#15 |
Drives: FR-S Firestorm 2013
This is normal.
#16 |
FR-S driver
Drives: ULTRAMARINE Scion FR-S
what about when you go neutral and slow down and then to a stop the car raddles. sounds like it is coming from the diff?
#17 | |
Drives: slow
The diff is known to be a bit noisy but shouldn't be making any noises unless you're turning. |
#18 |
Drives: Supercharged Golf Cart
2000rpm has been the "effective" minimum rpm of any 4 cylinder I have ever driven.
#19 | |
Drives: FR-S 6MT
Its not all engine noise either.. Clutch and gears make noises with low rpms that rattle on thru.. |
#20 |
Drives: 2013 FR-S Hot Lava
When I'm gentle on the gas, the rattle is very quiet.
I don't know of any way to get the car moving in 1st/2nd at 10mph or less without the rattles. Anyone have a secret?
Live to drive another day
#21 |
Drives: FR-S 6MT
#22 |
I came from a motorbike
Drives: Firestorm 2013 FR-S 6MT
Is it only when you have the car in neutral and you're coasting to a stop? I believe it may be the sound of direct injection.
| The Following User Says Thank You to Mandy For This Useful Post: | e46m3 (06-22-2013) |
#23 |
CAMBAM
Drives: '13 Whiteout FRS
Downshift to 2nd if your going really slow like under 10mph might as well go back to 1st gear..your not driving an automatic you do the work..lol
#24 |
Drives: hot lava FR-S
I had the same problem at low RPM, and I brought my car to Longo to find out whats wrong with this car. The mechanic guy at Longo said ,"It's normal." Also he told me that FRS makes weird noises. :/
#25 | |
#26 |
Drives: UltraMarine FRS MT
I was told from multiple people, first gear is only to get the car moving, once you start moving you should go second. Never drive in first, unless you're just in parking lot and needs to move 10feet to park
#27 |
Drives: Toyota 86 Silver
mine does too.
chatter sound when traveling 1000-2000 RPM in 2nd gear. better use 1st gear for very slow stop and go traffic. |
#28 |
My FR-S will rattle a bit if it gets too low. My WRX rattled a lot too.. same exact sound.
| WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 05:49 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| Steering wheel/dash "rattle?" upon heavy acceleration? | brett_g | Issues | Warranty | Recalls / TSB | 2 | 08-04-2012 04:52 AM |
