View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 06-24-2013, 05:19 PM   #2115
Huggsen
Drives: 2013 Scion FR-S Raven
Originally Posted by yuicebox View Post
Tell them you're going to file for lemon law protection if they don't fix it. That'll straighten them out quick. Look up the laws in your state.
Idk how it varies by state but basically in Florida, if you have to take the car in for the same problem repeatedly you can get a brand new car if you play your cards right.
Not saying you WANT a new car, but if you threaten them it raises the stakes for them to take care of it.
Also I just heard crickets for the first time yesterday at around 500 miles in. Will be waging war on the dealership soon. how do I know if the fuel pump they replace mine with is the right one? Any way to know for sure?
from what i hear you want the part # with the green dot next to it. But there is no guarantee that will fix it. I have had mine replaced with revised and the revised with the green dot and still have crickets. =(
Huggsen is offline   Reply With Quote
Old 06-24-2013, 05:35 PM   #2116
Carwhisperer
Drives: A lot of supercars.
There is no "fix" for the chirping yet. Just wait.
Carwhisperer is offline   Reply With Quote
Old 06-24-2013, 08:30 PM   #2117
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Either i pay 25 cents more for each liter of gas. Or live with the cricket... fml.
Muaddib is offline   Reply With Quote
Old 06-24-2013, 09:36 PM   #2118
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Hahaha... I hope you are joking because that is definitely not an "FML" moment.
DylanFRS is offline   Reply With Quote
Old 06-25-2013, 08:22 AM   #2119
BadMoon
BadMoon's Avatar
Drives: 2014 GLI Autobahn/Nav
So far I have but several hundred miles on mine with the replaced. We are in a heat wave here. No crickets.
BadMoon is offline   Reply With Quote
Old 06-25-2013, 11:11 AM   #2120
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Originally Posted by Hanzo View Post
I think I would consider that yes, you have the noise it's just not regular. BTW it only happens once the car is driven. When I fire it up in the morning it doesn't make the noise.
Same. Only after warmed up. Goes away under a load
sosick is offline   Reply With Quote
Old 06-25-2013, 12:18 PM   #2121
Realm
Drives: Scion FR-S
Originally Posted by Silver86 View Post
I've been running Ethanol free for about 3k miles and still no chirps.
You will never get them running Ethanol free, just a pain in the ass to pay $4.00 a gallon for it (really sucks if it's not available in your area)
I've had mine replaced once, came back after 300 miles again.
Been running non Ethanol for about 5,000 miles (no crickets), got low on gas and filled up with Ethanol yesterday... they were back within 15miles
Only have two 93 Octane (non-ethanol) stations around here, one 15 miles, one 35 miles away.
Realm is offline   Reply With Quote
Old 06-25-2013, 12:50 PM   #2122
yuicebox
Drives: Asphalt FRS
Originally Posted by Marchy View Post
dude, the lemon law won't apply. the pump works just fine, its just noisy. if the pump failed standing him or causing multiple engine failures then sure, i could see it applying then. But until that happens you just have to deal with the noise.
or go on a e0 hunt.
You may be right honestly, I haven't had time to look into it very much. From what I understand in FL the law says:
"the Lemon Law covers defects or conditions that substantially impair the use, value or safety of a new or demonstrator vehicle (these are called "nonconformities")."
You could probably argue that this impairs the value of the vehicle but you'd probably have trouble escalating it to the point of vehicle replacement. It aids us to some degree that a technical service bulletin has been issued on the subject. You could argue that it's a known issue to the manufacturer and despite having the manufacturer perform the repair multiple times, the problem persists.
I was REALLY focusing on addressing the guy who posted that the dealer was refusing to perform further warranty work because that's unacceptable.
Also I more mean that you might be bale to use this to further substantiate other claims you were making towards lemon law.
Edit to add some detail for anyone in FL:
Rule 1:
If the vehicle has been back to the service agent for repair of the same recurring problem at least three times, the consumer must give written notification by certified, registered or express mail, to the manufacturer (not the dealer) to afford a final opportunity to repair the vehicle.
Rule 2:
If the vehicle is in and out of the authorized repair shop for repair of one or more different problems for 15 or more cumulative days, the consumer must give written notification of this fact to the manufacturer (not the dealer), by certified, registered or express mail.
Last edited by yuicebox; 06-25-2013 at 12:55 PM. Reason: Drastic improvements in clarity and content
yuicebox is offline   Reply With Quote
The Following User Says Thank You to yuicebox For This Useful Post:
strat61caster (06-25-2013)
Old 06-25-2013, 12:54 PM   #2123
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
or go on a e0 hunt.
Lemon Laws typically apply when the vehicle has been taken in for the same repair multiple times or has been in for repair (unable to be used) for a certain number of days.
Lemon Laws typically do not have provisions for severity of issues. He wouldn't be the first to lemon this car based on noises and leaks. Some people deal with it, others expect more from a >$25k purchase.
If I had a car that was out of commission for a month within the first year of ownership I would seriously consider getting rid of it no matter the issue, thank god for consumer protection laws. :happy0180:
ineedyourdiddly
Old 06-25-2013, 01:04 PM   #2124
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
33 days on the Green dot pump, over 1,700 miles, 93 Octane E10 (Sam's Club), Temperature in the high 90's, still no chirp....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 3 Users Say Thank You to Opie For This Useful Post:
Marchy (06-25-2013), Smokinbuffalo (06-25-2013), yuicebox (06-25-2013)
Old 06-25-2013, 01:07 PM   #2125
yuicebox
Drives: Asphalt FRS
I can see that, but the car is only out of commission because you kept taking it in to fix something that really isn't broken.
The manufacturers have released a TSB describe it as an abnormal problem. They outline specific procedures to repair it which don't work.
This is the definition of a recurring problem. Sure, it's not impairing the function, but it IS impairing the value.
It's an acknowledged problem. If the company had just declared it a normal operating condition and never issued a TSB, I'd agree with you.
Edit: If you read the requirements of FL Lemon Law which I posted, it never says that the car has to be out of commission. Ever.
Old 06-25-2013, 04:21 PM   #2126
Tromatic
All of this and nobody knows why it chirps? Nobody has taken one apart?
Old 06-25-2013, 04:22 PM   #2127
Silver86
Silver86's Avatar
Drives: Argento FR-S
Most gas here is over $4 a gallon, Ethanol or no Ethanol.
I drive about 15min typically for gas but its worth it for the MPG and no chirp.
Silver86 is offline   Reply With Quote
Old 06-25-2013, 04:26 PM   #2128
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
only non ethanol here is 88 octane :/
Fett4Real is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
