Old 06-24-2013, 01:42 PM   #1
sw20kosh
Drives: 2013 Black FR-S
Innovate Stg1 Supercharger with W/M injection
Since the official dyno charts are released I can share more specific details on my water/meth cooled stg. 1 kit.
Supercharger:
Innovate Stg. 1 Twin Screw "Complete" Kit (non-intercooled) - Carb Exemption Pending
Water/Meth Inj. Kit:
1.) Trunk mounted alcoholinjectionsystems.com stage 1 kit w/ 3gal tank
2.) AEM water/meth flow failsafe gauge and flow sensor
3.) Snow Performance supercharger bypass valve boost solenoid (to open the bypass when there is faulty flow)
4.) Eaton bypass actuator with two vacuum ports (you need this to make the snow performance boost solenoid work)
Set to come on fully at 4.5 psi of boost. This translates into roughly coming on at 3k rpms if you floor it anywere below 3k. Comes on instantly anywhere above 3k rpms.
Injector Nozzle rated at 330 cc/min. Actual flow at the nozzle is measured to be 380 - 450 cc/min.
When failsafe is triggered the bypass valve opens and only allows supercharger to make a max of 2 psi untill you shut off the engine and restart.
The Dynojet graphs
<<<<<<Latest Graph 7/15/2013>>>>>>>
These below graphs are with OP and DP installed right before the runs. No tune adjustment so there could be a few more ponies in there.
Map 1: 91 pump
Map 2: 91 + Meth inj.
The Dyno dynamics graph
Dyno is a Dyno Dynamics. It reads ~18% less than a dynojet. Stock 86's read at ~130-140 whp. To see the real gains, look at the delta between stock and supercharged. Dynojet numbers coming soon.
Pink = stock 86
Green = base innovate tune
Red = water/meth tune
Highlighting the top end increase in whp:
Highlighting the top end increase in wtq:
Photos:
Other mods:
1.) Robispec Total Cooling Solution (integrated oil cooler and bigger radiator)
2.) Custom cat-back exhaust
3.) Deatschwerks High Flow Drop-In fuel pump
Trunk Mount W/M system
http://www.alcoholinjectionsystems.c...duct_info.html
AEM failsafe
http://www.aemelectronics.com/water-...e-1-4-sae-1184
Bypass actuator
http://www.ebay.com/itm/170895994487
[ame="http://www.youtube.com/watch?v=h4pUqKWHtL0"]Scion FR-S BRZ Innovate vs.Vortech Supercharger Acceleration - YouTube[/ame]
0-107
[ame]http://youtu.be/gpvmd4TEK6s[/ame]
3rd gear 2k ---->
[ame]http://youtu.be/Qpg8Jb1tEeo[/ame]
Old 06-24-2013, 01:45 PM   #2
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Were are you storing the water/meth tank?
Old 06-24-2013, 01:48 PM   #3
swift996
swift996's Avatar
Trunk mounted
Hey sw20kosh - I know I sent you a PM on the bypass valve. Would you mind posting the part number or links whenever you get a chance here?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 06-24-2013, 01:49 PM   #4
nonicname
Drives: it has 4 wheels and a motor
wow so this kit kills torque below 3k rpms?!
nonicname is offline   Reply With Quote
Old 06-24-2013, 01:50 PM   #5
OrbitalEllipses
Drives: Attitude
Would you mind scanning those dyno runs? Pictures are a bit blurry...
Old 06-24-2013, 02:06 PM   #6
Pete
Pete's Avatar
Drives: 22 BRZ
It looked that way on the official dyno too, but that's gotta be because they aren't at WOT yet right?
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 06-24-2013, 02:22 PM   #7
OrbitalEllipses
Drives: Attitude
Dyno pulls are WOT in a higher gear than you'd normally be in for the bottom of the RPM range.
Old 06-24-2013, 02:32 PM   #8
mad_sb
Drives: 2013 Asphalt FR-S
Very nice man, Supper happy to see it pulls out to the limiter!... With all the torque talk I was worried it would puke and die up top, at least on this pulley with the added knock suppression of WMI it does not.
Was this on the low boost pulley?
Old 06-24-2013, 02:42 PM   #9
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
I hope they release the intercooled version soon, the gains on these non intercooler versions are meh at best.
Even w/m sprayed... Mehhhhhhhhh
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 06-24-2013, 04:30 PM   #10
sw20kosh
Unicorn torque is far from mehhhh.
Old 06-24-2013, 04:52 PM   #11
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I think that midrange has this car written all over it. I can't wait until the first AutoX with this SC installed.
Old 06-24-2013, 04:59 PM   #12
whataboutbob
AutoX-10/10ths every run
^^ this ^^
Build thread:Here
Old 06-24-2013, 05:08 PM   #13
swift996
swift996's Avatar
Paired with my EL header & front pipe and the desire to run WMI and retain an aftermarket intake. I expect to get about 250-260whp from the provided pulley.
Remember many of the dynos are on stock air filters and stock headers/exhaust. Not saying it's going to be game changing but expect some better numbers as more people get a hold of these things.
Old 06-24-2013, 05:44 PM   #14
Adeets
OEDC
Adeets's Avatar
I guess I was expecting more from a unicorn. The torque band doesn't look that impressive, and I was expecting it to come out of the gate, not 3,500-4,000
My BRZ FI Build
Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! Innovate Motorsports Forced Induction 577 10-15-2014 12:49 AM
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 10:25 PM
Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! Visconti Forced Induction 67 04-03-2013 03:56 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 09:14 PM
