View Poll Results: Oil Temperatures seen WITH and W/O Oil Cooler
WITH Oil Cooler Spirited Street Driving < 195 F 12 8.28%
WITH Oil Cooler Spirited Street Driving 195-215 F 9 6.21%
WITH Oil Cooler Spirited Street Driving 215-230 F 11 7.59%
WITH Oil Cooler Spirited Street Driving 230-245 F 3 2.07%
WITH Oil Cooler Spirited Street Driving 245-260 F 0 0%
WITH Oil Cooler Spirited Street Driving 260+ F (Oil cooler not doing its job) 0 0%
With Oil Cooler Tracked 195-215 F 5 3.45%
With Oil Cooler Tracked 215-230 F 4 2.76%
With Oil Cooler Tracked 230-245 F 7 4.83%
With Oil Cooler Tracked 245-260 F 6 4.14%
With Oil Cooler Tracked 260-280 F 2 1.38%
With Oil Cooler Tracked 280 + F 0 0%
W/O Oil Cooler Spirited Street Driving < 195 F 5 3.45%
W/O Oil Cooler Spirited Street Driving 195-215 F 6 4.14%
W/O Oil Cooler Spirited Street Driving 215-230 F 30 20.69%
W/O Oil Cooler Spirited Street Driving 230-245 F 16 11.03%
W/O Oil Cooler Spirited Street Driving 245-260 F 11 7.59%
W/O Oil Cooler Spirited Street Driving 260-280 F 5 3.45%
W/O Oil Cooler Spirited Street Driving 280 + F 0 0%
W/O Oil Cooler Tracked 215-230 F 0 0%
W/O Oil Cooler Tracked 230-245 F 2 1.38%
W/O Oil Cooler Tracked 245-260 F 8 5.52%
W/O Oil Cooler Tracked 260-280 F 24 16.55%
W/O Oil Cooler Tracked 280-290 F 5 3.45%
W/O Oil Cooler Tracked 290 + F 4 2.76%
Multiple Choice Poll. Voters: 145. You may not vote on this poll
gmookher, Huehuecoyotl
Old 05-27-2013, 10:53 PM   #127
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Does anyone know if the Aim Solo DL captures oil temps ?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 06-20-2013, 01:21 AM   #128
robispec
Drives: Black frs project
this our solution
oil cooler in left side tank in the HUGE radiator
front View
Uses STOCK fans
All testing done all temps in "F" not "C"
Latest track data 100 degree ambiant 135 degree track surface temps.
My car Innovate/Sprintex Supercharged NO Intercooler 260 whp on dynojet
222 whp on dynodynamics
7psi 75mm pulley E-85 fuel
Water 198 peak oil 219 peak twenty minute run session with the A/C ON to simulate a FMIC (and it was hot out there lol)
I was driving my car hard enough to set a new lap record on 100 treadwear tires. Track average speed was 98.5 MPH
Customer car same SC Kit with dodgy water/meth injection on 91 octane california JUNK fuel (knocky environmental compromise fuel)
Water 210 peak oil 229 peak
so the data are consistant 20 degree delta between fluids and LOTS of overhead to go higher with the temps and still be safe.
Selling for 985 usd +shipping
Lots-O-room over the top and stays completely within the sheet metal center so IC piping can go out and in either over the top or behind the lights.
Clearance for any IC mounted to the A/C points or front beam
these fit into a stock car NO modifications nessisary.
We are using the stock mounts and the stock hoses. Install is the same as replacing a stock radiator. The only intake that doesnt seem to work is the AIR RAID intake everybody else looks ok with some requiring alternate hose running but all seems to fit.
Works with Full blown kit/ Vortech SC/ AVO/ Innovate SC...
Stock bumper beam stays stock and in stock location.
robispec is offline   Reply With Quote
The Following 12 Users Say Thank You to robispec For This Useful Post:
akuhei (06-20-2013), BatStig (06-20-2013), Carwhisperer (06-20-2013), Draco_PR23 (06-20-2013), JDKane527 (06-20-2013), Jeff86 (06-20-2013), mxsled (06-20-2013), Scooby South (06-20-2013), Sportsguy83 (06-20-2013), TemeCal (06-20-2013), trdfrs (06-20-2013), ultra (06-20-2013)
Old 06-20-2013, 05:26 AM   #129
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
@robispec What kind of temps are you seeing on the streets during normal driving conditions? How quick does the oil heat up?
