Old 06-05-2013, 03:59 PM   #267
Dustin@Dynosty
^ all of that is taken care of when ordering a custom damper, we under drove the drive belt in order to take into count the extra rpm we will be spinning, if you are running a big system then might affect alternator charging capabilities but even for a street application we set it up to handle normal drive charging just fine
Dustin@Dynosty is offline
The Following User Says Thank You to Dustin@Dynosty For This Useful Post:
Pete (06-05-2013)
Old 06-06-2013, 02:28 PM   #268
Frs300
Frs300's Avatar
Drives: Pile of junk
block will be finished up this weekend and heads will be back from p&p on thursday and motor will be ready to go in. @FA20Club.com still needs to fab up the turbo kit as well so hopefully it will be done in next 3 weeks or so maybe sooner.
Frs300 is offline
Old 06-06-2013, 02:50 PM   #269
dabocx
dabocx's Avatar
Drives: Scion FRS
Cant wait to see this build in action!
dabocx is offline
Old 06-12-2013, 08:25 PM   #270
FeaR-S
Drives: Great White
update on progress....
FeaR-S is offline
Old 06-12-2013, 08:28 PM   #271
Frs300
Frs300's Avatar
had to get new rod bearings because the other set the oil clearance was too tight
Frs300 is offline
Old 06-12-2013, 08:41 PM   #272
FeaR-S
Drives: Great White
looking forward to seeing the results.
FeaR-S is offline
Old 06-12-2013, 09:06 PM   #273
EZWood
BAMF
EZWood's Avatar
Originally Posted by Adeets View Post
To actually get your engine safely to rev to 9k what would it take, the dampner, new valve springs.... I dunno the rest.
Sounds like you are well informed on this subject. Thanks for the info.
EZWood is offline
The Following 2 Users Say Thank You to EZWood For This Useful Post:
DriftEightSix (06-16-2013), tech4pdx (06-26-2013)
Old 06-15-2013, 11:59 AM   #274
Frs300
Frs300's Avatar
@FA20Club.com do you have pics of the heads that came in?
Frs300 is offline
Old 06-16-2013, 04:59 AM   #275
cf6mech
Drives: FRS Silver LS1 swapped.
These cars are awesome boosted with E85 and low compression, and with a lighter flywheel and clutch, wheels and carbon fiber driveshaft.......HANG ON ! The acceleration is violent ....looking forward to when you get your first experience of what this car is capable of.
cf6mech is offline
Old 06-17-2013, 08:30 AM   #276
HunterGreene
Hail Magnet
HunterGreene's Avatar
And then the fuel pump filter disintegrates...
HunterGreene is offline
Old 06-17-2013, 09:11 AM   #277
xjohnx
Grip>Slip
xjohnx's Avatar
Correct me if I'm wrong, but thus far this has only happened to one car, and E85 has not been conclusively identified as the source of the failure.
xjohnx is offline
Old 06-17-2013, 09:23 AM   #278
HunterGreene
Hail Magnet
You may be right, but as the simplest answer is usually correct, the only major difference in that part of the car at the time is the fuel that was in the tank.
Old 06-17-2013, 10:24 AM   #279
jamesm
No one knows if it's safe or not, it just hasn't existed long enough. That's more than reason enough for me to stay away.
jamesm is offline
Old 06-17-2013, 03:30 PM   #280
lexusb3
Drives: FRS
Take the risk!! That's what makes it funnnn^^^^ lol
lexusb3 is offline
#car in litigation?, #ferris bueller ferrari?, 12 year build, 5 month engine build, are we there yet?, edging, fantasy, innovate thread pt.2, its happening!!!!, keep calm and carry on, maybe tomorrow?, not today, not viscontiqued ftw, the neverending build, unicorn!, vaporware
Full Blown Stage 1 Short Block FullBlown Forced Induction 116 03-22-2019 07:29 PM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
How often to rebuild coilovers or stock shocks? stockysnail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 12-24-2012 12:54 PM
2013 FR-S / BRZ (The R&D has Begun) Cotnoir CANADA 10 06-26-2012 03:08 PM
PM Spammers, it's begun! Beast Off-Topic Lounge [WARNING: NO POLITICS] 11 01-30-2010 01:13 PM
