Old 06-21-2013, 11:17 PM   #183
orthojoe
^^ Great info. What kind of temps were you getting before the oil cooler was installed?
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 06-21-2013, 11:41 PM   #184
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Unfortunately I didn't have anything to monitor temps before I got the oil cooler. The cooler and a Scangauge were part of the parts-pile that was growing while the car hibernated over the winter.
BatStig is offline   Reply With Quote
Old 06-22-2013, 07:57 AM   #185
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
if someone wants to donate an oil cooler i'd be glad to log before/after temps
smbstyle is offline   Reply With Quote
Old 06-22-2013, 08:31 AM   #186
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Or we can just look at my car
The max I've seen at Sebring with the cooler have been 235.
Edit, err 239F.. 115 celsius.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-22-2013, 07:55 PM   #187
smbstyle
smbstyle's Avatar
I'd rather get a free oil cooler, thanks, lol.
What did you see before you had the oil cooler? And what kind of ambient temps were you in when you were seeing a high of 239*?
Also, kind of getting to the root of the issue; where is everyone getting the arbitrary numbers of "anything over 2xx*f is dangerous"? I know over 230* people claim the engine pulls timing, which is no big deal as its going to be a tad slower for the sake of reliability, it looks like even with an oil cooler we'd hit that on track down here in FL. But where are people getting the fact that over 2xx* it's dangerous? I know cooler temps are ideal, and it never hurts to run an oil cooler, but where's the science to show that having 300*f oil temps is detrimental? Reading into the new synthetic oils, they're claiming to protect up to 500*f, so it doesn't seem like the oil will "fail" or break down at 300*f.
The Following User Says Thank You to smbstyle For This Useful Post:
orthojoe (06-22-2013)
Old 06-23-2013, 08:16 AM   #188
brillo
Drives: 2013 Firestorm FR-S
I believe someone asked one of the gt86 engineers the question about oil temps and the response back was 260 was the maximum safe temp. I'm not sure what the specific issue was with temps over 260. I know other cars can handle near 300+ oil temps without issue from poking around on bobistheoilguy's forum. I'm sure those temps reduce the oil life, but a lot of folks change their oil after a track weekend.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 06-24-2013, 01:15 PM   #189
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
If the car's factory engineers claim that 260 is the maximum safe temperature they why didn't they include an oil cooler from the factory? Seems to me that this car was built specifically for people to have fun with it, DRIVING IT HARD, be it on mountain roads or on a race track. So why develop it with an inherent flaw like this?
Old 06-24-2013, 01:21 PM   #190
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
So they can sell the car cheaper for more people. Given majority are drive around show car types. Small amount will canyon and an even smaller percent will push it hard in the canyons an most will crash if they do. Then a really really really small amount will go track their car compared to overall sales.
RAWR BRZ is offline   Reply With Quote
Old 06-24-2013, 01:24 PM   #191
Hanakuso
How do you get the oil removed from the cooler when you do an oil change? I'm planning on doing 0W-20 for streets and 0W-30 for track so I don't really want to mix them up.
Hanakuso is offline   Reply With Quote
Old 06-24-2013, 01:29 PM   #192
CSG Mike
CSG Mike's Avatar
Pull off a line and drain it... or just mix the old with the new.
Old 06-24-2013, 01:32 PM   #193
RAWR BRZ
I believe it will be a pita so just use 0w30. It will be much easier. Why 0w20 for street? Better fuel economy? Then remember that if you use 0w30 once then swapping it out for 0w20 youre wasting an oil change... You can use the same oil for at least 3 track days granted that its quality oil.
Old 06-24-2013, 01:33 PM   #194
robispec
Drives: Black frs project
I take off a line at the take off plate add my custom an blowpipe adaptor and us air to push the fluids back into the engine gets about 90% of the oil out...depends on the coolers height and orientation..or if the fittings are on the bottom just drain the cooler directly (messy...usually)
robispec is offline   Reply With Quote
Old 06-24-2013, 01:37 PM   #195
Hanakuso
Yeah I would probably want to pull the line but it might get messy. I know with computer watercooling they have quick disconnects that make draining simple, but not sure if it's a safe idea in a car.
I just want to use 0W-20 for the street because a lot of times I only drive short distances and I probably don't get it warmed up enough. Then again maybe it doesn't matter because I rarely go over 4-5k
Old 06-24-2013, 02:02 PM   #196
CSG Mike
CSG Mike's Avatar
Water cooling? Like... computer water cooling?
Just use whatever you'd use on track. The MPG hit will cost you less than the oil change cost.
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 09:48 AM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 12:55 AM
