Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 03-11-2013, 05:12 AM   #99
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Thanks, I was planning on using an inline fuse but your solution with a 3rd relay seems a bit safer.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 03-11-2013, 05:30 AM   #100
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Hmm. The downside to the diagram I posted above is that in the event the second relay gets stuck in the non-energized position (30 feeding to 87a), switching on the lights will send 12v to both low and high. I'm going to take a multimeter and check the oem setup to find out if switching on the lights does indeed cut power to the led hi wire
HRTROB is offline   Reply With Quote
Old 03-11-2013, 06:00 AM   #101
sav
sav's Avatar
Ouch, yeah that would not be cool. I've had it happen to me but with the horn - I had to rip the wires out to make it stop.
If I do go this route I'll use the best quality relays possible. Bosch if I can find them.
95RON SAV Tuned
Old 04-26-2013, 10:16 AM   #102
tm86
Drives: 2013 Dark Grey 86B
Did you guys get this working?
tm86 is offline   Reply With Quote
Old 04-26-2013, 10:45 AM   #103
sav
sav's Avatar
Nope
95RON SAV Tuned
Old 04-26-2013, 10:48 AM   #104
sav
sav's Avatar
Originally Posted by Anban View Post
Will take a pic tomorrow and post.bought a fuse to put in line just in case .i also got very irritated with it as park only.send me your mobile number
Still waiting for the pic.
95RON SAV Tuned
Old 04-26-2013, 11:18 AM   #105
tm86
Nope
Damn, you seemed so close to getting it working
Old 04-26-2013, 11:20 AM   #106
sav
sav's Avatar
Yeah, I could get it working I guess but I don't want to cut any wires.
95RON SAV Tuned
Old 04-26-2013, 11:26 AM   #107
tm86
I agree. Rather have it done right or not at all.
Old 04-26-2013, 11:31 AM   #108
sav
sav's Avatar
Exactly
95RON SAV Tuned
Old 06-24-2013, 06:59 PM   #109
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
@sav Any update?
FiRStsc10n is offline   Reply With Quote
Old 06-25-2013, 04:07 AM   #110
sav
sav's Avatar
Unfortunately not, I need the wiring diagram for our headlights and they are definitely wired different to the rest I've seen on this forum. I can't figure out how to activate bright mode.
95RON SAV Tuned
Old 08-06-2013, 02:10 AM   #111
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
So this is my thought on this situation. Seems like my car uses pin #1 for LED high mode. However, the LED low mode is actually missing from the harness. Therefore, there is no techstream flash that can enable the LEDs on the north american spec cars.
12v to pin #1 should enable bright LEDs when the headlights are off.
12v to pin #3 should enable dim LEDs to be on when headlights are off.
Now, I have to find a extra pin to use in slot number 3 as mine is blank. Also, I need to find a source of 12v when the headlights are on. At the moment, i am thinking of tapping 12v from the parking light harness that is really close.
My main concern is this to be 100% reversible and clean looking
edit*** don't try this at home kids. These are strictly based on wiring diagrams and looking at my harness. My test tool is out of batteries so nothing has been confirmed.
projek_01 is offline   Reply With Quote
The Following 3 Users Say Thank You to projek_01 For This Useful Post:
FiRStsc10n (08-06-2013), sav (08-06-2013), SurfAndSand (08-06-2013)
Old 08-06-2013, 02:22 AM   #112
Luis_GT
They are also also missing from the headlight assembly...
Cool feature of the daytime running lights! eriktherod Scion FR-S / Toyota 86 GT86 General Forum 26 08-31-2014 11:28 PM
***FR-S/BR-Z LED Daytime Running Lights 6K White*** Vicious LED Exterior Parts - The Rest 7 10-14-2012 04:38 PM
daytime running lights JDMrolla Scion FR-S / Toyota 86 GT86 General Forum 2 06-06-2012 11:09 PM
