View Poll Results: Which would provide the overall better MPG in a dailydriver?
Supercharger 45 32.61%
Turbocharger 93 67.39%
Voters: 138. You may not vote on this poll
Old 06-17-2013, 12:35 PM   #15
jamesm
One thing to note is that most modern twin screws (like the one innovate uses) have an internal bypass that equalizes pressure across the sc, negating much of what I wrote about above (additional load required to compress the intake charge when cruising). That said, on systems that do not have this, that load is a whole lot more than you'd imagine. It can take hundreds of horsepower just to run the (huge) blower on an alcohol dragster. Not so bad on a street car, but it is significant in any case where there is no bypass mechanism.
Old 06-20-2013, 04:31 AM   #16
Fast_Freddy
Drives: Passat
There are many things that can be argued in the super vs turbo charger debate but mpg isn't one of them.
Has anyone noticed that no top tier OEM is currently using a supercharger to augment power output from lower displacement, higher mpg engines? They're all replacing V6 engines with turbo 4 cylinders. The VW/Audi 2.0T is already legendary. Most of the energy used to drive a turbo would otherwise be wasted heat expelled out the exhaust pipe whereas a supercharger places a much more consistent and greater parasitic drag on the engine. This has been common knowledge since the 50's for crying out loud...
Fast_Freddy is offline   Reply With Quote
Old 06-20-2013, 08:07 AM   #17
Foobar
SLO NO MO
Foobar's Avatar
Centrifugals take advantage of the same concept. The Vortech system, for example, bypasses the compressor except under heavy load.
Old 06-20-2013, 01:12 PM   #18
sw20kosh
Drives: 2013 Black FR-S
As stated in the Innovate Twin Screw thread... I am getting 31 mpg on the highway cruising at 70-80 mph with supercharger installed. These things come with bypass valves that allow the motor to breathe air from a more direct route (ie not through the rotors).
Old 06-20-2013, 01:30 PM   #19
jamesm
It still breathes through the rotors so to speak, it just open a port between the top and bottom of the housing. This equalizes the pressure and reduces the effort required to drive the screws because it no longer has to compress anything. It's just spinning the screws, which consumes a bit of power, but not nearly as much as compressing the air does.
Old 06-20-2013, 01:38 PM   #20
sw20kosh
Yes this.
Old 06-20-2013, 01:42 PM   #21
radroach
Drives: car
@Adeets I think the effective efficiency of FI vs NA depends on where you apply it. At sea level, the GT86 performs just fine but at over 500-1000m you'll probably want more efficient power throughput per mpg. NA + tune is probably the better choice at sea levels but once you get up in the mountains (considering europe, maybe austria) i'd think a supercharger would be more efficient.
Old 06-21-2013, 07:39 PM   #22
Robftss
Drives: VW
Depends on the engine's HP and vehicle drag. If you only have a 150 HP peak, you would be into boost @ 90 mph. If you have 300 HP peak, you may be running in vacuum or 'off boost'.
If you can sustain 90 mph off boost and steady state and all things being equal...
Worst: belt driven centrifugal supercharger and twin screw, they internally compress regardless of bypassing.
Roots type: bypassed. So only belt, up gearing losses and inertia.
Turbo: back pressure due to exhaust constriction @ turbine housing. (Turbo aircraft have a manual wastegate override, to decrease restriction and improve economy when boost is not required) Some OEM's have incorporated logic actuated wastegates to 'open' at cruise (Porsche).
Turbos have a slight advantage in 'off boost' drain, but they all consume power.
Robftss is offline   Reply With Quote
Old 06-27-2015, 04:42 PM   #23
surfuxalot
Drives: Toyota Frs
i would think a turbo would increase mpg. turbos are way more efficient than supers. Supers add more stress to the engine, causing for the use of more gas. Turbos are also more reliable, if maintained well. Supers are not as reliable because the dependability of the power is on a belt, meaning if the belt break ur screwed unless ur remove it.
surfuxalot is offline   Reply With Quote
Old 06-27-2015, 05:24 PM   #24
Dream20b
Y u do dis?
Why are you continually bumping old threads, I mean, seriously?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
The Following User Says Thank You to Dream20b For This Useful Post:
HaloFRS (07-11-2015)
Vortech Supercharger or AVO Turbo HillCountryGuru Forced Induction 48 04-11-2014 09:19 PM
Supercharger or Turbo ? #87 Forced Induction 192 01-25-2013 10:20 AM
supercharger or turbo? RussellRockets Forced Induction 137 11-28-2012 06:54 AM
Looking for a Frs for R&D on a turbo and supercharger Toxic Forced Induction 38 10-23-2012 03:13 PM
Induction Poll - NA, Supercharger, or Turbo cloud9 Engine, Exhaust, Transmission 45 02-21-2012 12:41 PM
