Old 06-17-2013, 07:57 PM   #15
Splat
Drives: FR-S ultramarine
these rivets get replaced with the screws/washers
Splat is offline   Reply With Quote
Old 06-17-2013, 07:59 PM   #16
Splat
On the top side you are attaching the blocks to those long screws as you put them in. Don't tighten anything ofcourse so that you can wiggle everything around later on final tight.
Old 06-17-2013, 08:01 PM   #17
Splat
My second issue was the hose 90deg elbows point 180deg the wrong way, up instead of down. So, what you do is take your vise grips and loosely get a grip on the hose clamp so it will not turn, with your hand you can wrench the elbow to the correct orientation, pointing down!
Old 06-17-2013, 08:04 PM   #18
Splat
Now you attach the hoses to the top(loosely) with the long hose behind the short hose. You then slide the hoses into the radiator area, and set it down on the mounting blocks. Attach screws loosely.
Old 06-17-2013, 08:05 PM   #19
Splat
The Following User Says Thank You to Splat For This Useful Post:
charged86 (06-17-2013)
Old 06-17-2013, 08:06 PM   #20
Splat
Go back up top and 25Ft lb torque the 27mm bolt. Keeping everything pointed properly.
Old 06-17-2013, 08:08 PM   #21
Splat
Tighten the oil hose lines up top. Start zip tying the lines from top to bottom. The directions say to do this last, but I prefer to do it now that way the hoses are easier to move around. The lines go on the outside of the washer fluid as you see in pic.
Old 06-17-2013, 08:12 PM   #22
Splat
Now you tighten all the mounting hardware for the cooler.
Now use the wrenches to tighten the hose fittings. Use your thumbs as you tighten each to push the hard line of the elbows to face the radiator the best you can as you snug up the lines. This prevents the hoses from touching the bumper frame.
The Following 2 Users Say Thank You to Splat For This Useful Post:
charged86 (07-21-2013), jybrd (07-04-2013)
Old 06-17-2013, 08:13 PM   #23
Splat
Back up top . Install your oil filter, then add the quart of oil.
Old 06-17-2013, 08:15 PM   #24
Splat
Follow directions on leak checks and starting procedure.
Then Put your bumper back on.. rock n roll --
The finished, although Dirty project. I had bought some black VHT paint to cover the silver. Should have used it, I don't like the silver look. Next Time bumper is off will paint it. Hope this helps!
zdr93523 (05-07-2014)
Old 06-17-2013, 10:03 PM   #25
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Notice anything different at all? Do u track your car? I've been thinking about this same kit for a while.
FRSfan111 is offline   Reply With Quote
Old 06-17-2013, 11:41 PM   #26
Dezoris
Dezoris's Avatar
Use Eastwood radiator paint, and do 2 or 3 coats. It is designed for this type of application and heat. I painted mine day one.
Great DIY. So much easier on a stock car.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
Splat (06-17-2013), v1ru5 (07-04-2013)
Old 06-17-2013, 11:42 PM   #27
Dezoris
Dezoris's Avatar
It keeps oil temps at 175 to 195F all the time compared to stock 195 to 230F for street driving.
Old 06-27-2013, 09:40 AM   #28
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Thanks for this. My kit is on the way.
You want it, you got it: PERRIN Oil Cooler GB JoeBoxer Groupbuys 96 06-16-2013 03:10 PM
front bumper removal? ft86me DIY (Do-It-Yourself) Guides 4 06-10-2013 12:28 PM
Perrin oil cooler trouble ft86me Engine, Exhaust, Transmission 9 04-29-2013 07:56 PM
Perrin Oil cooler install review LeeMaster Engine, Exhaust, Transmission 3 03-14-2013 10:41 PM
Perrin oil cooler group buy? white devil Engine, Exhaust, Transmission 6 02-10-2013 03:17 AM
