Old 06-11-2013, 11:02 AM   #15
Onealpha
Drives: 2013 Subaru BRZ
Nice!
Onealpha is offline   Reply With Quote
Old 06-11-2013, 12:00 PM   #16
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
You are a scholar and a gentleman. Nice fabbing!
Old 06-13-2013, 11:24 AM   #17
qoncept
qoncept's Avatar
Updated with wiring
qoncept is offline   Reply With Quote
Old 06-13-2013, 10:48 PM   #18
Xdragonxb0i
Drives: ex500r
So i see that the weakest point is the welds on the two side flaps that hold the beam that is horizontally across the car. I understand that welds are strong, But if the welds fail the tow hook will fall off correct?
im looking to get a tow hook in the future, i want to haul kayaks lol
Xdragonxb0i is offline   Reply With Quote
Old 06-13-2013, 11:08 PM   #19
powerj2
powerj2's Avatar
Drives: 2013 Scion FRS
this is pretty epic
Pew
powerj2 is offline   Reply With Quote
Old 06-20-2013, 03:11 PM   #20
qoncept
qoncept's Avatar
I would say yes, that's probably the weakest point, and yes, if they were to fail, the chains are going with it. I'm confident in the welds. They're a strong corner weld (the pieces were fixed both outside of the corner and the entire corner was filled, then welded again on the inside). Also, the cross beam is very close to the bracket so there is very little lateral force on the tabs. If there was about another 1/8" of clearance the cross beam could be welded directly to the bracket without the tabs. :\
kask2_6.0's hitches have will gussets for additional strength here. I decided they weren't necessary for mine.
Old 06-21-2013, 01:06 PM   #21
jwjknorr
Drives: FRS 2013
I want to tow my jet ski, clearly that may be to heavy for this, any idea on making a stronger one for heavier tows. Clearly we cant tow a boat, but a jetski , or small utility trailer probably can be done. Thoughts?
jwjknorr is offline   Reply With Quote
Old 06-21-2013, 01:11 PM   #22
qoncept
qoncept's Avatar
With some additional gussets I think this design is probably about as strong as it's going to get. Maybe gusseting from the bottom of the receiver back to the mounting brackets. Ideally a lateral piece would help but I really don't know where one could go. I installed my Perrin catback last night which opened up the back a lot (I now have about 4" of clearance), I'll poke my head under some time this weekend and see if anything jumps out.
I'd estimate my trailer weighs about 150lbs, wheels/tires 200lbs, and the rest of what I load for autox another 100lbs. So probably a little under 500 total. The car tows it just fine. It's noticeable when starting from a stop but not so much while driving.
Old 06-21-2013, 01:17 PM   #23
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
your photos are showing up as broken links
mit_peid is offline   Reply With Quote
Old 06-21-2013, 02:06 PM   #24
qoncept
qoncept's Avatar
They're working for me. Are you at work?
Old 06-21-2013, 02:15 PM   #25
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Thanks for the kind words qoncept. Hitch looks good.
How has towing been so far? I'm about done fabbing my trailer to fit 2 dirt bikes. It will sit 8" from the ground, use my stock brz wheels, and have about a 50 lb tongue weight. @ScoobySouth will also be testing the hitch in the next couple weeks for more input before making the final version.
kask2_6.0 is offline   Reply With Quote
Old 06-21-2013, 02:32 PM   #26
qoncept
qoncept's Avatar
So far so good. Backing it up is an exercise in patience - once the trailer starts turning its almost too late to counter steer. Might end up putting a longer tongue on it. The car doesn't mind the load, though, and I can brake as fast as I'd want to with all that behind me.
Old 06-21-2013, 05:01 PM   #27
mit_peid
Boosted Noob
mit_peid's Avatar
Yeah, maybe that's the reason.... i'll check at home (sounds like a problem on my end).
Old 06-26-2013, 10:20 AM   #28
qoncept
qoncept's Avatar
FYI, kask6_2.0 has begun taking preorders for his hitches. Very reasonable price and lightweight. http://www.ft86club.com/forums/showthread.php?t=40098
Trailer Hitch Jack Black Tracking / Autocross / HPDE / Drifting 31 12-22-2015 08:26 PM
FRS BRZ Receiver Hitch phm14 Scion FR-S / Toyota 86 GT86 General Forum 34 03-04-2014 07:03 PM
Are there any trailer hitch options yet Scooby South BRZ First-Gen (2012+) — General Topics 133 08-06-2013 05:59 PM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 10:58 AM
Need Low Profile Trailer..Someone Help whitefrs Tracking / Autocross / HPDE / Drifting 0 06-02-2013 05:59 PM
