Old 06-14-2013, 12:01 AM   #15
kkkirbyyy
kkkirbyyy's Avatar
Drives: 2015 STi and '93 Sentra Se-r
any updates? I started hearing this about two days ago and I was planning on going in for the new tsb on our fuel pump issue and have them check out this "tick/click" issue. any input is appreciated. thanks!
kkkirbyyy is offline   Reply With Quote
Old 06-17-2013, 03:37 PM   #16
Hanakuso
Mine makes the tick after every shift. I had a similar noise back when I had my S2K and with that car it needed the axle nut to be retorqued
Hanakuso is offline   Reply With Quote
The Following User Says Thank You to Hanakuso For This Useful Post:
Carwhisperer (06-17-2013)
Old 06-17-2013, 05:26 PM   #17
Carwhisperer
Drives: A lot of supercars.
Mines does the exact same aswell. Hanakuso, but even just while accelerating.
Carwhisperer is offline   Reply With Quote
Old 06-17-2013, 07:54 PM   #18
Carwhisperer
[ame="http://www.youtube.com/watch?v=OCyJ5-10QyE"]VID 20130616 175852 - YouTube[/ame] mines gotten much "worse" its starting to Tick' tink' a lot more than usual.
Old 07-03-2013, 12:18 AM   #19
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
Originally Posted by Carwhisperer View Post
Mine does it going 5 mph in 1st gear all the time. Little throttle, let off *tick* high pitch ticking noise. No idea.. Glad im not the only one experiencing this.
I have the same exact problem. Noticed it today in traffic when i let off the throttle and decelerate to 5mph and you hear a click under the shifter. Mine's an AT btw.
sprintertrueno86 is offline   Reply With Quote
The Following User Says Thank You to sprintertrueno86 For This Useful Post:
whataboutbob (07-06-2013)
Old 07-03-2013, 06:04 PM   #20
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Since AT are doing it also? I'm not a tranny expert but what could it possibly be if it's happening to both? Mine hasn't gotten any worse besides it makes the noise basically eveeytime I go thru 1st thru 3rd and sometimes 4th
Sent from my HTC One
SMOKETREES is offline   Reply With Quote
Old 07-06-2013, 03:04 AM   #21
dschock
Drives: FR-S and 240Z
This clunk has been bothering me since I bought the car last September. Two dealerships have looked at it and the best I get is "We don't have another one here to compare to", or "Just let the clutch out slower". Getting pretty sick of this. This video is where I suspect the problem is coming from. The parking brake set and transmission in neutral, and I am able to rotate the drive shaft a good 20-30 degrees. Can anyone else try this out and post a video to compare?
[ame="https://www.youtube.com/watch?v=1JmFtv5c82s"]FR-S differential backlash - YouTube[/ame]
dschock is offline   Reply With Quote
The Following 3 Users Say Thank You to dschock For This Useful Post:
gonzo (05-29-2014), SMOKETREES (07-06-2013), whataboutbob (07-06-2013)
Old 07-06-2013, 03:55 AM   #22
whataboutbob
AutoX-10/10ths every run
I'll give this a shot tomorrow and post my results. I've also noticed a tick/click sound from my AT when starting from a stop or stopping.
Build thread:Here
Old 08-10-2013, 02:53 PM   #23
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
any update please ?
i am having the same problem
Sookainian is offline   Reply With Quote
Old 08-10-2013, 04:06 PM   #24
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Originally Posted by Sookainian View Post
any update please ?
It's coming from the rear axles. Go to the dealer. Some had success in just torquing down the axle nut. Others have had the inner joint assembly's break in two. And they have been denied warranty. I had mine looked at today he re-torqued it. Helped for a few miles then it was back. Going back on Monday.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-10-2013, 04:45 PM   #25
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
Is there a TSB for this issue ? Do you have the link to those with inner joint broken ?
Also any picture of which part need to be retorq ?
Thanks !
Old 08-10-2013, 09:13 PM   #26
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Ticking common before this failure:
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 08-10-2013, 10:00 PM   #27
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I noticed the ticking on mines too when I set the gear to Neutral while pressing the clutch and releasing it. When I am parked in my garage I do a constant press/depress on the clutch and notice the ticking sound but immediately after I shut off the engine the tick goes away.
It's got something to do while the engine is still running.
LeeMaster is offline   Reply With Quote
Old 08-10-2013, 10:29 PM   #28
feldy
feldy's Avatar
Thanks !
My axle but was torqued down by the dealer today. Still doing it. The assembly is probably cracked right now. Going back Monday
No tsb yet. Also they have been dyning warrantys both Subaru and Toyota
lifter tick? DarkCard Issues | Warranty | Recalls / TSB 11 02-07-2016 02:51 PM
Tick tick tick from the dash FRiSson Issues | Warranty | Recalls / TSB 23 06-12-2013 06:11 PM
Tick Click Tick (injector orgy) empower-auto Issues | Warranty | Recalls / TSB 4 08-27-2012 03:28 PM
Tick Tick injuryexpert Engine, Exhaust, Transmission 3 08-21-2012 09:31 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
