dyno but doesn't look as bad down low.... And a bit better up top |
| Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! | Innovate Motorsports | Forced Induction | 577 | 10-15-2014 12:49 AM |
| Innovate Supercharger!!! | Titanmotorsports | Forced Induction | 62 | 08-24-2014 10:25 PM |
| Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! | Visconti | Forced Induction | 67 | 04-03-2013 03:56 PM |
| Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ | Innovate Motorsports | Forced Induction | 1987 | 03-13-2013 09:14 PM |
