Old 06-15-2013, 08:02 AM   #15
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
That's awesome, Phil--nicely done...
Your still able to clear those 10s w/ just fender massaging? What size tires & offset? Any contact areas?
Thx
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 06-15-2013, 09:17 AM   #16
FeaR-S
Drives: Great White
congrats on win
FeaR-S is offline   Reply With Quote
Old 06-15-2013, 11:55 PM   #17
xn7485
Drives: 1995 Acura Integra GS-R
Just saw this today at hyperfest, awesome turbo setup!
xn7485 is offline   Reply With Quote
Old 06-16-2013, 12:32 AM   #18
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
did you have to mod the full blown rad at all to work with the fa20club turbo kit?
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 06-16-2013, 03:47 PM   #19
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
me likey fender flares...
JackSmiley is offline   Reply With Quote
Old 06-16-2013, 08:54 PM   #20
swift996
swift996's Avatar
Darn, I missed it!
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 06-16-2013, 09:49 PM   #21
Shit Luck
Drives: red frs
It was great talking to you at hyperfest Phil.
Thanks for the info on the managment system.
I hope the rest of your night went well, I know Lance and I never made it to visit those two ladies at work, did you? :happy0180:
Shit Luck is offline   Reply With Quote
Old 06-17-2013, 04:08 PM   #22
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Thx
The front just needs a healthy amount of negative camber and a roll..maybe a slight pull. I was getting some slight rub right at the reflector and at rear corner where the frame rail seam is. I ended up trimming the seam a little and all is good now. Don't forget I'm running "race" spec coilovers (that means very firm).
On the rear substantial roll and pull because you don't want to run too much static negative camber. I'm really not that low so I can get away with it and the flares hide the fact that I'm not low.
Element Tuning is offline   Reply With Quote
Old 06-17-2013, 04:14 PM   #23
Element Tuning
I did not mod the radiator to make it work with the FA20Club kit. It doesn't really fit properly together as it's an extremely tight fit together but we got it to work.
The OEM fans are within about 2 mm of the turbo flange so slim fans are ideal. We simply used a ton of heat protection and surprisingly the fan shroud has not melted.
We had to rotate/clock the turbocharger higher than normal to clear the radiator so we had to trim the underside of the radiator support to now clear the charge pipe and even so the bottom clamp touches the radiator shroud.
It the world I deal in, this was all minor adjustment to make something so essential (a big radiator) fit!
Old 06-17-2013, 04:25 PM   #24
Element Tuning
Ha ha no, they were entertaining, but I passed out about 9 pm from some spiked lemonade concoction in the pits
We actually had to leave to go get my race trailer and come back tso I could handle business on the track Sunday. Handle it we did taking another win.
"I don't know...this Hydra EMS powered, BC Suspension FRS just keeps winning."
We spent the day really sorting the car out again as the roll cage added a new dynamic to the chassis. It wasn't just the extra weight but the stiffness transmits a lot more movement to the suspension now. When we got her dialed, bam the lap time dropped! Had I known I was so close to the track record for TT2 I would have gunned for it since it was only a few tenths away.
[ame]http://youtu.be/H2JmihhU8gk[/ame]
Loving this car so far!
Thanks,
Phil Grabow
Old 06-17-2013, 05:13 PM   #25
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Thanks,
Phil Grabow
Hey Phil, Which cage is that? Something custom or bolt in?
Loving seeing this thing flying in FI trim.
Austin
GTM_Challenge is offline   Reply With Quote
Old 06-17-2013, 06:09 PM   #26
Element Tuning
It's an Autopower Race Roll Bar I had rush ordered. I wish I had a little more time to install and uninstall so I could have cut a hole in the rear side panels and fitted them. A well designed cage fits very tightly amd this one does so I wasn't keen on removing it I do drive this on the street and if anyone will with this cage give yourself extra time to fit the panels because the road noise is massive without.
I'm just about 6'2" and the cage hasn't hindered how I like my seat while racing or on the street.
Old 06-17-2013, 06:24 PM   #27
Shit Luck
Drives: red frs
It's an Autopower Race Roll Bar I had rush ordered. I wish I had a little more time to install and uninstall so I could have cut a hole in the rear side panels and fitted them. A well designed cage fits very tightly amd this one does so I wasn't keen in removing it I do drive this on the street and if anyone will with this cage give yourself extra time to fit the panels because the road noise is massive without.
you just keep adding to the list of shit I need to buy.....
The car is awesome.
We ended up patying with Jr and Forsberg up at the MA-motorsports camp.....
Old 06-17-2013, 08:24 PM   #28
Element Tuning
The car is awesome.
Yeah I chatted with a few old friends in the Ford tent...was good to catch up. As for adding to the list I can relate, I'm been buying plenty to accelerate development of other products. Sometimes you just realise other companies have done a good job and it's easier and faster to use their products
We can knock huge chunks of lap time off with a few tweaks to the suspension and brakes. I will likely toss out some big dyno numbers just to show the capabilities of the Hydra but I plan to continue developing the car at moderate power. I know another company that plans on some massive power with the Hydra so I'll do what I can to help those guys along.
Robispec TIME ATTACK Build robispec Tracking / Autocross / HPDE / Drifting 254 11-18-2014 04:27 AM
One Bad MoFo Time Attack FRS! Element Tuning BRZ Photos, Videos, Wallpapers, Gallery Forum 4 06-13-2013 09:27 PM
Toyota Time Attack May 5th silversprint Tracking / Autocross / HPDE / Drifting 9 04-26-2013 10:47 AM
Speedventures time attack Sonolin Tracking / Autocross / HPDE / Drifting 5 04-24-2013 09:15 PM
My FR-S In Time Attack Mode!! track_warrior FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 09-25-2012 02:13 AM
