Old 06-18-2013, 11:32 AM   #1
jay07631
Drives: 2016 Subaru BRZ Limited Black M/T
Throttle response delay
Just crossed about 4000 miles. seems to getting a slight delay on the gas pedal that didn't exist a few miles ago (getting worse). The only thing I did when I bought the car was drop in a K&N. Any ideas. TIA.
jay07631 is offline   Reply With Quote
Old 06-18-2013, 11:34 AM   #2
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Going back to the OEM filter seems like the first thing to try?
Guillaume is offline   Reply With Quote
Old 06-18-2013, 11:42 AM   #3
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
reset the ecu. itll work itself out.
supramkivtt2jz is offline   Reply With Quote
Old 06-18-2013, 01:21 PM   #4
Aaron_blatherwick
I had the same issue when I installed the k and n drop in filter, but I reset my ECM before I drove it. Throttle response was bad from a dead stop. It's call a dead pedal. The TPS needs re-learned. I would reset the ECM, then turn the key to the on position and depress the throttle pedal to Wot and back five times. I turned the key back off again before starting the engine but I'm not sure if you really have to or not. The dead pedal should be gone. Mine was. Are you MT or auto?
Aaron_blatherwick is offline   Reply With Quote
Old 06-18-2013, 02:28 PM   #5
wheelhaus
wheelhaus's Avatar
I have also noticed poor throttle response and a rather unresponsive pedal after disconnecting the battery, but a couple days later it was fine after the ECU relearned.
Old 06-18-2013, 08:03 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
How long ago did you istall the K&N? If its been in there a while (like months) then i doubt its the cause. Maybe try cleaning the MAF sensor and checking that all the hose clamps are tight on the intake.
1974 TA22 Celica
2013 86 GT
Old 06-19-2013, 10:59 AM   #7
jay07631
Thanks for the excellent replies. I got a MT btw. Will reset ECU by doing the gas pedal thing.
Old 06-19-2013, 11:24 AM   #8
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
try cleaning the MAF, I know ppl here will swear up and down the oil from their filters does not effect anything but its a possibility. After a week or so after the reset you should be able to tell if its gone or not.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 06-19-2013, 07:29 PM   #9
quicksilver30
quicksilver30's Avatar
Drives: '13 LR BRZ Limited| '07 Jeep GC
So this might sound like a stupid question but when you guys say "Reset the ECU" do you mean just unhooking the battery or is there something more?
quicksilver30 is offline   Reply With Quote
Old 06-19-2013, 09:56 PM   #10
charged86
charged86's Avatar
un hook battery both sides for around 15mins. also I have removed both leads and turned headlights on to suck out and remaining power that "could" be in power lines.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
quicksilver30 (06-19-2013)
Old 07-09-2013, 08:22 PM   #11
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
not both just 1 side -- negative. positive can stay
CamryDS is offline   Reply With Quote
Old 07-09-2013, 09:17 PM   #12
charged86
charged86's Avatar
not what ive heard for a very long time
Old 07-09-2013, 09:41 PM   #13
wbsrazzle
Drives: Subaru BRZ 6MT LTD
It's in the manual I believe. To reset the ecu, disconnect negative battery terminal for 15-20 minutes and you can also pump the brakes while disconnected to remove any charges and clear the ecu.
wbsrazzle is offline   Reply With Quote
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
Throttle response after intake mods Aaron_blatherwick Engine, Exhaust, Transmission 2 05-22-2013 05:18 PM
Does the throttle response improve? pr086 Scion FR-S / Toyota 86 GT86 General Forum 36 12-01-2012 01:06 PM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
