Old 05-22-2013, 10:29 PM   #15
ParangWala
ParangWala's Avatar
Drives: 2013 SCION FR-S
Originally Posted by wparsons View Post
I'm running the stock lugs on mine, the locking lug is a tight squeeze to get the key onto it, but they fit.
+1 tried my stock lugs before getting aftermarkets and confirmed they fit perfectly fine, I eventually went with some aftermarket lugs because I didn't like the color of the stock lugs on my RPF1s LOL
ParangWala is offline   Reply With Quote
Old 05-22-2013, 10:40 PM   #16
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
+1 wouldnt waste mounting those tires back onto ANY rims. Rubber is one of the best bang for your buck and noticeable upgrades you can get for your car.
chulooz is offline   Reply With Quote
Old 06-09-2013, 05:05 PM   #17
Faceless
Drives: 2013 Raven Fr-s
Finally got everything mounted, looks so much better than stock
Went with Hankook V12's 225/45/17, for some reason I could break these loose a hell of a lot quicker than the stock Bridgestones. Hopefully that wears off after breaking them in.
Faceless is offline   Reply With Quote
The Following User Says Thank You to Faceless For This Useful Post:
normancw (06-15-2013)
Old 06-10-2013, 11:57 AM   #18
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Well Faceless, I think your photos just sealed the deal for me. That combo looks great. Was the ride compromised in any way? Does the +35 offset affect handling?
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 06-11-2013, 01:04 AM   #19
Faceless
The only thing I feel that is different is that with the slightly taller tires I feel as though I'm sitting a little higher. The extra 3-4 lbs off each corner is definitely noticeable, and with the extra rubber I feel a little bit more weight in the steering which I love. I would recommend this set-up to anyone.
Old 06-15-2013, 12:56 AM   #20
pinoy_dorifto
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
I can't really see it well, but are the spokes sticking out?
I.G. @mytoy86
pinoy_dorifto is offline   Reply With Quote
Old 06-15-2013, 01:05 AM   #21
Faceless
They do stick out but are still flush with the bead, usually I wouldn't like that but it works with these cause of the sunk in lip
OICU812 (07-18-2013)
Old 06-15-2013, 01:57 AM   #22
pinoy_dorifto
Tuloy po kayo!
I see' as long as they're flushed with the bead, I'm fine with it.
I.G. @mytoy86
The Following User Says Thank You to pinoy_dorifto For This Useful Post:
karma003 (07-18-2013)
Old 06-15-2013, 04:01 AM   #23
Ricky Racer
Ricky Racer's Avatar
Drives: FR-S Argento and 2006 Scion tC RS2
Here is mine. I am running 235/40's, 17x8, 35 offset, also I am lowered on Tein S-Techs.
Ricky Racer is offline   Reply With Quote
The Following 3 Users Say Thank You to Ricky Racer For This Useful Post:
Fly Guy (03-25-2014), karma003 (07-19-2013), normancw (06-15-2013)
Old 06-15-2013, 12:47 PM   #24
pinoy_dorifto
Tuloy po kayo!
Very nice. On the +35 with your drop, do the wheels stick out of either on the front or rear?
I.G. @mytoy86
Old 06-15-2013, 02:28 PM   #25
normancw
normancw's Avatar
Drives: 128i
Looks great guys - would love to see more pics! Ricky Racer - how do you find the handling?
normancw is offline   Reply With Quote
Old 07-09-2013, 03:55 PM   #26
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Old 07-18-2013, 04:29 AM   #27
soodxn
Drives: S2000
do the 17x8 rpf1's fit our car better as +35 offset or +45 offset?
obviously +35 fits the rear better, but what about the fronts? will it poke in the front? or better to play it safe and go with +45.
soodxn is offline   Reply With Quote
Old 07-18-2013, 09:02 AM   #28
wparsons
wparsons's Avatar
On an 8" wheel without measuring, I would guess that at stock height and stock camber a +40 would be about dead flush up front. +35 will poke a bit and +45 isn't quite flush. +35 with ~2* of camber will probably look perfect though.
flickr
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei RPF1 17x8.0 +45 track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 163 03-17-2022 02:00 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Wheel Directory: Enkei RSM9 17x8.0 +48 AsianStyle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 02-17-2014 06:50 AM
Wheel Directory: Enkei RS+M 17x8.0 +35 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 02-12-2014 04:26 PM
