Old 12-03-2012, 11:21 PM   #15
gmookher
prefer crush
Old 12-04-2012, 05:03 AM   #16
s1monn
s1monn's Avatar
Drives: FRS asphalt
Hold on a second the Transmission fill/drain plug gasket: SU00303626 - 24mm OD x 18mm ID x 2mm Flat is $9!!??
s1monn is offline   Reply With Quote
Old 12-04-2012, 06:16 AM   #17
Daless2
Developer,
Thanks for the time you took and the info you posted on the washers. No doubt these washers can be sourced from somewhere other then the dealer for something less then the cost of my first born child.
Daless2 is offline   Reply With Quote
The Following User Says Thank You to Daless2 For This Useful Post:
developer (12-04-2012)
Old 12-04-2012, 07:26 AM   #18
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Daless2 View Post
Developer,
Holy Crap... Tell me how you did it... my first born child was like 10,000 times more expensive!!!
Old 12-04-2012, 09:32 AM   #19
diirk
diirk's Avatar
Drives: 4Runner
It was my understanding that the Transmission fill/drain washers were actually different sizes? Is this not the case?
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 12-04-2012, 11:16 AM   #20
developer
Drives: BRZ Limited
Not that I could tell using calipers and my eyes, they seemed to be the same flat washer.
developer is offline   Reply With Quote
Old 12-04-2012, 11:27 AM   #21
diirk
diirk's Avatar
Drives: 4Runner
Thanks. That's good news. So the diff fill/drain washers are the same and the tranny fill/drain washers are the same. So we only need two part numbers.
Was the tranny washer steel or aluminum?
diirk
Old 12-04-2012, 11:30 AM   #22
developer
Drives: BRZ Limited
I would feel pretty secure reusing the flat transmission washers at least once, if they are in good shape. I would check the surface of the washer and make sure there are no defects. They are also pretty soft so I would put them on a flat surface and make sure they aren't severely deformed.
Old 12-04-2012, 11:49 AM   #23
developer
Drives: BRZ Limited
Didn't stick to a magnet and soft so I am assuming aluminum.
Old 12-07-2012, 10:27 AM   #24
Eric1855
Drives: LP DSP / CSP '13 BRZ
Thank you for the information
You can get "generic" crush washers at any auto parts store for less than a $1 each I just didn't know the size the buy. I ended up flipping and reusing the diff ones with no leaks so far. The next change I'll get new washers.
Eric1855 is offline   Reply With Quote
Old 12-08-2012, 12:18 AM   #25
developer
Drives: BRZ Limited
You bet, I am really enjoying the fluid change. My transmission change to Pentosin II made a huge difference in shifting.
Old 06-19-2013, 11:11 AM   #26
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
Subscribed!!! I will change trans & Diff oil for motul 300 this weekend that is if I can find some in Puerto Rico. I will try to reuse everything.
Also I will be changing the Brake oil for motul RBF600 any chance anyone know where to buy a pump to drain the old oil?
kombatlion is offline   Reply With Quote
Old 06-19-2013, 01:06 PM   #27
Sportsguy83
Drives: Limited BRZ
Don't reuse the Differential washers. They are crush washer, I confirmed by doing the fluid replacement. The transmission ones are not crush, preferably change them, but I don't see much trouble in reusing them once.
Amazon has some hand and air pumps to drain the fluid.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
kombatlion (06-19-2013)
Old 06-19-2013, 03:49 PM   #28
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Thanks dude!!! Then I will order some dealer dont have them in stock.
The Following User Says Thank You to kombatlion For This Useful Post:
Sportsguy83 (06-19-2013)
Washer Mod? 636 Engine, Exhaust, Transmission 64 02-20-2018 04:08 PM
Pressure Washer $60 at super store Aznek CANADA 6 09-10-2012 11:08 AM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 11:28 AM
front washer? Filipino Royale Cosmetic Modification (Interior/Exterior/Lighting) 0 06-21-2012 02:06 PM
Man Crush A Friend's Car With A 100-ft Axe ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 11 01-19-2012 03:31 PM