Thanks.
BatStig is offline   Reply With Quote
Old 06-20-2013, 01:10 PM   #130
robispec
Thanks.
thats the best part under non-spirited driving the water still runs in the 190-200 range due to the thermostat in the engine. Water heats up faster (all water cooled cars have radiators right?) and in this case HEATS up the oil...it also provides a much more stable heat sink/source for any transient oil temp spikes. Air temps fluctuate wildly throughout the year with air itself being a poor heat sink (requires fantastic amounts of air to whic away the heat) and this is the major limit to most air to oil solutions.
The Following User Says Thank You to robispec For This Useful Post:
Old 06-20-2013, 01:21 PM   #131
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Are you absolutely sure it fits the AVO kit? I measured the gap between the top condenser bracket bolt and the AVO IC, and it was less than 9 mm of space. Not trying to argue or anything, but I've already tried with two different radiators and no dice, they don't fit...
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 06-20-2013, 01:24 PM   #132
M1K3
M1K3's Avatar
Drives: vrooom...
My guess is with IC bracket mod
M1K3 is offline   Reply With Quote
Old 06-20-2013, 01:25 PM   #133
Sportsguy83
Drives: Limited BRZ
Which also means IC piping mod
Old 06-20-2013, 02:09 PM   #134
M1K3
M1K3's Avatar
Drives: vrooom...
I have not seen or tried to install Robi's Rad, which you have done both. So I can only guess at what kind of modifications are needed, but you don't think that the flexibility of the AVO IC piping might allow for modification to the IC piping to be unnecessary?
Old 06-20-2013, 02:22 PM   #135
Sportsguy83
Drives: Limited BRZ
Well, it all depends. It might be possible to just turn the IC at the top part and leave the bottom where it sits, and that way the connecting points to the pipes stay the same. But either way, I'm trying to avoid any modification to the IC. At the end it might just not be possible, but I want to explore all possibilities before modifying the IC brackets, connections points, etc.
Old 06-21-2013, 07:16 PM   #136
BatStig
Some say.....
BatStig's Avatar
I have the Perrin oil cooler.
At the track in 80ºF I saw 249ºF tops.
Daily driving I'm at 185ºF. 190-195ºF when I'm cruising with the hammer down (80mph).
Old 06-22-2013, 05:26 AM   #137
BatStig
Some say.....
BatStig's Avatar
If I remember correctly, I saw you posted somewhere that with your total cooling solution your oil temps stayed around 10-20ºF hotter than the water temps. So does that mean that during normal driving your oil is in the 210-220º range?
Thanks.
Old 06-22-2013, 02:42 PM   #138
jamesm
driving around the street with my turbo i'm seeing 220-230 with near 100deg ambient temps. being that synthetics are good to 270+, and i dont plan on tracking the car, i may forego the oil cooler for now. maybe later... but it doesn't seem critical for even a boosted street car.
The Following User Says Thank You to jamesm For This Useful Post:
Sportsguy83 (06-22-2013)
Old 08-14-2013, 12:46 AM   #139
stockysnail
Just the tip
stockysnail's Avatar
Just fyi... Got my Perrin oil cooled BRZ up to 226 degrees on a track day. Daily driving on freeway I get about 180ish.
Old 08-14-2013, 01:58 AM   #140
akyp
Drives: 2012 86
126C max after a spirited drive up a mountain road. 2nd/3rd gear all the way. There are a few bends that are steep and the car stayed at 2nd gear >6000rpm so I guess it's pretty tough for the engine thermal-wise (no oil cooler, stock everything).
akyp is offline   Reply With Quote
oil cooler
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
Oil Cooler Location? Captain Snooze Engine, Exhaust, Transmission 5 11-26-2012 05:02 PM
